Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 21, 2015 at 10:22 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    2m 144-150 is 600 khz
    70cm 440-450 is 5 mhz
  2. Jun 21, 2015 at 10:24 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    You probably need to set the tone then. What is the callsign of the repeater your trying to listen to.
  3. Jun 21, 2015 at 10:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the master has arrived.
  4. Jun 21, 2015 at 10:31 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    frequency: 443.9750+ plus
    Tone: 136.5
    so you need to set the tone to 136.5. Which radio do you have?
  5. Jun 21, 2015 at 10:39 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    Did you get a program cable with it? If you did the easiest way to program it is to download a program called chirp. Go to repeaterbook.com then download the repeaters for your area as a csv file. Import into chirp then upload to radio. makes it alot faster.
  6. Jun 21, 2015 at 10:41 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    thats not unusual one is 2m and the other is 70cm with the same callsign. I just quoted the 70cm one.
  7. Jun 21, 2015 at 10:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    joshipps likes this.
  8. Jun 21, 2015 at 10:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    trust me..you're not alone..haha
  9. Jun 21, 2015 at 10:46 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    No problem thats part of the ham community. Help others learn the hobby.
    m3bassman[QUOTED] likes this.
  10. Jun 21, 2015 at 10:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :oops:
    Rack looks good. Complicated tho.
  11. Jun 21, 2015 at 10:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    its extremely complicated, for a freaking bed rack. Taken me damn near 3 weeks to build. It works though! Gonna be better once the handles go on. The more we use it the better it works though. Its kinda finicky but still does the job.
    it looks crooked though...because...my bed is bent :anonymous:
  12. Jun 21, 2015 at 10:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So the tilting is for access and fully extended is for camping/sleeping and low/flat is how it will sit the rest of the time for low center of gravity/aerodynamic sleekness?
  13. Jun 21, 2015 at 10:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep!
    Has side tilt for access to stuff there. Probably how ill pack the tools and stuff i use most. Then rear tilt up for ease of access as well for lunch or whatever. Fully up for camping. Although it doesn't have to be.
    Be down flat for travel. Whole tent is below the roof line now.
    has gas struts in all 4 corners too. Works pretty slick. I'll have video of it.
    m3bassman likes this.
  14. Jun 21, 2015 at 11:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Is it heavy?
  15. Jun 21, 2015 at 11:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lighter then my old one. Course it had the roof rack..
    Overall it is lighter i think yes. Its all just 1.5'' tubing and 1.25 and some 1/4'' angle iron and 1/8'' angle.
  16. Jun 21, 2015 at 11:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Whatcha gonna do with the old bumper? :anonymous:
  17. Jun 21, 2015 at 11:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You don't want that low hanging heavy thing.
    besides..the likely hood of ben getting my elite is pretty small..
    He won't want it after i modify the swingout again to accommodate my CO2 bottle anyways :p
  18. Jun 21, 2015 at 11:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sweet. The concept is interesting. Be curious to see how it does for you. Moving pieces on the trail can sometimes get interesting.
  19. Jun 21, 2015 at 11:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Seriously, it isn't that bad.
    I don't think that is going to discourage Ben. :D
  20. Jun 21, 2015 at 11:15 PM
    Speedytech7
    The likelihood of me being able to afford it was low anyway, stupid truck is gonna need a head-gasket by the end of the summer (it leaks, but not enough to warrant taking out a loan to do it right this minute). I almost have enough for new tires and wheels so those are first, plus they'll hold me to making sure I put the engine right. Working them 40+ hour weeks, I might have mod money after the maintenance and fixes.
