Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 15, 2025 at 8:00 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Totally, I thought the weather was great last time. I just know that I'm going to be in a "let's be warm" mood is all I was saying.
    Funny about NPS, I had no idea they checked vehicles. Send them some pics from the Montana trip going through the trees and up that steep hill after we had to turn around, lol. Certainly as capable as Will's Tundra, and it's not like White Rim is all that technical anyway. Speaking of which, don't forget the fire extinguisher :rofl:.
  2. Jan 15, 2025 at 8:52 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Well thats the defining difference between the truck and the van. You're certainly more "in the elements" with the truck, it's harder to escape the cold, so I don't blame you. I was looking at the north rim but I am still waiting on some tracks from @Blackdawg ... But I saw white crack was open so I snagged it.
    Yeah there was a stink about it last year that the NPS was putting requirements on certain vehicles in certain areas. Rescued to many Subarus I suppose as they seem AWD not approved for certain areas even. I sent them a picture of it in the trail in Utah... And it resolved it instantly. There's only a couple spots that could be interesting. The initial climb up Murphy's hogback, I recall a bit of erosion there and it looked worse than it was. There's the overhang ledge on the north side of Murphy's that the NPS said has 10' clearance, which I am under but idk by how much, and then Shafer, if it's wet, might be interesting descending. Other than that I don't think there's anything in that trail that is an issue. Just pluck a long at my usual speed and enjoy the views.
    I dropped the van off for its Dr appointment... Can't remember if I posted it here but I'm doing a whole bunch of preventative stuff just to keep it reliable in the trail.
    Gas tank strap, one broke, replace both.
    Diff service F/R
    Trans service
    Coolant flush, rad hose replace, new t-stat
    Serpentine belt replace with idlers and tensioners
    Shift linkage adjustment
    Oil change
    Diag airbag light
    And for shits and giggles muffler delete.
    turbodb[QUOTED] likes this.
  3. Jan 15, 2025 at 10:02 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Highly recommend switching to Shell Rotella ELC in the van if they are doing a proper flush. If its not running ELC already.
    https://www.tractorsupply.com/tsc/p...6H5vT0W80AUzyJ2xE0JbxdvymYOZAEtMaAvXDEALw_wcB
  4. Jan 15, 2025 at 10:05 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I want to go back to the North Rim and Alstrom point this year. Your neck of the woods. But in early September. Save a week of your PTO for that if you can.
    turbodb likes this.
  5. Jan 15, 2025 at 10:39 AM
    m3bassman
    Green truck
    Good to know and keep in mind.
    And it is kinda in my neck of the woods, as much as Boise is in your neck of the woods ;)
  6. Jan 15, 2025 at 10:41 AM
    m3bassman
    Green truck
    TacoVio[QUOTED] likes this.
  7. Jan 15, 2025 at 11:30 AM
    Digiratus
    Roaming the PNW
    The RedHead
    No reason for me to go to Boise any longer. :evil:
    16 hours/1100+ miles to St George from my house. Northern AZ is your neck of the woods.
    m3bassman[QUOTED] likes this.
  8. Jan 15, 2025 at 11:47 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'm tempted. :spy:
    As many times as I've been to Moab, I still haven't done the White Rim.
    Not sure I'm ready to drive that slow, however. :p
  9. Jan 15, 2025 at 11:48 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Just take the bike, you'll still go faster and it'll be more fun anyway.
  10. Jan 15, 2025 at 11:49 AM
    Squeaky Penguin
    Brett
    I'd love to bike it, but I would want to do it over a couple more days.
  11. Jan 15, 2025 at 11:55 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Its not so bad if you're in front. Just go to the next campsite at your normal speed. You'll have plenty of time to relax with a few beers that way. :rofl:
  12. Jan 15, 2025 at 12:59 PM
    m3bassman
    Green truck
    :luvya: I think it'll be able to keep a modest pace. Plus it's not like there are long distances each day so it by design is a leisurely pace. Day one is 37 miles of dirt with a few stops along the way. Colorado overlooks(one hike, one drive), musselman arch, and whatever else is interesting. Day two is 29 miles of dirt with a couple stops as well, a hike to a big crack and a slot canyon. So not really a reason to rush unless you want to find some hiking along the way. Then out that Monday and possibly the hike out to the Fort Bottom Ruins time permitting.
    You are more than welcome to join though, just let me know so I can add to the permit.
  13. Jan 15, 2025 at 6:53 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    Years ago, my friends and I did white rim with 9 people, 9 mountain bikes and 2 Toyota trucks (we all took turns driving). we spent 4 days going counter clockwise on the trail. My bike rims were smoking by the time we got to the bottom near the Green River! I only recall one fairly technical spot for the trucks on our second day. it was a fairly large step that I ended up ejecting about a third of the bed contents in my truck, crawling up it. Obnoxious to clean up, but no real harm done. There was also a pretty long descent that I thought 4 low was very prudent to use.
    Have fun, folks!
    m3bassman likes this.
  14. Jan 15, 2025 at 8:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Oh yeah I forgot to look for that. Lol
    I'm working early Sept...:pout:
  15. Jan 15, 2025 at 8:49 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I gave Ben the KML. You're welcome, hahaha.
    The rain in Oct sucked, but I want to feel like it's not always that way...because the color on the trees was amazing. I'd want to go when we could experience that color again.
  16. Jan 15, 2025 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah nice. Cool.
    Oct would be when i could go. Well earliest is Sept 21st.
  17. Jan 15, 2025 at 9:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I've heard this music many times before. Maybe it is time for a new tune. Or maybe you guys should go when it's cold and rainy/snowy.
    Now that I think about it, maybe late August might be an even better option.
  18. Jan 15, 2025 at 9:48 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    To many "or"s; need more "and"s. As in, we should do a trip in August AND October, hahahaha!
    I mean, I am about to head down to Toroweap on Tuesday, so it's gonna be cold.
    Hopefully not snowy, that would throw a wrench in things. Apparently GCNP is now giving out hefty citations for driving on muddy roads.
  19. Jan 15, 2025 at 10:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    My concert season is Aug 4th - Sept 15th. Sorry man..
  20. Jan 15, 2025 at 10:51 PM
    m3bassman
    Green truck
    That's one thing about mild trails they can pull you into a sense of comfort and then hit you with a doosy without warning. @turbodb did the same thing when we ran f on a blizzard in the maze!
    It's ok. I only called and begged for them.
    Thank you!
