Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 20, 2014 at 9:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How you gonna do that??
  2. Oct 20, 2014 at 9:30 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    The problem is I have no way of learning how to drive a manual now. Unless I go to a dealer and tear up a brand new car....
  3. Oct 20, 2014 at 9:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not certain yet. I did talk with Alex at Columbia Overland about a custom kit that would use 2 yellow tops instead of 2 Odysseys. Not sure if that will go anywhere.
    Yeah, might even be the same seller, Marc somethingorother was the paypal account name.
  4. Oct 20, 2014 at 9:35 PM
    PcBuilder14
    Brent
    Nor Cal
    :thumbsup:
  5. Oct 20, 2014 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    honestly find a friend that has a manual car and that is a good teacher. Learning on your own will be hard. Plus no point unless you have access to one all the time as it'll take a good few weeks of constant use to get semi good at it. and a good month or two before you are semi smooth at it.
    Yea i know Steve had issues with his Colombia kit and two odysseys. the battery terminals kept hitting his hood.
    I know the yellow top metal cage i have you can just put two back to back. But im not sure if it'll fit in the front..id think it would. But could be verrrryyy tight.
  6. Oct 20, 2014 at 9:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    They actually make a kit now for 2 group 35 Odysseys in the stock location. The kit moves the overflow bottle but it does fit without any other mods.
    http://www.columbiaoverland.com/col...1st-generation-dual-battery-tray-2005-current
    I think it might be the same seller. It was the same price and it came from Seattle too. I just say that it was a guys name on the paypal account. They only had one unit available. Maybe they found another one and I just got lucky. :notsure:
  7. Oct 20, 2014 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mike a kit like this would work
    Same thing i have but no TG logo..and a 1/3rd the cost..
  8. Oct 20, 2014 at 9:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Steve???
    It would be very tight. Would mean having to re-route all my winch, PIAA and LF wiring as well as relocating a couple of fuse holders for the amps.
    The Yellow Tops are dimensionally very similar to the Odysseys except for height. They are about an inch shorter.
  9. Oct 20, 2014 at 9:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I held mine in there and they fit. But didn't want to relocate the coolant overflow..in retro spec..that would be stupid easy.
    I do remember the biggest turn off for me for any of these kits is how much the battery over hangs the wheel well and isn't supported. Just too much hanging out there and i was worried about how it would handle the abuse the truck puts on it.
    So i just put it on the other side haha
    Steve = http://www.tacomaworld.com/forum/1st-gen-builds/173699-sanders-02-dc-build.html
    Yea shorter would be nice..
  10. Oct 20, 2014 at 10:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I hear what you are saying. I wish I had the skills for this.
    It seems like there may have been a single sheet of advertising in there but honestly, I cant remember. :eek:
    This ^^^ is correct. That is is a good inch wider overall and will not fit according to my calculations.
    There is no room to spare in there
  11. Oct 20, 2014 at 11:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gage did you cancel your front bumper order?
  12. Oct 20, 2014 at 11:42 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    Yeah he did but if he stayed in his number was pulled for a free one...
  13. Oct 20, 2014 at 11:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh the irony..lol
    Well that sucks. So no bumper still for baby taco?!
  14. Oct 20, 2014 at 11:48 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Yeah, but its all good. Ill get one eventually.
  15. Oct 20, 2014 at 11:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well that sucks..that woulda been a sweet upgrade.
  16. Oct 21, 2014 at 12:02 AM
    anders99
    Matthew
    Penscola, FL
    Hey gage have you seen the red first gen solid axel driving around laramie?
  17. Oct 21, 2014 at 6:41 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Yep! Bad ass rig.
  18. Oct 21, 2014 at 10:59 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Oct 21, 2014 at 6:06 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I am putting off buying the tent. Gonna sit out and see if I can't find a deal over the winter from someone selling one.
  20. Oct 21, 2014 at 6:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    called it haha
