Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 27, 2015 at 10:20 PM
    scocar
    scocar hypotenoper
    OK, I'm out for tonight. Gonna go watch Frenchmen get road rash for a bit...the Tour, you know.
  2. Jul 27, 2015 at 10:25 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Thanks for the laughs this evening fellas :laugh:
  3. Jul 27, 2015 at 10:30 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Well when I bought her in 2003 with 15k she already had the bug guard. I guess I'm too gawdamn sentimental...
  4. Jul 28, 2015 at 8:05 AM
    scocar
    scocar hypotenoper
    No, I think that will make a mess. It is generally used inside connectors prone to oxidation or corrosion from water, like bare metal trailer hitch wiring connectors (spades or butts) and similar. I would just use high-grade 3M electrical tape, making sure to clean whatever it touches very well. The trick also is to start away from the area or concern by not pulling the tape tight, then after a couple wraps, pull the tape to stretch and conform tightly to the wiring to exclude air/water, then when finishing, take the tension off again on the last wrap so that it it not trying to pull up the loose end. Make sense? I'll usually do a double layer, once in each direction.
    But your space to do this is ridiculously limited, of course. Hope this helps.
  5. Jul 28, 2015 at 8:12 AM
    scocar
    scocar hypotenoper
    Yeah. Not familiar with the resin, but once you've got that thing out, I'd put extra protection on it considering it is already possibly compromised. The sharp bends and exposed wire when I saw mine concerned me, but I saw no damage. Given the exposure to mud, dirt and water there, I would add tape too. Then even consider just leaving it unbent and zip tying it to that metal bracket in front of the shifter rather than reinstalling the factory retaining clip.
  6. Jul 28, 2015 at 9:16 AM
    scocar
    scocar hypotenoper
    Yeah. That was the first PITA. Was yours not attaches there? Small metal vertical tab, and the wiring harness connector had another clip on it that mated to this tab. Sort of arrow shapwd , IIRC.
  7. Jul 28, 2015 at 9:44 AM
    scocar
    scocar hypotenoper
    Yeah, almost looks like it it bent. I wouldn't worry about reconnecting to it. Just take measures to make sure the edges of that tab can't abrade through any wires over time. Hence the zip-tie thought.
  8. Jul 28, 2015 at 12:12 PM
    scocar
    scocar hypotenoper
    It really is unbelieveable how a little sensor R&R can be such a PITA. All they had to do was make the wires a little longer and move it to the rear out from under the sheetmetal. Fucktards.
  9. Jul 28, 2015 at 5:57 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So... :spy:
    Gillette may very well be in my near future
    SconnieHailer likes this.
  10. Jul 28, 2015 at 6:02 PM
    SconnieHailer
    Marc
    Coal road rail!!? Sweet man!
  11. Jul 28, 2015 at 6:20 PM
    SconnieHailer
    Marc
    Haha nice trick. That sucks though.
  12. Jul 28, 2015 at 6:28 PM
    SconnieHailer
    Marc
    Could u back that stud out with your trusty vise grip!? Put a new one in and call it a day? Or is that stud perm?
  13. Jul 28, 2015 at 6:42 PM
    SconnieHailer
    Marc
    Haha yea once u try that it's a must happen route since them threads would get jacked. Unless you threaded on a die and really cut the threads if it didn't work
  14. Jul 28, 2015 at 6:56 PM
    scocar
    scocar hypotenoper
    Oh shit. I swear I actually almost removed my driver seat.
  15. Jul 28, 2015 at 7:26 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
  16. Jul 28, 2015 at 9:36 PM
    memario1214
    Colton
    Missoula, MT
    That is a fact!
  17. Jul 28, 2015 at 9:37 PM
    jgantzler
    jgantzler Well-Known Member
    Jeremy
  18. Jul 30, 2015 at 9:13 AM
    scocar
    scocar hypotenoper
    @m3bassman hows the sensor shitshow going? I know you are busy with work, but wondering if you were at least able to back out that broken stud while waiting for the sensor to arrive...
  19. Jul 30, 2015 at 10:11 AM
    scocar
    scocar hypotenoper
    Is your tongue tired?
  20. Jul 30, 2015 at 10:13 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
