Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 29, 2014 at 9:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea I told him to flush it. He is due for his 60k service so he will get it flushed under warranty.
  2. Nov 29, 2014 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  3. Nov 29, 2014 at 9:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No he doesn't. He was just luggin it up the mountain. Didn't have the scan gauge to tranny temps as he usually monitors it close.
  4. Nov 29, 2014 at 9:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This could be. I was looking too. No luck.
    I'm actually a little surprised this is still happening after re-gearing. Mine got a lot better after the 4.88s. I still plan to add a cooler before next summer tho. I may do a new radiator too, as a precautionary move..
  5. Nov 29, 2014 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea idk. Truck is a pig and big tires..who knows.
  6. Nov 29, 2014 at 11:02 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I had issues as well. Had same guy tune mine. I actually did a tune running down i80 with wifi hotspot and laptop in passenger seat. My idle has evened out after going to 76mm TB. Used to idle shotty when hot.
  7. Nov 30, 2014 at 8:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It ever get better? Been kinda disappointing.
  8. Nov 30, 2014 at 10:04 AM
    FreidTaco
    FreidTaco boost
    jeff
    Yeah the idle is better.
    Gas pedal every once in a while goes dead while driving. I think it is a wiring issue someplace. Either in the pedal assembly or harness.
  9. Nov 30, 2014 at 10:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well wasn't the whole gas pedal thing the recall on a bunch of toyotas? should have taken it to the dealer for that for a new sensor.
    His just pegs out to 10.1 AFR under any load, way to rich. i don't think its had an issue idling, just running in general
  10. Nov 30, 2014 at 10:57 AM
    BradyT88
    BradyT88 Well-Known Member
    That was part of the Runaway Prius recall. Toyota only did on all vehicles to cover their asses. All they did was cut the bottom of the pedal off so it couldn't get caught under the floor mat and reflash the ECU so that if you hit the brakes it will close the throttle body whether you are pushing the throttle or not. All throttle by wire vehicles got the recall.
    As far as I know they didn't swap any sensors or anything.
  11. Nov 30, 2014 at 1:35 PM
    FreidTaco
    FreidTaco boost
    jeff
    Tell him to check his oil. So he is not washing his cylinder walls.
  12. Nov 30, 2014 at 3:59 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Gadang I love this state. Had a great day just out and about cruizn random two track and taking photos.
    [​IMG]2 by sconniehailer, on Flickr
  13. Nov 30, 2014 at 4:07 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
  14. Nov 30, 2014 at 4:16 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    I.... I.... I wanna do that!
  15. Nov 30, 2014 at 4:20 PM
    SconnieHailer
    Marc
    Silly Colorado private land :eek: I feel for you Joey :pout:
  16. Nov 30, 2014 at 4:25 PM
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    yeah. i love CO but it isn't exactly conducive to that sort of thing.
    still job hunting elsewhere so there is still a chance
  17. Nov 30, 2014 at 7:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Monte! I figured this would be appropriate to tell you since I bag on your rtt expo bull shit all the time...but I have now found a reason why i really want an rtt tent and why I have to build expo capabilities into my truck...I want a tent so With the truck built up I can drive around chasing powder on the weekends and not worry about staying in expensive ass hotels
  18. Nov 30, 2014 at 8:45 PM
    SconnieHailer
    Marc
    haha, better get an annex and a mr buddy heater :wink: Works great with my setup!
  19. Nov 30, 2014 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do it :cool:
    Or electric blanket and second battery!
    6d is treating you well man..damn..I am so jealous of..well...everything haha
    My date went awesome too!
  20. Nov 30, 2014 at 9:41 PM
    SconnieHailer
    Marc
    Woo! good to hear :D
    and true, an electric blanket would be saweet!
