Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 27, 2023 at 6:17 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Sounds good, I can mail you some B-Day card cash or PayPal it to you. Was looking at white lines website after Brett's advice and decided to go that route anyway for most of them and TC for the rack. I'm pretty sure I did TC years ago for the extended cab, but had forgot its been so long.
  2. Mar 27, 2023 at 7:57 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Send me a PM and I'll get the ball rolling on this end.
  3. Mar 27, 2023 at 8:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not to disrupt the white lines but the sonodorn or whatever lca bushings and good too. And easy to install and replace.
  4. Mar 27, 2023 at 8:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  5. Mar 27, 2023 at 8:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I thought you were trading those for a canopy. :rolleyes:
  6. Mar 27, 2023 at 8:32 PM
    m3bassman
    Green truck
    You didn't take them....
  7. Mar 27, 2023 at 8:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was just giving you a hard time buddy. :boink: And it looks like Brett needs them more that me.
  8. Mar 27, 2023 at 9:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Wouldn't waste my time again with the ES bushings for the steering rack. Less than a season and my rack slides in the D bushing. Granted my rack mounts could be fubar like Brett's was. I plan to try the TC ones whenever I care enough to replace them.
  9. Apr 2, 2023 at 4:17 PM
    m3bassman
    Green truck
    The AMG is a 13 second car. More rubber in the rear and I think it could get into the 12s!
    Blackdawg[OP] and Jensonbt like this.
  10. Apr 2, 2023 at 7:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice. Bet that was fun!
  11. Apr 2, 2023 at 8:39 PM
    m3bassman
    Green truck
    It was so much more fun than I expected. I wish I had done it sooner. I would be curious about what the green truck could do but with the AMG feeling like it could break 13 it's impossible to make the sacrifice. Maybe later this year I'll see if the green truck can put down a time... It's a fun day point to have.
  12. Apr 3, 2023 at 1:29 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    how often is the track open to run?
  13. Apr 3, 2023 at 6:17 AM
    m3bassman
    Green truck
    Next two and then I think there's sanctioned events starting up with grudge/test weekends sprinkled in.
    Here was my second run and you can see that I had traction issues. Also a weird bog in the rpm when it shifted into 3rd. Didn't happen on the final run so I'm not sure what happened.
    https://youtu.be/OwjvUVq_uVY
  14. Apr 3, 2023 at 12:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Huh yeah that was an odd burble.
    Looks fun though. Go to an autocross event too while you're trying out race car stuff. Looks so fun.
  15. Apr 3, 2023 at 1:42 PM
    m3bassman
    Green truck
    That would just end in tire smoke haha. If I wasn't selling the mini it would be so much better suited for that. After a lot of thought I am unsure if I want to keep racing the AMG. It's too cost prohibitive for me to try to gain more power. I could do some drag radials but that's about it with an engine that if blown is not something I can recover from. So we will see if I can leverage a different platform in the fleet...;)
    Jensonbt likes this.
  16. Apr 3, 2023 at 8:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah. They setup the courses so you will torture the tires for sure. But you'll barely ever get out of 2nd gear. It's more about cornering. Which yeah the big AMG probably isn't the best for. But it would still be fun in it. I'd at least try it.
    Mini would be better sure. But I saw people running all kinds of stuff when I went to one. Looked awesome. Run what you brung!
    I doubt you'll blow the engine. The diff or tranny...maybe haha
  17. Apr 3, 2023 at 8:47 PM
    m3bassman
    Green truck
    Yeah I don't think you understand that no matter the course, 500hp is gonna be a smoke show, never out of second. The car slides in second all day long without having to try. It's truly an Autobahn cruiser in every sense of it.
    Right now the train is leaving the station on getting an old truck over 100mph. I pulled some parts off tonight. I will set a baseline and then spend the summer seeing what improvements I can make. It's no secret I'm bored with it so may as well see what else I can do with it. It's proven itself on the dirt. Time for a new chapter.
    https://youtu.be/cRVA96Rvka8
  18. Apr 3, 2023 at 10:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Does it not have traction control? To keep it from doing that?
    And step 1.
    remove 35s lol
  19. Apr 5, 2023 at 1:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    now now ben. theres always harder dirt to prove yourself on :D
  20. Apr 5, 2023 at 2:04 PM
    m3bassman
    Green truck
    Meh.
