Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 19, 2015 at 4:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You got a full guard hoop??
    ugh..hate those..never seen a good one on a 1st gen ever. Pauls is close..but still..
  2. Jul 19, 2015 at 4:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea the badlands isn't as bad. Still.
  3. Jul 19, 2015 at 4:55 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I like mine... :pout:
    I agree that some look good and some don't. Pelfreybilt and Pauls are really the only ones I like.
  4. Jul 19, 2015 at 4:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes, they do. The ones that are in there came with the first set of springs I bought from Northwest Offroad many years ago. When I bought your alcans from Wheelers, I did not use the bushings they would have normally sent with those alcans.
    I'll bet money these will work. if you feel the need to be absolutely certain, call Bill Ford at Alcan or Dan at Wheelers.
    It's the Dakars that are non-toyota standard.
  5. Jul 19, 2015 at 5:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i believe it.
    But i thought you got the car for a commuter :stirthepot:
    hmm..well. Really any LED cube type light would be fine i think for that. Or PIAAs.
    don't really have a spot for some though on that bumper..
    I was looking and would be cool to plate from the winch to the headlight with just sheet metal. Could add light mounts then too.
    Your bias though :p
    Cool thanks. Im going to get the Wheelers HD stock length grease able shackles and they come with bushings so just checking.
  6. Jul 19, 2015 at 5:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea those would work too. Could mount those off the bottom of the tube i bet. They just aren't super bright so not really a fog..i mean..they work fine i guess. I still think they are the best lights on Frank.
    d2s on the CBIs might be too bright. You'd have to shut them off and on with on coming traffic.
  7. Jul 19, 2015 at 5:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Because they are perfect for what you are currently stating what your plans for the rear are. For a setup with 2" of lift using the stock locations (driver shock is 1/2" longer than the passenger) plus they are rebuildable. Unless you'd rather waste you money on OMEs. :rolleyes:
    :thumbsup:
  8. Jul 19, 2015 at 5:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Timmy.
    You're referring to the USB programming cable? Do you have one you recommend?
  9. Jul 19, 2015 at 5:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Jul 19, 2015 at 6:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hmmm. I would like to get that one but there is only standard shipping available on it. No other options and it wont get here before 8/12. Probably coming from HK.
  11. Jul 19, 2015 at 7:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know where to get the same lights. Give me a sec.
    Can always relocate the shocks...Mikes are doing great :cool:
  12. Jul 19, 2015 at 8:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    do the swingout. Duh.
    or do the TC relocation thing. Or a relocate them more vertical.
  13. Jul 19, 2015 at 8:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Very happy with mine. :cheers: @SconnieHailer
    Probably not for a or b. B option will also require frame reinforcement. Might as well relocate the shocks when you do that. I kno a guy...
    I have a brand new, unused 6" blitzpro that I might be willing to part with.
    SconnieHailer likes this.
  14. Jul 19, 2015 at 8:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i see where this is going....i go from fixin up your rig ass ever xmas to fixing bens rigs ass...lol
  15. Jul 19, 2015 at 9:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You do good work, its what happens.
  16. Jul 19, 2015 at 9:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the links. I will check them out.
  17. Jul 19, 2015 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea its only money right?..
    lets make it happen
    haha yea i guess. Only for you guys though :cool:
  18. Jul 19, 2015 at 9:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Gentlemen, I need to get a radiator, any brand suggestions? I was thinking either TYC (KOYO) or OSC. Remember I have a manual, so no tranny cooler needed (although my current one has one for some reason).
  19. Jul 19, 2015 at 9:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    We can chat on the trip about stuff.
  20. Jul 19, 2015 at 9:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have no experience with having to change the radiator, tho I have been considering doing it as proactive maintenance. Probably the next time a do the timing belt and water pump. I am at 70K on the current ones.
    I will be curious to hear what you end up doing.
