Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 29, 2024 at 9:11 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That ones even better really if it works out for you
    turbodb[QUOTED] likes this.
  2. Aug 29, 2024 at 11:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well if it doesn't work for you I'll take the parts and see if it works on my 95 haha
  3. Aug 29, 2024 at 11:52 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    From my research, and what was posted on the pirate thread and a couple on custom tacos, it was the pre-Tacoma r150’s (behind a 3VZ) that were incompatible with the r452 Dyna parts. Any Tacoma 5vz-r150 combination should be fine.
    turbodb likes this.
  4. Aug 29, 2024 at 2:16 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    How much does the brand of wheel spacers matter? I'm looking for 1" (which I think is the minimum w/o messing with the existing studs), and I found a couple on amazon + Trail Gear (from Summit). Naturally, the trail gear are 3x the price, but they are all speced similarly.
  5. Aug 29, 2024 at 2:18 PM
    Speedytech7
    I don't know that it actually matters, they may come from the same place... But Bora and Spidertrax have good reputation
  6. Aug 29, 2024 at 3:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine were from Allpro. I kind of doubt it matters that much. But then again could cheap out on the studs or the aluminum too so.. :notsure:
  7. Aug 29, 2024 at 3:43 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Thx.
    Spidertrax only has 1.25" and thicker (that I can find).
    Bora does have 1". Bora is also pricey (US made which is nice...even if it doesn't/shouldn't technically matter). Apparently, they also have any size I want, and I'd probably go with 1/2" if that didn't mean mucking around with the studs.
    Maybe I should just bite the bullet on the studs though, since I hate mud and it seems like fewer points of failure...
  8. Aug 29, 2024 at 5:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not sure if is still true or not, but in the past I've read that some tire shops will not work on a rig that has wheel spacers. YMMV.
  9. Aug 29, 2024 at 8:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The only "downside" supposedly is potentially more wear on wheel bearings.
    Idk if that's true or not. And if you torque right and use the et thread lugs to mount the spacers you'll never have issues.
    I'll put it this way.
    I ripped the entire front wheel/spindle/everything off....twice...with spacers on. And they were fine.
    Doubt you'll even tweak em out any more.
    1" will look good I bet!
  10. Aug 30, 2024 at 6:05 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    The truck is in it's new home, Albuquerque. Long freaking couple days...
    TacoVio, BossFoss, turbodb and 3 others like this.
  11. Aug 30, 2024 at 9:14 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice! Glad you made it!
  12. Aug 30, 2024 at 12:01 PM
    m3bassman
    Green truck
    Besides sleeping the van outside the apartment all has gone well today. Vans in storage, everything is moved in, now to unpack...
    Blackdawg[QUOTED][OP] likes this.
  13. Aug 30, 2024 at 4:48 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Wow, big move. We actually just moved away from New Mexico in June. Quite a bit of exploring opportunities in the state and I think you’ll be surprised how much there is. I’m already kind of missing how “empty” the state felt regarding people.
  14. Aug 30, 2024 at 5:41 PM
    m3bassman
    Green truck
    We're you in Albuquerque by chance? I may pick your brain in a PM for some places to start. Lots of nothingness out of town here. I like it.
  15. Aug 30, 2024 at 5:54 PM
    PcBuilder14
    Brent
    Nor Cal
    Nah, down in Alamogordo beside White Sands National Park. But, we did take a few trips North of Albuquerque. The Jemez Mountains and Tres Piedras district of the Carson National Forest can be pretty empty, even on holiday weekends.
    Also, Los Alamos is 100% worth a visit if the birth of nuclear weapons is of any interest. Tons of history and interesting stories, especially if you stop and talk to the locals.
  16. Aug 30, 2024 at 6:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Where did you go to?
  17. Aug 30, 2024 at 7:01 PM
    m3bassman
    Green truck
    I'll have to check those out. Getting a piece of trininite would be so cool.
  18. Aug 31, 2024 at 12:22 PM
    PcBuilder14
    Brent
    Nor Cal
    We moved to Northern California, near Sacramento. I'm still in the military. It's nice to be somewhere green with water, but it feels a little crowded. I can make due for 4-8 years, though. I've always wanted to attempt the Rubicon at least once, so now's the perfect opportunity living 2.5 hours from the trailhead.
    If you want to tour the Trinity site, it's limited. Something I regret never getting around to doing.
    Trinity Site Open House :: White Sands Missile Range (army.mil)
  19. Sep 1, 2024 at 8:48 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Just did like a 7mo catchup on the thread, still alive still in the DUB, if anyone passes through and wants some recs hit me up. Still looking for another 4th gen 4Runner with a V8 under a million bucks, if anyone comes across one please share.
    SconnieHailer and m3bassman like this.
  20. Sep 1, 2024 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    will keep my eye out!
