Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 13, 2015 at 8:31 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Ill look tomorrow but I think a sleeve popped out from the hinge on the gate. I am not sure how I manage to screw everything up but it's impressive :laugh:
  2. Mar 13, 2015 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The bottom dust shield is up side down and so is the top bearing in this.
    Put the dust shield on first then the bottom bearing. Then the swingout goes on. Drop the top bearing on and then just tap it a round while wiggling the swingout up and down till the beating goes down. Then the nut goes on.
    Should be fine.
  3. Mar 14, 2015 at 8:34 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Yep, broke it. Fuck, I'm going fishing.
  4. Mar 14, 2015 at 9:19 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Damn it I want to go fishing! I got a fly rod the other day and need to try it out.
    Also my prjectors are weird. When on brights there are very bright lines to both sides out in front.
  5. Mar 14, 2015 at 9:57 AM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Lol what? How?
  6. Mar 14, 2015 at 12:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    How do you break a swingout? Haha
  7. Mar 14, 2015 at 2:11 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    No put the bottom bearing in the swing out small part of the cone facing the middle of the sleeve then tap the seal into the swing out. Place swing out on spindle with the top bearing ready to drop onto the spindle into the swing out small part of cone facing the middle of the sleeve. Put washer and castle nut on torque down so all moves freely but no up and down movement on swing out. Also everything should be packed with grease....that's to make it easier. Haha...
  8. Mar 14, 2015 at 8:23 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Thanks Steve, that was better instructions than what I got :laugh:. Anyways, the sleeve for the small bearing came out so we decided to just press it in using the castle nut and washer but it just broke. Not sure what to do now but I'll be mesaging Tyler in the morning.
  9. Mar 14, 2015 at 8:27 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Bummer Gage, I've got no experience with swing outs but what Steve said was a good description of what I saw John and Monte doing with Mikes when they put it on!
    BTW Steve, how are those coilovers riding?!
  10. Mar 14, 2015 at 9:05 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Haha yeah I had no clue what I was doing. I was going off that picture I posted earlier...which was very much wrong.
  11. Mar 14, 2015 at 9:14 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    Just get a number off of the bearing or cup. You can probably get one for less than 10 bucks. Coils are good so far but I haven't really had much of a chance to get them worked in.
  12. Mar 14, 2015 at 9:51 PM
    FreidTaco
    FreidTaco boost
    jeff
    Gage did you get the number I texted you?
  13. Mar 14, 2015 at 10:37 PM
    oldmancrash
    oldmancrash Well-Known Member
    Maurice (Morris)
    Missoula, MT
    Stock
    Yea Gage, take the bearing to NAPA and have them look up the numbers. I bet they will have one on the shelf. If they dont have numbers stamped on the bearing NAPA can measure it and come up with a replacement. Ask them to give you a jobber price as your a student. Makes the parts much cheaper
  14. Mar 15, 2015 at 2:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do it. Although is it open even? Idk how the plowing works up there. Think they open Yellowstone this month tho.
    Be a good time to go before too many tourists go there. But July is the best there. Or August of course when its mountain spring sfrom what I've heard.
    Really dry year though. Hope the fires aren't bad this year
  15. Mar 15, 2015 at 9:29 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You wont be able to drive thru the park. The going to the sun road is only open during the summer months depending on how much it snowed up there.
  16. Mar 15, 2015 at 9:49 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Come and meet us there on August 20th. :D
  17. Mar 15, 2015 at 12:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Probably yes we will. Kind have too haha
  18. Mar 15, 2015 at 2:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Because I have to be home the 21st at the latest. I'm not driving from Canada to Powell and then to st Louis in three days.
  19. Mar 15, 2015 at 3:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :facepalm:
    You didn't look at a calander did you?
  20. Mar 15, 2015 at 3:42 PM
    FreidTaco
    FreidTaco boost
    jeff
