Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 21, 2024 at 1:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    power is back on.yeah.
    And the tree has been taken down.
  2. Nov 21, 2024 at 1:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'll get the ladder out here in a little bit and see if I can take a closer look at the condition of the roof.
  3. Nov 21, 2024 at 1:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Amazing, looks like very little damage.
    Also jealous you have power back.
    Digiratus[QUOTED] likes this.
  4. Nov 21, 2024 at 1:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    it is a rarity when bview doesn't come out ahead of Kent. :luvya:
  5. Nov 21, 2024 at 3:43 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Roof looks like it survived well enough! Happy to see that. Those rounds are nearly perfect for firewood. I'm sure you can rent a lot splitter... Unless the arborist took the wood.
  6. Nov 21, 2024 at 6:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I can't see any punctures. There are a few depression areas though. May have dodged a bullet.
  7. Nov 21, 2024 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    wow. Looks pretty unscathed! lucky!
    Speedytech7 likes this.
  8. Nov 21, 2024 at 10:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Nov 21, 2024 at 10:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Anyone have any good ideas on a studded snow tire to run? I was running cooper discovery M+S tires with studs and they were great. But no longer made.
    I'm half leaning at getting some Kenda RT tires and studding them. They just don't make a size that works great unless I get 17" wheels.
  10. Nov 22, 2024 at 5:35 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    A lot of the studded tires are off the market now because most states have restrictions or bans on them at this point.
  11. Nov 22, 2024 at 7:18 AM
    m3bassman
    Green truck
    For good reason....
  12. Nov 22, 2024 at 8:58 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Is it because they don't work? Or because they work too well and tear up the pavement?
    I've never run them myself. And don't think I ever would. Way too loud.
  13. Nov 22, 2024 at 9:40 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    IMO a good studless winter tire will outperform any studded tire.
    I miss my WRX with Yokohoma iceguards. That thing was unstoppable in the snow and ice. Volvo with Blizzaks wasn't far behind either.
    Digiratus, Reh5108 and Speedytech7 like this.
  14. Nov 22, 2024 at 10:07 AM
    m3bassman
    Green truck
    A couple pieces, one is tire chemistry, specifically rubber compounds have a come a long way int he last 30 years and can put perform age old studded tires. The other aspect is the damage to infrastructure. They absolutely eat through road surfaces. I will admit there are fring cases where they might have an advantage and be useful but those are only a couple days a season, and so for the rest of the time, from Oct to April (in Idaho) they are just doing damage.
  15. Nov 22, 2024 at 10:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The thing studs help with more than any tire compond is deep snow. They dig through hard pack drifts much better and if you have a semi agressive tire that cleans out better it just works better than a studless tire. I'll admit, most my driving Id be fine without studs. But the few times a year where I have to break out of work to get home, the studs are super important.
    I still only buy studded for devins car too.
  16. Nov 22, 2024 at 10:50 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    M+S tires can't hold a candle to a true winter tire.
    I have a set of studded winter tires and I can't say for certain if the studs are worth it or not. Once they wear down they turn to skates.
    Even 3peak rated tires vary considerably in performance. The ones on my Sequoia are pretty terrible in the snow despite the 3peak rating. Their tread is more of a passenger all terrain than what I would consider for a quality snow tire. I'll eventually find a cheap set of oem take offs for a winter tire and have a more aggressive all terrain for summer on it. Two sets of wheels is the way to go.
    I do live in an area where there is a ton of black ice so I wanted the studs.
  17. Nov 22, 2024 at 10:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I deal with ice a lot on the highways as the hills shadow the roads a lot so ice stays for a long time.
    I was impressed with the Kendas in the snow on my other truck. To the point that adding studs to them would make them a crazy good winter tire I think.
  18. Nov 22, 2024 at 12:02 PM
    m3bassman
    Green truck
    Studs are intended for ice, the thought is like the claws winter ice climbers use, they can dig into ice. Everywhere else, they serve no use. A dedicated winter studless tire is the way to go.
    I was shocked at how good the HT tires on the truck performed. Wouldn't have thought it by looking at them but during a snow storm last year I was driving circles around cars and trucks stuck in the road, tons of grip where trucks with ATs were stuck. Made me realize I don't know shit for tread design for snow :laugh:
  19. Nov 22, 2024 at 3:32 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  20. Nov 22, 2024 at 4:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well deal with plenty of ice. My "favorite" road condition is when a bit storm comes and plows run but it freezes and then snows again and they run again. So now the road is a smooth sheet of snow/ice the entire way. Then the sun comes out juuuuust a bit and melts the top layer down only for it to freeze again. Ice rink driving for everyone!
    Drat.
