Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 30, 2023 at 7:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I wouldn't be worried about it being to skinny if they are like my "10.5" wide ones. I think they are closer to 11 really.
    What are you running in 35x11.5
  2. Jan 30, 2023 at 7:45 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah they’re probably really close, I didn’t feel like I had the same flotation with 255/85.
    I have trail graps in 35x11.5r17 C load range
    jubei and Blackdawg[QUOTED][OP] like this.
  3. Jan 30, 2023 at 8:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    C load. Awesome. These are D I think. And mostly fine. C is the best though.
    drr[QUOTED] likes this.
  4. Jan 30, 2023 at 9:35 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Good to know. The problem is these wear so well I'm many years away from replacing them. Once I fix the ride I may jump to an AT and pray the yokies are worth something used.
  5. Jan 30, 2023 at 9:36 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Put them on the van. There are buildings that weigh less than that thing, I'm sure it can wear them down.
  6. Jan 30, 2023 at 9:38 PM
    m3bassman
    Green truck
    Would require cutting the cab corners. The U-joint kit pushes the axle forward enough to run 35s but the Quigley doesn't. Otherwise it would've happened already lol
    Speedytech7[QUOTED] likes this.
  7. Jan 30, 2023 at 9:39 PM
    Speedytech7
    Ah bummer, it would look proper on some 35s...
  8. Jan 30, 2023 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    these are super aggressive for an AT. Near a MT honestly just lots of siping. The photos don't look like they are aggressive but in person they really are.
  9. Jan 31, 2023 at 10:31 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    @Digiratus, every time I think I’m done with FAA testing life finds a way to pull me back in. My boss decided to get his license, so once again I turn to Gleim test prep to get my CFI, probably end up with all three before all is said and done, I’m scratching my head trying to remember…did you retire? At least he got a cool bird to learn in
  10. Jan 31, 2023 at 10:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That things looks like it'll be way too much fun.
    Yup. Forced out when covid happened. There were a few of us that were considered superfluous when we were all sent home to try to work from there.
    It was mere coincidence we were the ones paid the most. :rolleyes:
  11. Jan 31, 2023 at 10:47 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Sorry about the “questionable” circumstances of your retirement, that’s shitty… I’d threaten to use the competition, but since Gleim got me through my first 5 ratings I’m hesitant to reinvent the wheel. Hope retirement has involved a lot of cool wheeling opportunities…
  12. Jan 31, 2023 at 11:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, it was uncool at the time. Everybody likes to feel appreciated and this didn't feel that way. But in the long run, they did me a favor. Retirement is cool and I'm having fun with it.
    And it wasn't Gliem, so you are good. I worked for ASA. Aviation Supplies & Academics.
    jubei likes this.
  13. Jan 31, 2023 at 11:16 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Well this is slightly embarrassing, trying to figure out why I thought you worked for Gleim. Not that I can really boycott ASA either, have to have a copy of the the practical test standards for each checkride too and they pretty much have that market cornered.
    Digiratus[QUOTED] likes this.
  14. Feb 4, 2023 at 6:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Flooring is mostly in. Cabinets too. Kitchen is looking good.
    IDtrucks, jubei, m3bassman and 8 others like this.
  15. Feb 7, 2023 at 8:51 PM
    m3bassman
    Green truck
  16. Feb 7, 2023 at 9:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I wish I could like this more than once. Even getting a fillup from the Zanemaster himself. Can't thank you enough for all the help through this process. :hattip:
  17. Feb 7, 2023 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow you got one eh? 97?
  18. Feb 7, 2023 at 10:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It's an all stock '98 4x4 with a v6 and 5 speed.
    drr, BossFoss and Blackdawg[OP] like this.
  19. Feb 7, 2023 at 10:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nice looks pretty clean.
  20. Feb 7, 2023 at 10:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I haven't seen it in person yet, but Ben tells me its worthy.
