Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 2, 2024 at 8:45 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Oh yes I will try that, I thought you were saying that goes in the potatoes:laugh:
  2. Apr 2, 2024 at 8:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ah. no. That would be pretty strange.
    m3bassman[QUOTED] likes this.
  3. Apr 2, 2024 at 9:03 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Jensonbt and BossFoss like this.
  4. Apr 2, 2024 at 9:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know. It sounds weird. But it's awesome. Devin was very suspicious too and now loves it. You'll eat the whole box of strawberries haha
  5. Apr 2, 2024 at 9:24 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think Monte might have hit on the potential reasons for what happened.
    What kind of pan did you use? What kind of fat did you use? How big did you cut the pieces of potato?
    Bigger pieces of potato take longer to cook and it is harder to cook them uniformly. 1/2" or smaller if you can.
    I use olive oil for the flavoring, not butter. If you used butter, it might have contributed to the burning, especially if the heat was too high.
    Start by cooking the onions a bit in the oil. Not too long. Just til they turn translucent and a few might start to get a bit browned. Stir often.
    I keep the heat between low and medium. Low and slow and stir pretty often, especially after you start to see the potatoes start to turn brown. Use the spatula to flip the potatoes so the crispy side is moved to the top. This helps to get every piece crispy (as much as possible). I don't add salt until near the end of cooking. Salt to taste and check for doneness.
    It always seems to take longer than you think it should. Have I mentioned stir often?
    Speedytech7 likes this.
  6. Apr 2, 2024 at 9:42 AM
    m3bassman
    Green truck
    Butter may have been the issue. They were browning and not turning translucent at all so I added the potatoes. I did cast iron on lower heat and cut the potatoes to 1/4" size with a bit of seasoning. I'll have to try again. They weren't terrible but definitely missed the mark.
    Digiratus[QUOTED] likes this.
  7. Apr 2, 2024 at 9:50 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Hell Yeah. Keep at it. Try using a cooking oil instead and cook the onions a little less before adding the potatoes. Don't be afraid to change things up a bit. It takes practice to be a good cook.
  8. Apr 2, 2024 at 10:03 AM
    m3bassman
    Green truck
    Olive oil or should I try a different type?
  9. Apr 2, 2024 at 10:07 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Avocado oil has a higher smoke point if that helps
  10. Apr 2, 2024 at 10:09 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I use olive oil because I like the flavoring it adds. Some cooking oils are more neutral flavored but there are many choices out there. I do not use butter or cooking spray like Pam.
  11. Apr 2, 2024 at 10:35 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    You can also cook things separately to practice getting them "right" individually. You'll lose a bit of the flavor melding, but the way we've been teaching the kiddo (who can easily get sidetracked with "prep of the next thing") is:
    1. Get the onions ready; cook them until they are translucent but still have what you think is "a couple minutes" to be totally done. Remove from pan and set aside on plate.
    2. Get the potatoes ready; cook them until they are a nice golden brown.
    3. Dump the onions back in and cook for a few more minutes to brown up the onions and meld the flavors a bit.
    Also, never forget salt.
    m3bassman likes this.
  12. Apr 3, 2024 at 8:10 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Olive oil is the only cooking oil I'd use. The rest are poison.
    jubei likes this.
  13. Apr 4, 2024 at 4:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I still can't find the bolts I bought for the skids. Which normally isn't a big deal. Except I can find the allen bolt that I was using before anymore at the store. They don't have fine pitch in m12 or whatever it was I needed. So i need to find the bag of bolts...
    I found the bag that I bought the additional 2 bolts which I then put in the big with all the bolts. And now...poof.
  14. Apr 4, 2024 at 4:28 PM
    m3bassman
    Green truck
    You'll find them 5 minutes after you get new ones and everything installed.
    BossFoss and Speedytech7 like this.
  15. Apr 4, 2024 at 4:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    They are where you are assuming they are not. Right next to them will be the set of keys you can't find either.
  16. Apr 4, 2024 at 6:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ain't that the truth.
    I lost some keys?
  17. Apr 4, 2024 at 7:00 PM
    m3bassman
    Green truck
    Doubt it, they are probably locked in the truck.
    Jensonbt and Speedytech7 like this.
  18. Apr 4, 2024 at 7:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
  19. Apr 4, 2024 at 8:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh, i didn't loose them. They were in my bag which I knew they were. Plus the other key on the seat haha
  20. Apr 6, 2024 at 11:36 AM
    Digiratus
    Roaming the PNW
    The RedHead
