Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 7, 2025 at 7:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah idk. But would be a fun little car. Always wanted a small bmw. Awd is just cool.
    Have fun!
    m3bassman[QUOTED] likes this.
  2. Feb 7, 2025 at 7:24 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    My temp sensor wire isn't hooked up. It's the one that is for the dash. Guessing the one for the computer could have an effect on fueling though.
  3. Feb 7, 2025 at 7:54 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Nice! Interior looks pretty dang good.
    One day... I'll have a project car. Technically my truck is my project car I guess since I have a daily and the truck needs work ha. Love having three cars and the ability to have one go down and not be sol for a minute. That and they're all pretty easy to work on.
  4. Feb 7, 2025 at 8:10 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    No doubt that will happen. Parked off behind the rocks trail, tucked out of the wind. Faced a brutal wind here, moab was recording 23mph with gusts to 30+ but this spot was well sheltered and only a minor breeze. Saw dust storms in the distance. Winds drop, but so do temps tomorrow as we start the white rim.
  5. Feb 7, 2025 at 8:25 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Yeah this was the one up front, sender for the gauge is on the back. Person I got it from cut the cats out before letting it go and severed the O2 sensors in the process. It's funny that makes no difference in it being able to run, but a water temp sensor causes it to shut down.
  6. Feb 8, 2025 at 10:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Have fun my friend.
  7. Feb 8, 2025 at 11:56 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Welcome!
  8. Feb 8, 2025 at 12:44 PM
    Reh5108
    Idaho
    Rear o2s won't effect how it runs. They just monitor the catalyst. Front o2s would change things. On the 3rz the front sensor is the one for the dash would assume it'd be the same on the 3.4 but maybe it's not.
  9. Feb 8, 2025 at 12:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Front sensor on a 3.4 is for the computer The one all the way in the back by the firewall is for the gauge
    Reh5108[QUOTED] likes this.
  10. Feb 8, 2025 at 4:18 PM
    m3bassman
    Green truck
    White crack tonight. Sadly has cell service
  11. Feb 8, 2025 at 4:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup. Has for a while now. Don't worry, Potato Bottom won't.
  12. Feb 8, 2025 at 7:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks nice there! Freakin cold here and tons of snow now.
  13. Feb 9, 2025 at 5:37 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    SPC uppers what the cool kids run these days? Would like to get away from the hiem joints that I had with the camburgs back in the day.
    m3bassman likes this.
  14. Feb 9, 2025 at 5:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You had hiemed uppers?
    I'm kind of neutral towards them. I think the new ones aremt as serviceable. But not sure what other options are out there.
    If you're not wanting a uniball joint could look at icon delta joints. They can go into any uniball uca.
    Jba is also a thing for some folks.
    BossFoss[QUOTED] likes this.
  15. Feb 9, 2025 at 6:41 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    I thought that's what they were, but you are probably right.
  16. Feb 10, 2025 at 7:30 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Howdy; from Hopetown, Abacos Bahmahs
    turbodb, BossFoss, m3bassman and 3 others like this.
  17. Feb 10, 2025 at 9:06 AM
    Digiratus
    Roaming the PNW
    The RedHead
    You are definitely living that dream Dude.
  18. Feb 10, 2025 at 9:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah idk how you do it but well done! Always looks like you two are having fun on IG
  19. Feb 10, 2025 at 8:38 PM
    m3bassman
    Green truck
    Good. The trail has changed a bit, a couple VERY narrow spots for a full size but otherwise the trail is as amazing as it has ever been. Didn't realize it was super owl Sunday this weekend but dang we have the whole place to ours lives because of it, it's incredible. Slightly cold. Worth it.
    Late to the party but the SPC today are different than those of yester-year. It is why i asked what i did as they have changed things, the arms are cast and not tubular anymore. They have held up and always been friendly to alignments. The UBJ lasted me 60k miles and is still going. Sadly i cant comment on the new BJ design and will find out soon enough. The sealed UBJ seems like the way to go if you see mud enough.
  20. Feb 11, 2025 at 5:25 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Was mostly curious on the sealed BJ. It would be an upgrade to the Mrs. Vehicle and I don't want to have to keep up with what's going on since I dont drive it too often
