Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 15, 2022 at 9:27 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I vote make it a crawler toy!
  2. Aug 15, 2022 at 9:56 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    maybe you can beef up the 7.3 and tow the taco down with it lol. then you have your wheeling rig and a plush living rig. best of both words.
    Jensonbt and turbodb like this.
  3. Aug 16, 2022 at 10:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the new colorado is coming for toyota's lazy ass to take the crown of coolest mid sized truck it seems.
    Speedytech7 likes this.
  4. Aug 17, 2022 at 7:30 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I chose a bad day to drive ve the truck, no AC and a high of 103....
    But the big tires look sooooo cool! I know I know. I might just have to wear them off at this point.
    Frank is not a good example as im not getting another tacoma or another 4runner to distract from the original build. Unless youve never stated that the Frank build ran its course and you needed a new project, that would be the area it overlaps. And i spend a lot of the time in the garage, not much now because its soooo damn hot but im not anti-wrenching lol gotta do something after work! i think my path forward now is to fix the rear springs and then take it out wheeling some local stuff. might remember whats fun about wheeling.
    5.29 with crawlbox and I tow it to the trails! :cookiemonster: can it fit 37's?
    My truck made yours' look stock at hammers so i understand the sentiment :devil:
    just needs a hitch and we would be in business...hmmmm.
  5. Aug 17, 2022 at 9:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh, probably some air bags or beefier springs. i doubt he 10k van suspension will like an extra 750 or so lbs of tongue weight....
    when i towed the taco down to CO for the last trip i put i had the hitch all the way down, no air in the air bags, and the truck all the way forward just to get the tail of the trailer off the ground as much as i could so it wouldnt bounce and drag all over the road lol
  6. Aug 17, 2022 at 9:21 PM
    m3bassman
    Green truck
    I've got bags already I can adjust on the fly independent side to side ;) that said I need bigger bags but capacity isn't an issue.
  7. Aug 18, 2022 at 11:17 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    youre ready to roll my dude
  8. Aug 18, 2022 at 10:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    gpdx and turbodb like this.
  9. Aug 20, 2022 at 12:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Aug 20, 2022 at 10:28 AM
    Digiratus
    Roaming the PNW
    The RedHead
    If it were closer to me, I'd definitely be checking it out. Alas, I never see anything close by.
  11. Aug 20, 2022 at 10:36 AM
    digitalzombie
    digitalzombie Well-Known Member
    love the roof rack
  12. Aug 25, 2022 at 9:54 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    when are we going rock crawling ben
    Reh5108 likes this.
  13. Aug 25, 2022 at 10:16 AM
    m3bassman
    Green truck
    When you in the valley?
  14. Aug 29, 2022 at 5:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
  15. Aug 29, 2022 at 5:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Alright. I was putting some nut serts in the frame for the resi mounts. First ones I ripped some of the threads out. Had to remove one. Adjusted the installer just a bit. And that one now is spinning in the frame with the bolt in it...freaking great. Haha
  16. Aug 29, 2022 at 6:12 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    They take a bit of feel to get right. Which tool are you using?
  17. Aug 29, 2022 at 6:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. Aug 29, 2022 at 8:35 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
  19. Sep 2, 2022 at 3:43 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  20. Sep 2, 2022 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    okay. Expensive. Getting power to is turning into a really PITA and very pricy. So is water.
    But plumbing is all but done. HVAC is almost done. Cabinets hopefully be done designed soon.
    But yeah things are getting pricey. Had hoped we could move in late Nov/early Dec. But idk about that now.
