Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 21, 2023 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Insulation install went well. Probably could have gone a touch heavier in a couple spots but whatever. Only got the hose hung up once. Have to finish plugging the holes tomorrow. Also had to buy more insulation than originally planned but not much more. Whole thing should be under $600 still. Machine was easy to use and quiet too. Would totally have done my own attic if I'd have know how easy it was. Finding one was a bitch. Home Depot and Lowes' machines were all broke. Everyone else did fiber glass. But finally found one way across town which was definitely the most inconvenient part of this project.
    Overall glad I did it.
  2. Jan 23, 2023 at 4:15 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Was it foam insulation you sprayed? Been wanting to insulate my garage roof but the trusses aren't spaced evenly. Foam seems like the easiest option.
  3. Jan 23, 2023 at 7:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No just cellulose.
    Thought about spray foaming my garage. Expensive though.
  4. Jan 24, 2023 at 6:22 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Blow in sounds perfect for you. Its what I'll be doing for the roof in our garage most likely
  5. Jan 24, 2023 at 7:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah it was pretty easy. Although fiberglass or wool is till better than cellulose. But still overall good.
  6. Jan 30, 2023 at 9:50 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Pulled the air boxes on the AMG and must've left something on in the car in the process. Left for the weekend and put it back together last night only to find the battery completely flat. No interior lights even. Was able to jump it after a while. Shut off and fired up after I let it idle for 20 minutes. Felt ok about it but threw the ctek on it to top off the charge by morning. Before bed I tried to fire it up and nadda. Dash lights and radio but no crank. Went out this morning and if I'm not mistaken this is the ctek faulting the battery and telling me I have a bad battery.
    It was replaced by a Mercedes dealership in Portland in April2022. Question is, will my local Mercedes warranty it...
  7. Jan 30, 2023 at 10:45 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You can hit the Mode button to restart the charging/reconditioning process and see if the fault comes back. My CTEK did that but after restarting it charged up just fine.
    If you’re running an AGM you’ll want to put it on AGM mode before restarting as well (the snowflake light) so it charges at a higher voltage.
    jubei likes this.
  8. Jan 30, 2023 at 10:54 AM
    m3bassman
    Green truck
    Its a normal battery but I misunderstood the manual and thought the snowflake was trickle charging which is wrong. Means I've been using the wrong program on the van. Thanks for the heads-up to make me reread the manual.
    I pulled it off to check the voltage with the multimeter but couldn't get a solid voltage reading. I was late for work and freezing so I just threw it on w/o the recon step and I'll see how it is tonight. It's incredibly odd to be so dead in only 48 hours.
    drr[QUOTED] likes this.
  9. Jan 30, 2023 at 11:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well idk about where you are but was -20 last night and cold as hell the night before. Which obviously pits the ole hurt on the batteries.
  10. Jan 30, 2023 at 12:07 PM
    m3bassman
    Green truck
    It doesn't stray far below 50* in my garage ;)
    BossFoss and Jensonbt like this.
  11. Jan 30, 2023 at 5:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol right. Forgot about that.
    In other news. I'm convinced now that these kenda's are the best damn all around tire I've ever owned. Did take a small mpg hit compared to the 255s I had before. But traction is so much better. Our roads are nothing but ice and snow right now. 0 issues. These are basicly snow tires.
    Off-road they do great too.
    Still look near new too. Though I have no idea how many miles are on them.
    Reh5108 and 50Buck like this.
  12. Jan 30, 2023 at 6:09 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Good info on the tires. Which ones are they. Size?
  13. Jan 30, 2023 at 6:14 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My Kendas have been pretty bad ass too, haven't let me down yet. Got close one time but they dug themself out
    Blackdawg[QUOTED][OP] and 50Buck like this.
  14. Jan 30, 2023 at 6:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Kenda R/T 33x10.5r17
    They are a tall 33 too. And I'd say wider than 10.5 too.
    But damn good.
    50Buck[QUOTED] likes this.
  15. Jan 30, 2023 at 6:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right forgot you got some.
    Haven't let me down really either.
    50Buck and JKO1998[QUOTED] like this.
  16. Jan 30, 2023 at 6:16 PM
    50Buck
    Ah, So quite a bit larger than stock. Did you need wheels with a different offset to keep them off the UCAs? Any mods or trimming to fit?
  17. Jan 30, 2023 at 6:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah all the standard 33 stuff. I have scs wheels already and had cleared for 255/85r17 that I had earlier.
    17" ray 10s with the 4.30 back spacing I think. The non really aggressive ones.
    I still took a hit going from the 255s to these though. They are a lot bigger. Not sure about weight.
  18. Jan 30, 2023 at 6:46 PM
    m3bassman
    Green truck
    That's good for to hear. These yokies wear really well but this time of year suck. In 2wd I got stuck leaving this parking spot :laugh: I should see if they make Kenda's in my size.
  19. Jan 30, 2023 at 7:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    35s? Yeah they do. Though idk if 315s. Do in 35x12.5r17 though pretty sure.
    Shit they make 35x10.5r17. Forgot about that. Almost made that jump for the hell of it haha so if you didn't want the fat ones you got two options.
  20. Jan 30, 2023 at 7:29 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I’ve really been liking the 35x11.5r17 size, they fit way easier than 12.5 wide and don’t rub anything in comparison. 35x10.5 might be a little on the skinny side in my opinion but I bet fits really well.
