Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 13, 2024 at 9:27 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    No but I do see that they have a quick release that I can buy. Not cheap though, but probably worth it.
  2. Mar 13, 2024 at 9:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wait then how are you attaching your camera? Pretty much all tripods I know of come with a quick release.
  3. Mar 13, 2024 at 10:21 AM
    m3bassman
    Green truck
    It's a hard mount on top of the mono, think of it like a ski pole with a threaded stud at the top. I ordered the mount I posted, should allow vertical tilt and the quick release will be nice. Just pricey.
  4. Mar 13, 2024 at 10:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ohhhh it doesn't have a ball head on it. Gotcha.
  5. Mar 13, 2024 at 10:45 AM
    m3bassman
    Green truck
    No, I was hesitant about that after the tripod I had, no matter how hard I locked it down, it still liked to lean because of the weight of my gear. Looks like the mount I ordered only has movement in one axis so should be an issue.
  6. Mar 13, 2024 at 3:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah ball heads all have weight ratings. You can spend a LOT on a good ball head. Our best one we have is 5k alone. works nice though haha
  7. Mar 13, 2024 at 6:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well vibes are still happening. I did check the lugs and a handful where not at torque spec but not by much. Like barely a pull.
    So back to doing the u joint. Probably get a parts store one at this point just to get it done.
    m3bassman likes this.
  8. Mar 14, 2024 at 9:57 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Thanks for the heads up about his channel. I’ve been past that place many times but never had the opportunity to stop.
  9. Mar 14, 2024 at 7:47 PM
    m3bassman
    Green truck
    Quite happy with this shot from this evening. Starting to get the hang of this camera thing.
    SconnieHailer, jubei, turbodb and 3 others like this.
  10. Mar 14, 2024 at 7:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Very nice!
  11. Mar 16, 2024 at 4:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Went for a bit of a cruise. Explored a new area until snow turned us back. Looks like some good stuff to explore this summer for quick get aways.
    Vibe is still there. Definitely getting worse and really feel it in the back now. Confident it's u joints. Hopefully wheelers shipped them last week never got a confirmation.
    SconnieHailer likes this.
  12. Mar 16, 2024 at 4:25 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wheelers is trail gear now and everything comes from California and usually has terrible response time.
  13. Mar 16, 2024 at 5:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I know. So might through a parts store one in it. Always but the better one in later.
  14. Mar 16, 2024 at 7:28 PM
    m3bassman
    Green truck
    Disconnect your driveshaft. Isolate it.
    turbodb and Digiratus like this.
  15. Mar 16, 2024 at 7:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have a new u-jount I carry in the OSK for the position at the diff pinion if it comes to a trail fix. You are welcome to it if you need it.
    turbodb likes this.
  16. Mar 16, 2024 at 9:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I can try that tomorrow I suppose if I have time
    I sure hope not. Haha
  17. Mar 16, 2024 at 10:06 PM
    Speedytech7
    Would it even be a trip with Monte if his vehicle showed up ready for it?
    Squeaky Penguin likes this.
  18. Mar 17, 2024 at 1:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean no.
  19. Mar 17, 2024 at 9:05 PM
    m3bassman
    Green truck
    Working through some photos from a shoot I did today for a cars&bids auction. Pretty happy so far, certainly have a lot to learn still but great practice. The spot I chose was really neat, although a bit noisy, but the 24-105 lens is impressive.
  20. Mar 17, 2024 at 9:07 PM
    Speedytech7
    That poor rear quarter haha, dude needed a basketball PDR job
