Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 31, 2024 at 4:52 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I want more power not less!
    Mine get noisy above 70mph. I don't recall the noise from the cooper's. I do think they are a better tire than the st maxx. I agree with @Blackdawg about them being softer also. They are E. I think they come one a D range 35x 10.5x 17. You wanted taller right?! :D
    The also have a 33x9.5x15. Might end up with a set for my T100.
  2. May 31, 2024 at 9:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    33x9.5r15? Hm nice. 33s might be a bad idea though for my daily. I don't need worse mileage haha
    Mine don't seem too noisey at 80mph. Not louder than just the wind noise. But also hard to say. Not like my truck has any sound treatment in it.
  3. May 31, 2024 at 10:49 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How noisy is noisy? Do they howl like some MTs do when they get a few miles on them? Or is it more like a mild hum that you start to notice more as the speeds get higher?
    I've become less concerned about the load rating and more concerned with the weight of the tire. E rated tires are not always heavier than their C counterparts.
  4. May 31, 2024 at 11:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hm I've never noticed that. Can't say I've looked at that before. One would assume E's would always be heavier though, unless the size of the tire is bigger.
  5. May 31, 2024 at 12:45 PM
    Reh5108
    Idaho
    I wouldn't say it's super loud but I struggle to hear what my daughter is saying sometimes. My hearing sucks as is though. I'd describe it as in between the hum and howl. I only notice it above 70 or 75 mph. I have 20k on them.
    I had meant to download a sound meter app on my trip but never did.
    Digiratus[QUOTED] likes this.
  6. May 31, 2024 at 2:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My only evidence is from the Falkan website. They offer their 285/70r17 AT3W tires in 3 ratings, SL, C and E. The C is 60.6# and the E is 58.9#. The E is also a little wider and a little taller.
    https://www.falkentire.com/wildpeak/at3w#size-list
  7. Jun 1, 2024 at 6:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well Honda can officially suck a nut.
    Devins lca went bad very shortly after I replaced them. Well. Turns out the welded nut that holds the front mount down with a bolt broke off. Inside the subframe. No way to get to it it's full boxed in.
    So gutted everything and put a holesaw on it to hopefully get a wrench or socket on it to get the bolt out.
    Nope.
    It's not a nut. It's a sleeve.
    So probably have to replace the whole sub frame because in order to get a welder on it I'd have to hack so much of it away I'm not sure I can patch it up well enough.
    Either way. Gotta pull the sub frame to attempt it or replace.
    FML.
    m3bassman likes this.
  8. Jun 1, 2024 at 6:56 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Get that 4 door Tacoma you were talking about and fix it for her to drive
  9. Jun 1, 2024 at 7:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its pending. I had messaged the guy before that but someone got there first.
    Plus given she drives like 100+ miles a day the insight has been good.
  10. Jun 5, 2024 at 3:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hows the snow pack down there @BossFoss Looking at maybe trying to get to shoshone over July 4th weekend. Devin's never been.
  11. Jun 5, 2024 at 4:24 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    :spy:
    Blackdawg[QUOTED][OP] likes this.
  12. Jun 5, 2024 at 4:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Might want to put those skids on for that one.
  13. Jun 5, 2024 at 4:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    naturally.
  14. Jun 5, 2024 at 4:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not that they'll help all that much in a big hit.
  15. Jun 5, 2024 at 4:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's why he needs 35s, less big hits
  16. Jun 5, 2024 at 5:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That might help some. But slipping off a wet rock is pretty easy there. And with OEM skids, the belly is pretty exposed.
  17. Jun 5, 2024 at 5:02 PM
    Squeaky Penguin
    Brett
    I did that trail on 265s too. It'll be fine!
  18. Jun 5, 2024 at 5:22 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    I can't spit numbers at you but it was a mild winter compared to last year so I'm sure it will be open by the 4th of July
  19. Jun 5, 2024 at 5:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Meh. It's not that bad. Just the right line is needed. Not worried about it.
    Cool. Will plan on it for now. Be good to you guys and the kids too!
  20. Jun 5, 2024 at 6:02 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Stop in whenever, the band is playing in the parade on the 4th so won't be able to join you up there but can see you on either end of the trip
