Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 20, 2015 at 12:07 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Was thinking the same thing...
    The UG will do everything that Digiratus asked about.
    VVVVVV
  2. Jan 20, 2015 at 12:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Jan 20, 2015 at 12:12 AM
    PcBuilder14
    Brent
    Nor Cal
    Yup, got my acronyms mixed up. Fixed.
  4. Jan 20, 2015 at 12:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  5. Jan 20, 2015 at 7:07 AM
    BradyT88
    BradyT88 Well-Known Member
    The UG asks how many miles you traveled and how many gallons you added when you fuel up and compares it to what it read and adjusts the calibration from there. It does show you the percentage adjustment on that screen so you can just enter in numbers to get the percentage you want if you know it.
    For fuel calibration, it suggests using the same station and same pump every time while calibrating to get a good calibration, and I suggest hanging on to all of your receipts since you will have to add them together every time you fuel up to adjust the calibration number correctly. I usually have it pretty close after about 5 fuel ups.
    I haven't seen an SG in person, but from all that I have seen there are only 3 differences I know of, the SG costs almost 3 times as much as the UG. The SG can read auto trans temp on 2nd gens while the UG cannot, and the UG's screen is much bigger than the SG.
    One difference I am not sure about, is I believe on the SG you can add in missing sensor readouts, but this involves knowing the can bus coding very well and spending some time programming it, or hoping that someone already did the leg work for you. The UG has no other external connection besides the OBDII port so you can't change the software. But other than auto trans temp on a 2nd gen, the UG already reads everything.
  6. Jan 20, 2015 at 8:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tranny temp isn't just a 2nd gen thing. It's an everything thing.
  7. Jan 20, 2015 at 8:59 AM
    BradyT88
    I just said 2nd gen, because I only knew it was the case for 2nd gen. I wasn't sure about others.
  8. Jan 20, 2015 at 9:54 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    only autos get the tranny temp feature. My SG is always within 2 or 3 tenths of what the miles/math method nets me at each fill up. I run the SG at 9.2% for calibration of millage.
  9. Jan 20, 2015 at 10:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben you should get the 24mm pancake. I just tried it out and it's great. Perfect FOV IMO.
    Mike, gonna cost me 231 to get my 18-135 fixed :eek:
  10. Jan 20, 2015 at 10:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I love the gopro. Can't wait to really start to use it. But yea I feel you.
  11. Jan 20, 2015 at 7:54 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I bought an 11mm german Mauser today... Not sure why.
  12. Jan 20, 2015 at 8:05 PM
    BradyT88
    Mine are pretty damn close. Within 1 MPG easy.
  13. Jan 20, 2015 at 8:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    SG can see all the sensor data coming from the ECU. I primarily chose it over the UG because of its ability to read the trans temps in almost real time (about every 2 seconds it updates). It does this through XGauge codes developed by SG. The XGauge development work may be part of the reason for the additional costs. :notsure: I don't really care actually, the trans temp is that important to me.
    Not quite, XGauge codes in my SG would not work on the Raisin. Since then, I've read that on 1st gens those codes only work on '98-'04 models. Something must be different for '95.5-'97 models, either in the ECU or in the trans. Those code also worked on Mark's '07 Tundra.
    I want to say that mine is 7.2%. I'm note sure those numbers really mean anything outside of the vehicle they are for tho.
    :woot:
    Sometimes it helps to actually read the instructions that come with something. It did come with an instruction booklet...didn't it? :rolleyes:
    Wow, that kinda sucks. Is that from the Canon Factory Service center?
  14. Jan 20, 2015 at 9:02 PM
    FreidTaco
    FreidTaco boost
    jeff
    My SG went from 9.0%ish pre SC to 0.4% post SC
  15. Jan 20, 2015 at 9:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Haha, not sure what the implication of that is.
    Yeah it did. :p
  16. Jan 20, 2015 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
  17. Jan 20, 2015 at 9:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
  18. Jan 20, 2015 at 9:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
  19. Jan 20, 2015 at 10:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Probably ecu. Not the only odd thing with out ecus..
    And it was at the local camera store. I'll check direct canon later
    Nice photos btw!
  20. Jan 20, 2015 at 10:37 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    You can download the instruction from the website, its what I did.
