Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 8, 2022 at 4:32 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Middle photo is awesome!
  2. May 10, 2022 at 4:41 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    see, now compared to ham radio talk, i could get into that for hours. I dont know jack shit about how to understand electrical systems and i sure would like to.
    turbodb[QUOTED] likes this.
  3. May 10, 2022 at 5:17 PM
    Taquita
    Taquita Well-Known Member
    Denver co
    Pos
    Rust
  4. May 10, 2022 at 8:12 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Hey Dan @turbodb
    How do I acquire a set of those Tundra hard lines? I admittedly didn't look at all... :oops:
    Banjo bolts aren't cooperating for some reason after years of working fine. :notsure:
  5. May 10, 2022 at 8:50 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    https://adventuretaco.com/product/tacoma-to-tundra-hard-brake-line-kit/
    Got a set here with your name on them, ready to go. As I recall, you've got your spindles gusseted, so you'll either need to weld on the spindle brackets or bend the brackets slightly to get them to fit.
  6. May 10, 2022 at 9:01 PM
    Squeaky Penguin
    Brett
    Thanks! :thumbsup:
    Just ordered. I'll make the brackets work one way or another.
  7. May 10, 2022 at 9:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    that sucks. Not surprised though. Grew up there. Cool area. The local schools would do field trips there a lot. That will suffer a lot.
    But people are assholes. So fuck em.
  8. May 11, 2022 at 5:25 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Blackdawg[OP] and jubei like this.
  9. May 11, 2022 at 7:19 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’m biased because I work in the HFC industry, but I think this is encouraging if they can make good on their goals and actually follow through. The fact that they address the issues of water consumption for the electrolysis process, the use of salt domes for long term energy storage, and the transition from coal to hydrogen for the IPP makes it seem like they might actually have a front to back plan rather than just, “buy an EV and put in solar panels and save the planet”.
    I imagine it’s also a good thing in terms of jobs in Millard County as well. God knows that part of the state needs all the help it can get.
    JKO1998[QUOTED] likes this.
  10. May 11, 2022 at 11:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. May 11, 2022 at 11:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Man, did this bring back some memories. Failed ball joints, recoveries and festivities in the rain. Fun times. :cheers:
    And, wow, Kane Creek looks like it might just be a tad worse for wear since I last ran it in 2012. :laughing:
    turbodb likes this.
  12. May 12, 2022 at 12:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    looks like a fun time.
    And man. Brand new rig. Thing has to have 70k or more in it wow. The maiden voyage too.
    also that tow rig is awesome. I want that job. Has like 5 winches on it I think at least. and cool its still a manual.
    Digiratus[QUOTED] likes this.
  13. May 12, 2022 at 5:26 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Also shows what the inevitable is when you don't drive with a CV in the spindle. No good.
    Yeah that trail has eroded a ton in the last ten years.
    Glad to see others watching Rory's channel, I find his videos entertaining.
    It's a beast of a truck and he is a hell of a driver. If you like that video, you'll like this one where he tows a jeep over elephant hill.
    https://youtu.be/JKzolvcQ_Xw
  14. May 12, 2022 at 8:26 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    All that money and no spare cv :facepalm:
  15. May 12, 2022 at 8:33 AM
    Digiratus
    Roaming the PNW
    The RedHead
    A spare probably would not have helped until they could get the old one out and a new wheel bearing/hub in there. But yeah, I get your gist. No real understanding of the rig they are breaking.
  16. May 12, 2022 at 8:39 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I liked what they did to be able to make the brakes still useable even though there was no hub and disk in that caliper. Definitely a creative solution.
    And that use of a shovel reminded me of something somewhere in our past adventures. :rolleyes:
    turbodb and m3bassman like this.
  17. May 12, 2022 at 9:08 AM
    Squeaky Penguin
    Brett
    I doubt they would've needed a new bearing/hub if they swapped in a spare CV immediately. It was driving with no clamping force on the bearing that killed it.
  18. May 12, 2022 at 10:02 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    That was a great video. I like that tow truck even better than Matt's Offroad Recovery, which is one my dad watches all the time.
    A bit of wood works well for this too, should you happen to carry some leveling 2x6's with you ;) Firewood or even a branch would work too.
  19. May 12, 2022 at 10:21 AM
    m3bassman
    Green truck
    I fell out of interest with Matt's channel when it seems they went the way of bigger and more dramatic things. His fraud charges don't look great either. Rory's channel is as authentic as it gets of a guy using a cell phone filming his work, no BS.
  20. May 12, 2022 at 11:22 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That was an amazing recovery. I love the front pivot thing they do.
