Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 20, 2024 at 7:57 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Millirem (mrem) is the correct unit for the US...more so the DoD and some of DoE. Sieverts are the unit the rest of the world uses lol. Anything under 1 Mr/hr is pretty much written off as "indistinguishable from background levels" for the Navy (and I'd assume most other US agencies but I only know navy for sure)
    Still a cool place to have gotten to visit!
    m3bassman[QUOTED] likes this.
  2. Oct 20, 2024 at 12:43 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I figured someone smarter than me would chime in. I just read the signs :laugh: still it's similar to background levels for a one hour visit, a longer stay would obviously be more exposure.
  3. Oct 20, 2024 at 12:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Don't eat the dirt and you'll be fine
  4. Oct 20, 2024 at 1:42 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    On the way to Zanes, and then on the way home. 5th gear swap went off without a hitch I'd say. I can't say that my bed was the same way, but the bed definitely went back on in a much better state than it came off!
    Thanks Zane and Jayson!
    @Speedytech7
    @2RZNoShi1
  5. Oct 20, 2024 at 2:59 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Lol well I used to work on the Navy's reactors so do know a thing or two on it.
  6. Oct 20, 2024 at 2:59 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Nice! Glad you got it to work - enjoy your new 6th gear. I’ll be curious to hear what your thoughts are driving up the pass or if it’ll be mainly for flat ground driving.
    turbodb[QUOTED] and Speedytech7 like this.
  7. Oct 20, 2024 at 4:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Awesome! Glad it worked. Now I need to do it to mine..
    Yeah do you find yourself having to use 4th for most hills now? Or is the gearing still good enough?
    You're sitting now right where torque lock up in the auto is. Which of course is pretty much only good for flat ground and mild inclines.
  8. Oct 20, 2024 at 6:18 PM
    m3bassman
    Green truck
    It'll be interesting what you experience. I assume this was done in an effort to improve fuel economy. I think the big question is if you are able to maintain speed in string headwinds and small inclines. If not and you find yourself going to 4th to do so, since you shifted the rpm out of the power band, it might be a wash.
    turbodb and Digiratus like this.
  9. Oct 20, 2024 at 6:54 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I know you checked mpg, did it change?
    turbodb[QUOTED] likes this.
  10. Oct 20, 2024 at 9:04 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    There were only a couple times I needed to downshift on the way home, and not for very long. Obviously, for folks who generally travel at faster speeds - like in the 68-75mph range, that would be less of an issue.
    My plan though, was that this was largely for flats - the long trips up/down to California.
    Also - the shift keys - it was the long ones (the original ones you bought) that we needed to use. Was nice to have both Zane and I there, so we could talk through the entire setup together and bench assemble until we felt like it was good, before putting it into the truck. (which we did with the trans still installed).
    Yeah, we'll see how it goes. Was really great on flats. I was telling Zane that I'm so used to the sound of the engine at 2750rpm that it sounded like I wasn't going fast enough with the new gear, and I often found myself going much faster since I was subconsciously driving by sound rather than speed.
    Had a pretty good headwind last night and it wasn't an issue. Time will tell.
    I didn't check mpg (in any measurable way) on the way home for two reasons:
    1. It's less than a tank of gas to get home (or, about a tank). You can never really tell on a single tank, though I do get a kick out of guys who are like, "look, I got 32mpg," and then you found out they drove 12 miles. hahaha.
    2. The first half of the way home, I was on fuel from the tank that got me there. I did fill up a couple hundred miles from home, so I'm now on the first full tank with the new gears. I'm planning to drive down to Vegas at the end of the month, so that'll be the real test. 3-4 tanks to get down there.
    All that said, it looks to me - from the (oh-so-accurate ;) ) fuel gauge - like about 5-10% improvement. Ironically, I think I lost about the same amount with the new wheel/tire combo, and I don't have a ton of data with that combo, so knowing all this "for sure" is going to be a bit tough. This upcoming trip will be telling. Does make me wish I still had the old wheels/tires, though. Just to see.
    Reh5108[QUOTED] and drr[QUOTED] like this.
  11. Oct 20, 2024 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool to hear. I suspect it'll be amazing for Frank. For my daily. Debatable given it's on 4.30s and 31s. Pretty cool!
    Also I suspect not a massive change in mpg. It's below the engine peak torque and p no where near it's peak power anymore. So it'll work more under the load. But it'll still be better than doing 3000rpm. Hell I bet actually you'll see better mpg at faster speeds now. Whatever 2500ish rpm is now.
  12. Oct 20, 2024 at 9:50 PM
    Speedytech7
    I mean it would be ideal if he got his old MPG moving at speeds people actually use on the highway. I'm still amazed he hasn't gotten road raged entirely off the road in California or Nevada or Arizona, I'm pretty sure you can still get the death penalty in two of those states for going under 70 on a highway
  13. Oct 20, 2024 at 10:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah we can only hope that 75-80 will now be acceptable.
  14. Oct 21, 2024 at 9:02 PM
    m3bassman
    Green truck
    @Digiratus found a strong IPA but definitely not enough flavor for you, but the name alone was too funny not to share.
  15. Oct 21, 2024 at 9:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Beep-Beep!
  16. Oct 22, 2024 at 7:07 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Tundra V8 DC 1st gen
    SconnieHailer likes this.
  17. Oct 22, 2024 at 7:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow nicely done I must say. Pretty decent price too.
  18. Oct 22, 2024 at 7:42 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah not bad, some quirks to work with but reasonably priced considering stock ones are in that 10-15k price range
  19. Oct 22, 2024 at 11:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah I think thats a decent price all things considered. Reinforce the frame and it'd probably tow as good as a tundra too.
  20. Oct 22, 2024 at 11:04 PM
    Speedytech7
    The bird kind of looks like Mr horsepower if his parents were cousins.
