Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 29, 2024 at 7:22 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Good choice haha, the std ones are even shorter than I described haha. Ext travel is about .5" over stock with them vs 1.75 with every other CO brand. The out of box tune likely won't impress you, but thankfully everyone and their mom tunes Kings so you should be good. Someone in NM does that locally I'm sure.
    I'm curious though, is the price that good compared to other options? I mean King is good if you're getting custom COs and shocks and tuning them, but like I wouldn't ever use their stock application options just because they're proven to be lacking, what's motivating this choice?
    Digiratus likes this.
  2. Oct 29, 2024 at 7:25 AM
    Speedytech7
    for sure haha, that's an easy fix at least on both ends. Your icons can be tuned and resprung with 600s or 650s for less than new kings though. And they have more usable shaft travel
  3. Oct 29, 2024 at 7:29 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I know what you mean since i swapped to 63s as well. I ordered my rears from accutune and feel there may be not enough compression valving as well. Im sure they work good with regular 1st gen lift leaf packs but are undervalved with 63s. May send em in for my free revalve. Currently reworking my tent setup again to something lighter though so I my wait to see what loaded weight looks/feels like before jumping to a revalve.
  4. Oct 29, 2024 at 7:30 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Like I said I remember how smooth my friends second gen was after we put kings in his second gen. If I remember it was the difference between digressive vs progressive valving? I need something softer so my mind is running to that.
    And probably because I've just thought kings were cool, and I'm fitting logic to around the emotional want.
  5. Oct 29, 2024 at 7:32 AM
    m3bassman
    Green truck
    Maybe that's something I can do if the kings don't fit the bill. Not having a garage/backup car really complicated things when I'm too stubborn to take it to a shop to do the work for me.
  6. Oct 29, 2024 at 7:34 AM
    Speedytech7
    2nd gens suspension is pretty different and they got the benefit of Kings R&D department learning too, our stock application valving has been shipping with the same tune since 2006 though and it reportedly can be made good (like any CO) but out of the box is not so much. The Icons are digressive, but like anything else that can be tuned around, actually @Bandido did it recently. You're also way oversprung so 700# combined with digressive valving isn't exactly a good combo.
    m3bassman[QUOTED] likes this.
  7. Oct 29, 2024 at 7:36 AM
    Speedytech7
    Fair, I still think they're cool, so I just bought a set of 2.5x14 adjustable resi shocks for my new* rear setup
    *setup still very much a work in progress
  8. Oct 29, 2024 at 7:52 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    My recommendation would be not to rush here. Everything in the "overlanding" is going to be "on sale" in exactly 1 month for BF.
  9. Oct 29, 2024 at 8:18 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I've been changing the valving pretty often since 2020 actually, pretty pleased with the current ride...
    Looking back thru the messages I agree with most of what Zane has said.
    Elka - bad - they have some really trick stuff at the top end of their lineup (magnesium housings, 4-way adjustability), but the bottom end (probably what you would buy) is lower quality than similarly priced king/fox/ads
    Kings - to me these are just the basic progressive shock now, I know the TC crew love to use them, and their package on the 4g was awesome, depending on whose package you buy you will get a different product
    ADS - also basic progressive shocks but with an internal top-out bumper - never ran a set on a 1g but loved them on a 3g
    Fox - they have some of the best tech available, but the basic packages are still just a basic progressive shock, but with more robust seals than kings come with typically, DSC is an excellent add-on imo
    Icon - I bought into the digressive valving hype back in 2014 or so, definitely its more annoying than anything, it makes the handling feel good, and the big hits feel OK, but the washboard/small stuff is extra bad... but if you already own these, just revalve and roll with it. 600# 14" springs will work great even with bumper/winch
    Speedytech7[QUOTED] likes this.
  10. Oct 29, 2024 at 8:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can 100% get any size you want with stock mounts. You just need to call them. They build in house and ship direct. Or contact a rep that actually is good like MCM.
    Who the hell is that?
    Do you have plans for a winch? if so I'd go for 650s, they ride good if you're not cranking them down for lots of lift.
    Is it stink bug now?
    No idea about de arcing, pulling a leaf seems much easier.
  11. Oct 29, 2024 at 8:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Don't think thats just the shocks. The suspension geometry in a 2nd is FAR better than our 1st gens. They inherently ride MUCH smoother.
  12. Oct 29, 2024 at 9:04 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    My experience with Kings COs was not good. Yeah, they are pretty...for a while. But in the long run that matters little. Their main issue IMO is they are too short. Even the extended version is too short. They will become your limit strap.
    And I originally thought the valving was ok and the ride was good. Now, looking back and after having the ADS, I just didn't know any better.
  13. Oct 29, 2024 at 9:18 AM
    Digiratus
    Roaming the PNW
    The RedHead
    This is good advice. Same advice you gave me and I am glad I listened. Matt is a good guy and great to work with.
  14. Oct 29, 2024 at 10:02 AM
    m3bassman
    Green truck
    That's a good point.
    What do you mean by whose package? I was looking at wheelers and headstrong, part numbers are the same, I would assume they are the same.
    And on paper it seems easy enough to put new coils on the icons and have them retuned. In practice, I can't have the truck inop for any period since it is my only vehicle. A bolt in project is easier to do in the street which is all I have. Buuuut once the icons are off and the kings on I can always have them rebuilt and try them out later. But you are right the ride is annoying, it wasn't bad when my truck was heavy on 35s. The solution was always to go faster to go smoother, but sometimes I don't want to do that :laugh:
    It's me! I am just teasing, since I moved to NM I stopped going by Ben.
    No plans for a winch, or skids, or sliders, so the 600s should be right on the money, if a bit soft for no sway bar.
    Stance now is perfect but when the front drops with a new coilovers, it will stink bug, and it is too tall for most of the shelf rear shocks.
  15. Oct 29, 2024 at 10:14 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I understand that King themselves have a base valving and shock dimension(this is whats sold wholesale to distributors), Accutune will ship different valving sets on request, Total Chaos also has their own valving in the same dimension shock as King.
  16. Oct 29, 2024 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Parker eh? alrighty then haha
    Yea 600s should be fine. Thats what My Kings had when Igor was stock heigh still. Was fine.
    Looks like another leaf could come out then. Easy enough to do
  17. Oct 29, 2024 at 10:29 AM
    Speedytech7
    Don't encourage him
  18. Oct 29, 2024 at 10:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean IDGAF whatever he wants haha
    BossFoss likes this.
  19. Oct 29, 2024 at 6:00 PM
    m3bassman
    Green truck
    Why are you so offended by me going by my middle name?
    Y'all can call me either way, was just messing with you. Been very good to have a fresh start on a lot of things, name change a big one. Always liked my middle name more but never had the courage to change until this year.
  20. Oct 29, 2024 at 6:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ahhh middle name. Cool. I have a good musician friend who's name is Parker haha I could need go by my middle name.
    But whatever you want. I don't mind. I'm sure it's been a great fresh start.
