Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 3, 2023 at 6:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The A340 is like a father that has already threatened to turn the car around. He knows he can't give up on the trip but he has zero enthusiasm to continue onward. It's the official transmission of passive aggression.
  2. Mar 3, 2023 at 6:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You shush! Don't be so mean to that hard working auto. :D
    You might try making an adjustment to the pressure line. That is the one that attaches to the throttle body. Maybe try shortening it just a tad. Maybe just a 2-3 threads on the adjuster nuts to see what it does.
    Speedytech7[QUOTED] likes this.
  3. Mar 3, 2023 at 6:39 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I'll will do that, thanks
  4. Mar 3, 2023 at 7:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It won't. That's just the joys of a 3 link panhard setup.
    We put all new bushings in. And upgraded links(they were actually really nice) sub links and panhard. Still does the wiggle.
    Jeeps are the same.
    Did help not to have it lifted too much though
  5. Mar 3, 2023 at 7:08 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    But it's a 4 link.
    And did it have a panhard correction? I understand those are necessary for lifted 4unners.
    Reh5108 likes this.
  6. Mar 3, 2023 at 7:23 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Its part of the design. The rear suspense on our trucks with leafs only moves up and down. If you were to watch the 4runner as the axle moves up vertically it also will also move front to back which is what gives the wiggle. Bushings should help but expect some degree of that feeling no matter what. I believe it gets more pronounced with a lift. The green 4runner I had wiggled way more than yours does.
  7. Mar 3, 2023 at 7:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    We got one yes that was the upgraded one. Plus lowered it with different coils. Helped. But still swings.
    It's more of a 3/4 link hybrid design. Not a true 4 link really. The top links are only like 12" long.
  8. Mar 3, 2023 at 7:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The wiggle feels like it's a bit of side to side movement to me. And it seems to happen with weight transfer, like coming out of a turn.
    FWIW, the trucks axle moves in a very shallow arc. It is not perfectly vertical. Not knowing what the actual movement of the 4R's axle is, it is hard to compare and hard to know what the exact difference is, other than the feel.
  9. Mar 3, 2023 at 7:43 PM
    Speedytech7
    Leafs also move in an semi-arc but it's odd because they flatten out as well, but that a front to back movement not side to side. The 4 runner wiggle comes from panhard geometry moving the axle side to side under the body. The land cruiser has better panhaed geometry (being wider helps the arc not be as steep) and doesnt have as pronounced of a wiggle.
  10. Mar 3, 2023 at 7:45 PM
    Speedytech7
    Still a 4 link, but it's not a triangulated 4 link so it requires a panhard for lateral axle locating
  11. Mar 3, 2023 at 8:14 PM
    m3bassman
    Green truck
    Go flex is out and see how it the axle moves. I'm sure it'll be telling.
    I always felt that the 4runner rear axle rotates around the Z axis. Like as the axle on one side droops it move fore or aft. That's what gives the side to side feeling as the wheelbase is changing, side-to-side over undulations. Certainly the leafs have an arc but it's negligible in comparison how much the 4link moves laterally. Just my recollection of it. Big picture is it's a unique feeling but not something that makes you feel uncomfortable.
  12. Mar 3, 2023 at 8:27 PM
    BossFoss
    Wyoming
    01 DC Tacoma
  13. Mar 3, 2023 at 8:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't need to flex it, I fell it on the street.
  14. Mar 3, 2023 at 8:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It seems like replacing the 300K bushings might be worth it. If they are rubber, they are worn out. And you might find that it does reduce that wiggle.
  15. Mar 3, 2023 at 8:39 PM
    Speedytech7
    SPC makes some nice replacement lower rear arms, the rubber bushings from toyota are hard to beat for the panhard and upper links.
  16. Mar 3, 2023 at 8:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Likely see my future there. But the front end is first.
  17. Mar 3, 2023 at 9:05 PM
    m3bassman
    Green truck
    Care to elaborate what you felt up front? Sway bar bushings the problem? The front did not feel wore out but we didn't get up to highways speeds much. I certainly think the front needs something. The green truck with a used leaking steering rack and balloon tires is way more responsive on center and need much less correction to go straight that your 4runner. Btw.... Lbj should be done too on your rig.
  18. Mar 3, 2023 at 9:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    LBJs are a definite as they could well be originals. As you saw in the extensive documentation the PO had, there is no evidence they have ever been changed. But LBJs do not account for the front end wander which is minimal at slow speeds but very noticeable at highway speed. Add in a headwind and you better be on your toes or you'll be in the next lane before you realize it. Beyond that could include LCA bushing and or inner and outer TREs. I am not sure yet. Honestly, hadn't considered the anti-sway bar bushings. What are those?
  19. Mar 3, 2023 at 9:27 PM
    m3bassman
    Green truck
    Damn I had a set of white lines I should have sent home with you for the lcas. I can give em to you next time we meet up if youre interested. Planned to put them in the green 4runner but was so beat up by the green truck I never did.
  20. Mar 3, 2023 at 9:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Are the whilelines for the 4R different from the ones for the Tacoma?
