Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 21, 2015 at 8:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha I'm sure!
    I thought there was a Toyota supercharger for it..or no?
  2. May 21, 2015 at 8:51 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Dang Gage, that sucks and I'm glad all is well. I know I'd be freaked as well if Jax did the same, can so easily have a different outcome...
  3. May 21, 2015 at 9:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah..bummer.
  4. May 21, 2015 at 9:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    When is the warranty up :p
  5. May 21, 2015 at 10:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    5 years at the current rate. :rolleyes:
  6. May 21, 2015 at 10:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Jesus. you drive a lot haha
  7. May 21, 2015 at 10:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Time to put some miles on the green machine. :stirthepot:
  8. May 21, 2015 at 10:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha you need to replace the shit AAL for a better one.
    The wheelers 3 leaf would be a good way to go. Would fit the stock pack perfect and still let you keep the skyjacker leaf.
    Or just a normal AAL.
  9. May 21, 2015 at 10:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :woot:
    I've been doing the exact same thing. :D
  10. May 21, 2015 at 10:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    OH yea!
    well Marc is coming over for a sleep over and we are gonna do shock rebuilds and some welding!
    So there!
  11. May 21, 2015 at 10:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm sure that will be lots of fun. :rolleyes:
  12. May 21, 2015 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Proper leaf pack? eh. The weakes point is that it's still an OEM pack base. Just need to replace that and it would be better.
    Longer shocks..not sold on. Not without a relocation.
  13. May 21, 2015 at 10:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    fanboi
  14. May 21, 2015 at 10:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea..fine on the leaf pack.
    But the concept of "correct length shocks" is very misguided here.
    You can NOT get a bigger shock then 8.5 at the most while utilizing the stock mounting locations and retail stock uptravel. You'll see a net loss in travel.
  15. May 21, 2015 at 10:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i know. I was there, why i went with 10'' ones.
    But mine are also dead from acting as my bump stops.
    Short story...relocate the shocks.
  16. May 21, 2015 at 10:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Get a swing out :p
    and if done right you can still relocate.
    Get TC's kit. Or fab something like it.
    I will probably get TCs kit for Igor and Frank will be custom.
  17. May 21, 2015 at 11:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Doesn't the TC kit require running wheel spacers?
  18. May 21, 2015 at 11:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    are you trying to..shock me with this?
    Have you...seen my truck? :p haha
    Only 3 of those things would have to happen..really only two for relocated shocks.
  19. May 21, 2015 at 11:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I thought you were planning OBA with CO2
  20. May 22, 2015 at 7:33 AM
    SconnieHailer
    Marc
    Just filled my tank last night! :woot: ready for summer!
