Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 23, 2024 at 10:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    True. Red head is forever.
    We aren't doing that this go around. I think Ben would poop himself if he rolled up on that in the van haha
    Waiting for the hydrogen engine swap haha
    Digiratus likes this.
  2. Apr 23, 2024 at 10:21 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Poop myself? I would just say no if it's too gnarly. And based on the campers filming us on the last trip my threshold for too sketchy isn't nearly as low as it should be.
  3. Apr 23, 2024 at 10:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It can go higher. Haha
  4. Apr 23, 2024 at 11:06 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I'm pretty sure the single channel radio Monte is talking about is not a hand held.
    Nothing wrong with dual band in a hand held. The main limitation is their antenna. You can't really go wrong with this one.
    https://www.amazon.com/Baofeng-UV-5R-136-174-400-480Mhz-1800mAh/dp/B074XPB313?th=1
    Speedytech7 likes this.
  5. Apr 23, 2024 at 12:30 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    monte, let me know when you have a rough route planned out for july haha
  6. Apr 23, 2024 at 1:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    This was my dads recomendation for a mobile station radio single band: https://theantennafarm.com/shop-by-...radios/vhf-radios/13312-alinco-dr-138t-detail
    He also offered to get it installed for you and tuned when you're out here if you wanted. You'd of course need an antenna. Which I'd recommend this guy: https://theantennafarm.com/shop-by-...field-tunable/6441-sti-co-mgnt-ft-niti-detail
    He said otherwise if you don't want the install just get a Baofeng, which he does not like. But for simple simplex should be fine. You obviously got to experiance the downfalls of it's antenna reception this last trip.
    Yeah I'll send you the Gaia map as I get it more honed in. I think I have your email, if not i'll PM you.
    IDtrucks[QUOTED] likes this.
  7. Apr 23, 2024 at 9:08 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    +1
    I used to switch off between that STI and the Diamond antenna, but I run the STI almost exclusively now.
    Pro:
    • You can't beat the flexibility, and it's nice not to worry when I'm going through trees.
    Con:
    • It's definitely not as good as the Diamond at Tx/Rx.
      --> This weakness is barely noticeable in the desert at "dirt" speeds (35mph and less) because it stays mostly vertical.
      --> It is noticeable at highway speeds ( yes, even my hwy speeds :wink: ) where the antenna lays down a bit, and of course, it's worst in mountainous/canyon-y terrain, since it just doesn't have the same gain.
  8. Apr 23, 2024 at 9:13 PM
    m3bassman
    Green truck
    Ah, I'm not looking for a hard mount setup, handheld worked great, just a simple thing to use as long as I can charge it. Haven't looked into why the inverter wouldn't kick in yet. Hell I haven't put fuel in it from our last gas stop even. Stopped by the van today and already blew out the steering stabilizer so need to get another one ordered up before the next trip.
    Speaking of Gaia, do you use the free version or the paid version?
  9. Apr 23, 2024 at 9:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Better to use uhf anyways in mountains and canyons. It bounces around more.
  10. Apr 23, 2024 at 9:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I paid for it. Only way you can offline download maps.
    But so far enjoying it a lot. Ive been planning the routes on my computers in the browsers. Just syncs with my phone. Downloading maps is super easy and fast. Map layers are really good too. Worth it I think.
  11. Apr 23, 2024 at 9:22 PM
    m3bassman
    Green truck
    Well if you say it's worth it, and even though I rarely trust your judgement, I just might look into buying it before the next trip. I know OnX is another big one these days and it's hard to decide where to throw the money.
  12. Apr 23, 2024 at 9:41 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I heard something interesting from a few people "in the know." OnX is a big (well-known) one because they have a huge marketing budget and are paying any "influencer" who will have them. However, in real world use, the Gaia maps are better, the app has more features, etc.
    One thing that is really nice with Gaia is the online map/web site. Creating tracks there (which I know you don't do as much as Monte or I, but still) is SO nice. Way nicer than Google My Maps even. And, once you create your route, it just syncs (including offline maps) with your device.
    Full disclosure: I still use BCN. Actually, I use a combination of BCN Pro (the old one), BCN XE (the new one), and Gaia as such:
    • Gaia (paid) - to create routes, which I then export to KML for Google Earth (since that's where I store my "master catalog." @mrs.turbodb runs this on her phone and downloads the routes+maps for each trip so she can poke around while we're driving. The maps are "great" from a detail perspective, and they are small since they are vector based - a few hundred MB for an entire trip!
    • BCN XE - this is what's displayed on my tablet on a trip. I like it because of the Accuterra Land Use maps, which have a very nice/good/visible public/private land use display, and the maps are generally "pretty good." Downside is that they are bitmap based, so downloads are enormous (20GB/trip).
    • BCN Pro - I use this on trips to record the actual tracks I run, one per day on the trail. BCN Pro is still the most stable of all the apps, and I want something stable to record an 8-hour long track. I don't download maps at all for this, since it's just recording in the background.
    Gaia has pretty regular 50% off sales, so you should wait for one of those if you can. We're paying $24.99/yr I think from a Black Friday or Christmas sale.
  13. Apr 23, 2024 at 9:44 PM
    Wahayes
    Wahayes Well-Known Member
    Will
    2017 tundra (sold) 2015 tacoma trd 1984 c10
    What up wyoming-ites lol I don't live here but I'm here all the time. I drive a semi on 80 from Cali to kimball, Nebraska every week. I live in utah. Actually in laramie at the moment :cheers:
    Blackdawg[OP] likes this.
  14. Apr 23, 2024 at 9:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What is the cost? Is it an annual subscription?
  15. Apr 23, 2024 at 9:53 PM
    Wahayes
    Will
    Yes it is , I have it too. I don't remember what is was before but I got a notice saying it's going up to 59.90 a year next re -up
    Digiratus[QUOTED] likes this.
  16. Apr 23, 2024 at 11:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's pretty great. Plus if you ahve it, I can share the trip with you and you can easily see it, it'll sync to your phone or whatever. And you can add whatever you want to the map too. The potential for collaboration is big.
    OnX charges you for a lot of map layers that Gaia just has. So I didn't see the cost benefit.
    Welcome!
    Most people in here aren't actually in Wyoming anymore haha we just hang here. i80 is no joke to drive though all the time.
    Annual $60 a year. That's what I did.
  17. Apr 24, 2024 at 7:08 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Of all people i figured you would be the one to do this, but have you tried/want to set up starlink? Or are you leaving your off grid trips off grid?
    YOURE ALL FAKE BUT MEEEEEEEEE
  18. Apr 24, 2024 at 7:23 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    In other news, we're back in KW after a trip to the dry tortugas, waiting for the next favorable wind to start heading back north. This was our furthest away point we are sailing this season. We ran out of time to make it to the bahamahs, so we have to wait until next winter for that. Wish we had more time in the dry tortugas, it was such an incredible place, but we electd to come back with easy conditions ahead of a week of big wind.
    BossFoss, ricphoto, jubei and 6 others like this.
  19. Apr 24, 2024 at 8:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Too bulky and expensive to be a roaming station. Plus, no one wants broadband out in the woods.
    Very cool. Glad it's been a great trip. Looks like it's been a great adventure.
  20. Apr 24, 2024 at 8:10 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    What Monte said, at least in part. The bulky bit doesn't bother me all that much (esp. with the flat starlink kit), but I don't need to be connected when I'm going to get away from the hustle and bustle anyway!
    Those are some amazing sailing shots. Man, that looks and sounds so awesome. Good on you guys for doing it!
