Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 20, 2023 at 9:14 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    It's all relative but I did find that some of the stuff I ran in moab wasn't a cake walk.
  2. Nov 20, 2023 at 9:35 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i dont think the cv is going to snap going down hill :p
  3. Nov 20, 2023 at 9:39 AM
    m3bassman
    Green truck
    Well sir, I struggle to drive up obstacles while simultaneously taking third person pictures of it. Only stopped here cause the frame was holding me on the rock.
  4. Nov 20, 2023 at 6:58 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No go on this one, unfortunately. :pout:
    Hope you gents have a good time.
  5. Nov 20, 2023 at 7:27 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Booo :angrygirl:
    Save that CV for me, I'll pick it up later.
  6. Nov 22, 2023 at 8:20 PM
    m3bassman
    Green truck
    Update from me: truck is dead. Electrically. Was struggling to crank each morning the night was below zero. Got the AMG put back together then hitched a ride to get the truck and haul a load, left it out front with the flashers on for a few minutes and it was no start from there. Had to solo jump the damn thing and then moved it to its new parking space.so the truck needs a new battery and new terminals. It's no surprise as it has had electrical woes for years and the cables Zane made me would likely solve it. @Speedytech7 do I have to open any looms or will I be able to unbolt and bolt in the new cables?
    Good news I'm in my own place now, have a place for both cars and an awesome "yard" to run the dogs off leash. A couple months from now we will have a lot more clarity on the situation but I have to say I'm feeling good and things are looking up
    jubei and Blackdawg[OP] like this.
  7. Nov 22, 2023 at 8:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    To do it cleanly, yes I would open the looms, but you can install it just by zip tying it to the existing loom and hooking it up instead of the existing wiring. Be careful tightening the terminals, tighten them just tight enough so that they don't twist on the battery terminal, no tighter.
  8. Nov 22, 2023 at 8:36 PM
    m3bassman
    Green truck
    I'll have to see how doable that is. Will be a parking lot job so limited.
  9. Nov 22, 2023 at 8:43 PM
    Speedytech7
    12mm, 10mm, maybe some zipties, all you need. Pulling fender skirts up or skids would make it a cakewalk
  10. Nov 22, 2023 at 8:47 PM
    m3bassman
    Green truck
    Fender skirts have been gone for many years. Skid would help with the starter wire I'm sure. What does the third wire go to?
  11. Nov 22, 2023 at 9:01 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Did you move away from Boise?
  12. Nov 22, 2023 at 9:02 PM
    Speedytech7
    To the fuse box, but you can skip it if you're short for time, it's an easy replacement tho.
    m3bassman[QUOTED] likes this.
  13. Nov 22, 2023 at 9:07 PM
    m3bassman
    Green truck
    Technically yes I moved to an apartment in Nampa due to some....life changes.
  14. Nov 22, 2023 at 9:14 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Ah, picking up what you are laying down. Keep your chin up man.
  15. Nov 23, 2023 at 12:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nice. Glad it's settling.
    Sounds like an easy enough fix.
    How's things going in your world???? Any news?
  16. Nov 23, 2023 at 6:30 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Still just waiting, things look good, but no signs of it kicking off yet. If we get to 41 weeks which will be next Friday they will induce, but for now just letting nature do it's thing. If you guys make it over here let me know and I will come say hi, haven't had enough time to make it your way yet.
  17. Nov 23, 2023 at 9:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Awesome! Hope it goes smooth. Will definitely try and hit you up next time we are there.
    BossFoss[QUOTED] likes this.
  18. Nov 23, 2023 at 9:24 AM
    m3bassman
    Green truck
    Blah, thermostat stuck open on the Mercedes. This car is really beating me up lately. Might as well get it done while I still have access to the garage.
  19. Nov 23, 2023 at 9:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well it is a used Mercedes haha how many miles are on it?
  20. Nov 23, 2023 at 10:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Happy Thanksgiving dudes!
    Skawdee, Digiratus and BossFoss like this.
