Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 12, 2023 at 7:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, you got into two of them somehow. :laughing:
    And more than a decade. 11 1/2 years ago...
    m3bassman[QUOTED] likes this.
  2. Nov 12, 2023 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ha yeah think most my photos of that era might be gone or only whats on here now after the whole photo bucket shit show.
    Fun times. Man, Frank's OG color...so good.
  3. Nov 12, 2023 at 7:50 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Ironically my truck is more or less the same as it was then if you think about it.
  4. Nov 12, 2023 at 8:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That ain't Frank, that is Pre-Frank. :luvya:
  5. Nov 14, 2023 at 12:52 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    And in today's episode of "Hey, that's not your truck!" I give you:
  6. Nov 14, 2023 at 1:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It is, but it's an old version. :humble:Late 2012/early 2013
  7. Nov 14, 2023 at 2:05 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Wait, is Cheyanne your screen name in another world? :p
  8. Nov 14, 2023 at 5:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Popular truck to steal apparently haha
  9. Nov 14, 2023 at 7:17 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    occupy moab. fucking legendary time gents!!
    Digiratus[QUOTED] likes this.
  10. Nov 16, 2023 at 8:42 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    It's been a while.... but I'm back. Just picked up an FJ transfer case so I can twin stick it. Cheaper than regear to split 1st gear for the wife. Also picked up a dash so I can replace mine that has a hole in it passenger side.
  11. Nov 16, 2023 at 10:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah no doubt been a while.
    Your twin sticking to avoid a diff regear? Not sure how that is supposed to offset a diff regear..
    Reh5108 likes this.
  12. Nov 16, 2023 at 11:36 AM
    FreidTaco
    FreidTaco boost
    jeff
    2low to start moving, shift to 2hi and go through rest of gears like normal. Just use it to split 1st or reverse. Stock gears, 35s, heavy, racing clutch, light weight flywheel make it hard for her to get it moving. Also have a steep driveway approach into garage.
  13. Nov 16, 2023 at 12:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah gotcha.
    I'm not certain you can shift from low to high while moving though..
  14. Nov 16, 2023 at 12:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can, just not vice versa.
    FreidTaco likes this.
  15. Nov 16, 2023 at 3:44 PM
    FreidTaco
    FreidTaco boost
    jeff
    So give me a 2 year summary of what I have missed...
  16. Nov 16, 2023 at 5:33 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Frank is still broken, but has more cobwebs than two years ago.
    Guess that about sums it up.
    Jensonbt likes this.
  17. Nov 16, 2023 at 6:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I can't remember for sure but I think it was great.
  18. Nov 16, 2023 at 7:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Let see..uh..
    Gage is moving to WA, had a kid.
    I built a house, got married.
    Mike retired, living large camping
    Dan's doing what he does camping every week basically.
    Probably some other stuff.
    more like wasp nests haha
    turbodb[QUOTED] likes this.
  19. Nov 17, 2023 at 10:13 PM
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
    Great afternoon all, is there a Wyoming Craigslist forum on this thing?
  20. Nov 18, 2023 at 1:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There is a wyo craigs list.
    If you mean a regional FS thread, no. Other than posting here. There aren't a lot of active wyo members anyways.
