Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 28, 2024 at 1:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Revolving at all?
  2. Jun 28, 2024 at 1:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No. No need really. They have been pretty good the way they are. These have the compression adjusters on the resi too so that's good for tuning for conditions.
  3. Jun 28, 2024 at 5:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool. Just curious
    Also looks like I'm about to get the cheapest reheat if all time. $400 for some OEM diffs with 4.56 ratio. 171k on them.
    Digiratus likes this.
  4. Jun 29, 2024 at 9:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That's a whole frame with suspension, diffs and axles? Hopefully they are in good shape.
    And CO rebuild went pretty smoothly and are back on the truck. Feeling like they did when new again.
  5. Jun 29, 2024 at 12:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Excellent! I need to do that to mine. All 4 corners.
    Nah the frame was a rusted out shit mess. Everything was but the diffs looked okay and just need paint probably. Plus I didn't want to deal with the frame so just offered $400 for the diffs and he agreed. So should have it regear sometime! Picking them up on Sunday. Not sure when I'd install them.
  6. Jun 29, 2024 at 6:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    A little better than I was expecting.
    m3bassman and Blackdawg[OP] like this.
  7. Jun 29, 2024 at 8:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Me too! I thought you'd be in the 230s. pretty good. Needs a 2.1 pulley now.
    Speedytech7 likes this.
  8. Jun 29, 2024 at 9:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It was a good day for both of us, came in at 345hp and 414lb ft of torque.
  9. Jun 29, 2024 at 9:03 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    12.4psi? You had it turned up!
    Speedytech7[QUOTED] likes this.
  10. Jun 29, 2024 at 9:04 PM
    Speedytech7
    And I left it turned up, Jayson and I worked on the tune a bit and it is just smooth and powerful now. We actually figured out a pound of boost is good for 12hp on my truck. My first pull on 11.5psi was 333hp
  11. Jun 29, 2024 at 9:13 PM
    Speedytech7
    turbodb and Blackdawg[OP] like this.
  12. Jun 29, 2024 at 9:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My guess was 220-230 going in. So 240 was a pleasant surprise.
    turbodb and Speedytech7 like this.
  13. Jun 29, 2024 at 9:37 PM
    Speedytech7
  14. Jun 29, 2024 at 10:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dude wow haha that's amazing. Turbo ftw
  15. Jun 29, 2024 at 10:31 PM
    Speedytech7
    Thanks! It was a very pleasant surprise. I believe it has more in it easily too but we stopped since it already surpassed expectations and was still relatively unstressed.
    Blackdawg[QUOTED][OP] likes this.
  16. Jun 29, 2024 at 10:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    agreed! Haltech paying off.
  17. Jun 29, 2024 at 10:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The haltech is a game changer. I will post a better iteration of the graph when I get it but take a look at the ramp up for the horsepower and the flat curve for the torque. That is all haltech.
  18. Jun 30, 2024 at 12:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty bad ass. Also pretty inline with most other turbo builds I've seen.
    Almost double stock hp haha
    Can't wait to do that to my single cab, be a riot.
    The 5vz has a very flat torque curve from factory honestly. So not too suprising to see that, just more. Be cool to see the graph to compare more closely with Zanes.
  19. Jun 30, 2024 at 12:42 AM
    m3bassman
    Green truck
    We really missed the opportunity to compare to the ancient URD system to see the true gains of the haltech.
    Went up one of my favorite spots that is just under 2 hours from home as today was upper 90s in the valley. Haven't got the new shocks on the van yet sadly, but it made it. Popped out of 4lo about ten times going up, but it still made it. Need to plan an overnight up there soon, such an awesome place.
    Blackdawg[OP] likes this.
  20. Jun 30, 2024 at 12:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks awesome.
    We didn't go anywhere but planning on Shoshone Lake next weekend.
    I built a solar array for a pump to water my trees in the back of my property.
