Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 27, 2014 at 8:51 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Are those lights any good?
    Distance? Good for back up ligjts?
  2. Nov 27, 2014 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea. 6" lights. They are good for the price. Great for back up lights. Nothing crazy though. They are optic less.
  3. Nov 27, 2014 at 9:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thanks Josh, I ate way too much. :eek:
    :woot: I can't wait. :D
  4. Nov 27, 2014 at 9:52 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    What site is that on?
  5. Nov 27, 2014 at 9:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
  6. Nov 27, 2014 at 10:27 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    well poo
    Thinking this would go well in the rear bumper for some reverse lights
  7. Nov 28, 2014 at 2:51 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Just bought a couple... Probably try to use them for reverse/camp lights. Won't be putting them on for a while though.
  8. Nov 29, 2014 at 7:01 PM
    FreidTaco
    FreidTaco boost
    jeff
    URD just hit 539rwhp with their sleeved and stroked kit.
  9. Nov 29, 2014 at 7:03 PM
    BradyT88
    BradyT88 Well-Known Member
    With the 1GR-FE? Was it running their Stage 3 setup or did he put a larger blower on there like Werty did?
  10. Nov 29, 2014 at 7:09 PM
    FreidTaco
    FreidTaco boost
    jeff
    URD has hit another milestone.
    URD was the first company to bring to market a forced induction system for the 1GR-FE engine. Our first system we call the Mark 1 system made over 300 RWHP in its original form.
    A while later the system was updated to the Mark 2 configuration using a larger supercharger and air/air intercooler system and we broke through the 400 RWHP barrier.
    The system was again updated to the Mark 3 configuration using better engine management and a cold air intake system. The stage 3 system normally ranged in the 430-450 RWHP range, with some pushing higher. The system could not be maxed out due to limitations of the stock engine.
    URD worked with Darton a good while ago to develop the first mid sleeve kit for the 1GR. Once the sleeved block was delivered we contacted with an engine builder that failed to complete the build. Although this set things back a good bit, it did give us the opportunity to start over from scratch and this time we decided to include stroker rotating assembly from Brian Crower.
    The new engine was installed a couple of weeks ago and started right up and drove perfectly. The self tuning ability of the UCON-Ethos did not require any manual calibration changes. It was driven for 500 road miles without a glitch.
    Today it was put on the dyno. My last dyno on the stock engine with the same configuration put down 440 RWHP (-91 w/75mm), today after a few runs it easily push through 500 RWHP. The highest it was pushed today was 539 RWHP with an 80mm pulley and 7000 RPM redline. It was backed off to right at 500 RWHP and we are going to run it like that for a while. This was all done with 93 octane pump gas."
  11. Nov 29, 2014 at 7:11 PM
    BradyT88
    I found the thread. Looks like it was on the regular Mark 3 kit. I wonder what that thing could do with a larger blower, if the motor could handle it anyway. 7000rpm redline:eek:
  12. Nov 29, 2014 at 7:15 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  13. Nov 29, 2014 at 7:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn...
    Do it Marc :D
    Also my mom texted me the FRV had issues today coming off the mountain but no one is replying to my messages....
  14. Nov 29, 2014 at 7:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Christmas tree hunt. Nothing offroad. Just up to five spring camp ground, josh Marc and gage should know that, but if there is snow can be a bitch.
    Idk if it's a run into the tree issue..or blown tire issue..or engine issue..no one has replied in three hours..
  15. Nov 29, 2014 at 8:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea me too..no one is responding. Not even my brother.
  16. Nov 29, 2014 at 8:18 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I bet they are fine man. She was probably talking about the MTRs.
  17. Nov 29, 2014 at 8:20 PM
    FreidTaco
    FreidTaco boost
    jeff
    Sleeve/stroker kit is 11k
    on top of the 7k sc kit
  18. Nov 29, 2014 at 8:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea they are fine. Truck is just running bad. Not happy with the 7th injector kit, has t run good since that went in. Runs too rich.
    11k haha shit. Idk rather get Titan motor sports stroker Kit for a 2jz for all that money.
  19. Nov 29, 2014 at 8:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well this is the 2nd gen kit remember.ltotally different from ours..same idea though. It's pretty new too.
    I'm not sure what the deal is but my dad will call gaget and get it ironed out. Has already had a guy tune it via wi fi..kinda cool to see.
    He also baked his tranny a while back..hit like 300° going up one of the steepest passes here.
    And front diff was acting weird.
    :itllbuffout:
  20. Nov 29, 2014 at 9:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Any thing above 250* is pretty hard on the fluid.
    There is a thread on here somewhere that gives numbers (in minutes) on what sustained high temps will do to it. It doesn't take long at 300+ to ruin it.
