Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 25, 2023 at 4:42 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Fresh snow and close to 0° here
  2. Dec 25, 2023 at 5:07 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Was nearing the teens last night over in Oregon.
    Actually was interesting, I had a sleeping bag and was warm in the van, but when it got real cold at night, it was as of Znüni was trying to lay on me to keep me warm, couldn't get her to leave me alone.90lb weighted blanket is warm but a lot!
    TacoVio, mic_sierra and SconnieHailer like this.
  3. Dec 25, 2023 at 5:19 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    My 4 legged heater does a pretty good job of keeping me warm.
  4. Dec 25, 2023 at 5:25 PM
    m3bassman
    Green truck
    I mean i stayed plenty warm. Just breathing was an issue...
  5. Dec 25, 2023 at 6:55 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I prefer your weather for sure! Over half an inch of rain on partially frozen ground is gross.
  6. Dec 25, 2023 at 7:45 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah that doesn't sound cozy and fun
    SconnieHailer[QUOTED] likes this.
  7. Dec 30, 2023 at 12:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You were right @drr was a bad caliper. Wasybrbay one. Had a spare one from Napa so easy enough fix.
    Speedytech7, Jensonbt and drr like this.
  8. Dec 30, 2023 at 1:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What is that?
    BossFoss likes this.
  9. Dec 30, 2023 at 1:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm fluent in Ben's texting so I was able to use some of those skills on Monte's there. I think he said it was an eBay caliper
    TacoVio and BossFoss like this.
  10. Dec 30, 2023 at 2:02 PM
    m3bassman
    Green truck
    I concur with zanes assessment.
    Jensonbt likes this.
  11. Dec 30, 2023 at 2:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, got it.
  12. Dec 30, 2023 at 4:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn you guys are good.
  13. Jan 1, 2024 at 11:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Happy new year my dudes.
    I'm starting it off with a failed front wheel bearing it seems like. Been a while since I looked up how to do this but I do remember the horror stories of presses not being able to do it. Last time I just striped down the spindles and took it to Toyota and had them do it. Think I even brought the parts.
    But I don't live super close to a great dealer anymore. My dad has a press in Powell so I'd either go get that or bring the spindle down. Or am I dreaming the harbor freight special can even do it?
  14. Jan 1, 2024 at 11:44 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I wasn't able to do it with my 20 ton press, but that was because it's really hard to get them fixtured.
    You basically have to support them by the little bosses where the dust shield bolts go, but hold it high enough that there's room to press it out.
    It would be easy if you had a press big enough for the hub to fit though the base.
  15. Jan 1, 2024 at 1:02 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    My 20 ton harbor freight did mine no problem. I think they were the originals with 500k. Just takes a bit to set it up on the press
    jubei and Squeaky Penguin like this.
  16. Jan 1, 2024 at 3:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah interesting
    Good to know.
    So setup is the issue. And tips?
  17. Jan 1, 2024 at 3:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is good to hear because I just bought an HF 20 ton to do this very job.
    Tacofire98[QUOTED] likes this.
  18. Jan 1, 2024 at 4:20 PM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Just have the appropriate diameter to press the bearing in. All my stuff was over the diameter of the over race. You can use the old bearing for most of it, it's just the last bit that gets tricky. Keep everything straight when pressing. I had the old stuff out and the new stuff in a morning. Wasn't too bad.
    jubei and Digiratus like this.
  19. Jan 1, 2024 at 7:55 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Since we are on the topic and this reminded me of a screenshot I took seen below…not sure how good it is but may be worth a shot for someone. Just another option.
    Blackdawg[QUOTED][OP] likes this.
  20. Jan 1, 2024 at 9:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oooo nice. Thanks for that. Cheap enough to give a try plus i have...4 others potentially to do lol
    TacoVio[QUOTED] and Speedytech7 like this.
