Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 5, 2024 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    oh awesome! Glad to hear the band is still going!
  2. Jun 8, 2024 at 1:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not a bad looking bumper. Tho the swing out spindle does look lonely.
    turbodb and m3bassman like this.
  3. Jun 8, 2024 at 2:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Overhaul time?
    Digiratus[QUOTED] likes this.
  4. Jun 8, 2024 at 4:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The bearing at the top of the spidle failed on the last day of our trip. Ordered a new one, just waiting for it to get here.
    From the looks of this race, it had been failing for a while.
  5. Jun 8, 2024 at 9:32 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Any room for a zerk to grease that thing? Looks like it's had water intrusion for quite some time.
  6. Jun 8, 2024 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wowza
  7. Jun 14, 2024 at 11:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Speaking of blown shocks. One of my foxes looks like it gave up the ghost.
    Can't complain or be surprised as I think I've put 100k or more on them and not been all nice miles. Think my dad has a nitro kit still so hopefully just rebuild both. Front are probably over due as well.
    On top of that. One of my either lower spherical bearings is dead already or the bolt is shit or something. Was going to go camping today but was checking play while swapping tire and now won't be.
    So new lower bolt or something needs done and ITRe and I've got new upper ball joints too.
    Woooooohoooo
  8. Jun 14, 2024 at 11:41 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Speaking of, working to get some custom valved shocks for the van in the next month. We will see if that helps things a bit.
    Blackdawg[OP] and Digiratus like this.
  9. Jun 14, 2024 at 11:48 AM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Jun 14, 2024 at 7:56 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Broke a rear leaf in little red so just upgraded to some OMEs. Turns out my shocks were blown as well but I always overload the back with supplies while working. More surprised it did as well as it did being used hard everyday
  11. Jun 14, 2024 at 9:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oooo cool! That sounds fun.
    I did get those this go around. I didn't tear it apart today but will tomorrow or Sunday and see what's actually causing the play. The other side is tight as can be. I think I replaced them either this winter or last fall or something. Pretty recent.
    I like how we both overload our single cabs regularly hahaha
    I redid my single cab suspension after I split a leaf spring and new I'd be hauling water with it. I did 5100s though.
  12. Jun 17, 2024 at 7:49 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i have a good freind getting married in jackson 7/21....might change plans slightly for joining for that leg of the trip. Will have to check w/ the ol boss man and see what time I can take during that week, since i can't use the weekend to get there/start the trip
    Blackdawg[OP] likes this.
  13. Jun 17, 2024 at 8:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just video conference to the wedding.
    Be like this guy
  14. Jun 18, 2024 at 11:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks like GFC made a some big upgrades to their camper. Looks nice.
    Dan, Brett, and Brett you guys will be able to get upgrade kits next month for various things. That's also cool.
    drr likes this.
  15. Jun 18, 2024 at 12:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Does look like some nice upgrades.
    We'll see how many are applicable to my old V1.
  16. Jun 18, 2024 at 1:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well id hope the mattress and the tent would be. But who knows I suppose. I think Brett(lander)'s is also a v1 too.
  17. Jun 18, 2024 at 3:59 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Would like an upgraded tent, but damn $1k for the fabric
  18. Jun 18, 2024 at 4:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ouch.
  19. Jun 18, 2024 at 7:43 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Sold mine to a kid in Casper a couple months ago, we used it twice in 4 years, it was time to pass it along
  20. Jun 18, 2024 at 8:49 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Rig rats gotta have some privacy
