Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 16, 2024 at 8:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    So... For the Pryors... MTs or ATs
    The forecast indicates there will be intermittent rain in the area over the next week or so. I do not want to be 'that guy' that slides off the trail. :cookiemonster:
  2. May 16, 2024 at 9:11 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Just keep your locker off and you'll be fine. I'll be on my nittos so if you think your truck cants hand with ATs you should switch to MTs. :stirthepot:
  3. May 16, 2024 at 9:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Easy for you to say since you can't switch to MTs :luvya:
    edit: you are 'that guy' that I was referring to. :laugh:
  4. May 16, 2024 at 9:28 PM
    m3bassman
    Green truck
    Why can't I switch to MTs? You are confusing that with the same problem I have of not being able to switch to 35s... I refuse to cut the van even if nature is self cleaning on one corner.
    But I wouldn't be sure if the green truck is back on 35s before 2025. Been tempting now that the dream of making it an all out street truck is shattered.
    Jensonbt likes this.
  5. May 16, 2024 at 9:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I can switch between ATs and MTs with no cutting.
  6. May 16, 2024 at 9:50 PM
    m3bassman
    Green truck
    Same? What is your point? That you have parts stacked the corner?
  7. May 16, 2024 at 9:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes. I asked the question becaue I have the choice of switching.
  8. May 16, 2024 at 10:02 PM
    m3bassman
    Green truck
    Much like I have the option of camping out of the wind :p :evil: ordered the radio tonight. Oil change and steering parts are on the agenda this weekend, awning may not happen. Super pumped to see you guys again, should I bring eggs, chips and avocados?
  9. May 16, 2024 at 10:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Same. Yes on all three.
  10. May 16, 2024 at 10:27 PM
    m3bassman
    Green truck
    Will do :thumbsup: haven't heard from that new guy that was wanting to show.. hope he understands to bring a piece of breakfast with him for the final day.
  11. May 17, 2024 at 12:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No idea. Could be muddy. But I don't think it'll terrible. Not gonna be raining for days and snowing. Hopefully..
    Digiratus[QUOTED] likes this.
  12. May 17, 2024 at 8:38 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    first off, lmao. second, why are they shattered? what happened that I missed?
    ahh shucks. thats when things get fun!
  13. May 17, 2024 at 8:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    He has no garage anymore to build that LS.
  14. May 17, 2024 at 9:43 AM
    m3bassman
    Green truck
    Lost my house in the divorce... So no place to work. And I have no plans to buy a house to get that back on track. Did you really miss all that? I live in an apartment out in Nampa now :laugh:
  15. May 17, 2024 at 12:59 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    holy shit balls
    yes i missed all that! fuck bud! Im sorry to hear that!!
  16. May 17, 2024 at 1:05 PM
    m3bassman
    Green truck
    Haha ya, that all started back in October, finalized after the start of the New Year, sold the house by Valentine's day. Been an interesting last 6 months.
  17. May 18, 2024 at 5:08 PM
    m3bassman
    Green truck
    Picked up a pair of Baofeng UV-5VR radios with big batteries. Antennas aren't great but should work for my uses.
  18. May 18, 2024 at 8:57 PM
    m3bassman
    Green truck
    turbodb likes this.
  19. May 18, 2024 at 10:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That shit is crazy. I've driven all those roads hundreds of times but never at 80+ It is very difficult to outrun a helicopter.
  20. May 18, 2024 at 10:06 PM
    m3bassman
    Green truck
    I recognized a few of the roads. King county air support has some interesting videos. The chopper sure seems impossible to outrun.
