Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 10, 2024 at 10:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    More in than out when you're behind that thing
    Blackdawg[QUOTED][OP] likes this.
  2. Jul 10, 2024 at 10:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    probably true haha
  3. Jul 10, 2024 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I live in western Wa so I know traffic. And I have both, neither is advantageous in that setting. However, the auto is way better on the trail. :stirthepot:
  4. Jul 10, 2024 at 10:24 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Ill be there for sure, just shot myself in the foot a bit.
    and stop making fun of Mike, he likes getting high on the diesel fumes...
    At least im TRYING to solve it with ne suspension! All my other trips the van is damn near perfect, only does it have short comings around you lot. :laugh: last weekend it was 98* and i was laid out on the couch taking a nap enjoying ice cold AC. If i could afford to build the tacoma back up to fuck around with you guys and my van for my personal trips, i would, but i cant so yall just are gonna have to slow down and smell the roses. well except for Mike, who is smelling diesel fumes.
    Digiratus likes this.
  5. Jul 10, 2024 at 10:29 PM
    Speedytech7
    Do you have to idle the engine to run the AC or does it have a separate AC for when you're chilling at camp?
  6. Jul 10, 2024 at 10:33 PM
    Speedytech7
    I'm tired, I did entirely too much today and I've been sweating for like 13hrs straight.
  7. Jul 10, 2024 at 10:33 PM
    m3bassman
    Green truck
    I just idled it. There is a secondary ac system I've disabled, you need shore power to run it. The engines thirsty though, I had several hours of idle time and it dropped my avg down to 10mpgs. But to be cool and out of the sun with Venice, it's worth it.
  8. Jul 10, 2024 at 10:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh pros n cons. I was both happy to have an auto and not at Shoshone Lake. My tranny kept overheating and had to stop several time to let the temps get down. Hoping that was mainly due to the shroud not being installed. But didn't help we were doing like 1mph and it was very steep and rocky.
    I like both. But I still miss the manual usually, its just more fun.
    :itllbuffout:
    Im sure the new shocks will help...but not make it faster haha At some point you'll cave and the tacoma will be back. I know it. Not now. But eventually...
    Shower and go to bed man!
    Definitely worth it in that context.
  9. Jul 10, 2024 at 11:02 PM
    m3bassman
    Green truck
    I mean I have fought off the thought that my shocks are in my storage unit, I could throw them back in, but new leafs and 35s and ground tent it... But moneys get in the way. Can I borrow 5k to get it where it needs to be?
    It's certainly nicer now than it's ever been as a solo traveler. Hot, cold, it works out great having a literal room to hide in that's temperature controlled.
  10. Jul 10, 2024 at 11:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The regear will go a long way to helping with that. The tall tires are a big help in the rocks and a hindrance because it takes more to pop up outa that hole and get rolling. Are you running a trans cooler?
  11. Jul 10, 2024 at 11:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Like i said..eventually. ;)
    Yeah for sure. Definitely pros to it.
    I do have a cooler. Which I need to fix the mounts for, noticed today one has come off when I put my fan shroud on this evening. But have had it a while. Seems to have been seeping a while too so I'll check the fluid levels as well.
    Regear will certainly help. Probably won't get that done before the trip. Not if it stays this hot anyways.
  12. Jul 11, 2024 at 12:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Monte, what is your plan for arriving at Crackerville or Fairmont Hot Spring? What day and time?
  13. Jul 11, 2024 at 12:40 PM
    Speedytech7
    This name is far too midwestern to be in MT
  14. Jul 11, 2024 at 12:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Saturday meet at Fairmount springs. Around 12-1 seem okay?
  15. Jul 11, 2024 at 1:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, that is fine with me. Does that mean that somebody has to work on Friday?
    @Speedytech7 Do you have to work half day on Friday the 19th?
  16. Jul 11, 2024 at 2:00 PM
    Speedytech7
    Yes
  17. Jul 11, 2024 at 2:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also fair warning but doesn't look like there is gas there. So fill up in Anaconda or somewhere "near" by.
  18. Jul 11, 2024 at 4:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ooof. Not looking good for Morrison to reopen any time soon. Was supposedly going to start work this year but due to staff shortages and funds it's not going anywhere.
    That's 2 iconic trails this month in my area shut down for the foreseeable future. Damn.
  19. Jul 11, 2024 at 4:48 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Man, so much easier to do both leafs at the same time.
    Blackdawg[OP] and SconnieHailer like this.
  20. Jul 11, 2024 at 5:38 PM
    m3bassman
    Green truck
    Doesn't really surprise me. From the pictures it needed a lot of work. Spending a bunch of money with no ROI seemed like a stretch for the govt to do in the first place.
