Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 4, 2015 at 1:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Better than nothing!
  2. Oct 4, 2015 at 3:20 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Monte @Blackdawg I found more haul ass roads!!! Picture later. On south pass down a power line. Saw some elk through the binocs too and a few sage grouse but no hun (gray) partridge we were hunting.
    Looks nice Ben! I need to get out camping at least once more this fall!
    Edit: here's the road
    [​IMG]3 by Marc Mayer, on Flickr
    Blackdawg[OP] likes this.
  3. Oct 4, 2015 at 4:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ummm....
    YES!!
  4. Oct 4, 2015 at 5:05 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    where is this.
  5. Oct 4, 2015 at 7:15 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I hear ya, Still trying to break that habit haha.
  6. Oct 4, 2015 at 8:02 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    U can take me on a date there then. I'll put out I swear
  7. Oct 4, 2015 at 10:19 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    I can help yuh help yuh help yuh. Sluts all of them! first month of college all those girls gave a fuck and made class easy on the eyes then after that it was swear pants for a whole year.
  8. Oct 5, 2015 at 5:06 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    College sluts :D
    gordi and m3bassman like this.
  9. Oct 5, 2015 at 7:13 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    @BabyTaco you will be glad to know i purchased another car.
  10. Oct 5, 2015 at 7:18 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
  11. Oct 5, 2015 at 7:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea..really why..
  12. Oct 5, 2015 at 9:17 PM
    FreidTaco
    FreidTaco boost
    jeff
    It's an 05 pontiac grand am that was babied until it was tboned. The guy changed oil ever 2k with synthetic, air filter every other oil change, and fuel filter every 4th. The engine will be pulled and dropped in our caged lemons car. I only paid 200 for the car and drove it 30 miles home.
    BossFoss likes this.
  13. Oct 6, 2015 at 9:19 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Well, the truck went into the dealer today. Everything so far has been smooth. Upfront cost is a minimum of $110. This gives them an hour to diagnose what is wrong and decide how they want to proceed. Hopefully I can get everything sorted out and the truck running smooth again.
    SconnieHailer likes this.
  14. Oct 6, 2015 at 9:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What was wrong with it?
  15. Oct 6, 2015 at 10:08 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    That shuttering sound I mentioned awhile ago is coming somewhere under the hood. I "fixed" it when I changed the oil early and noticed I lost a lot of oil. With new oil the truck runs smooth with no noise. After a round trip from Laramie to Sheridan the noise would return. I added oil one trip without fully changing it and the noise again went away for a bit. Occasionally when starting the truck after it has sat for a few hours I will get a loud grinding noise directly after the engine turns over.
    I also keep throwing my check engine light. P0101, indicating a Mass or Volume Air Flow Circuit Range/Performance Problem. I cleaned my MAF Sensor and replaced my PCV valve but still threw the code. I am guessing my valve guide seals may be bad already? Hard to believe with the truck barely having just under 50,000 miles on it.
  16. Oct 6, 2015 at 12:34 PM
    FreidTaco
    FreidTaco boost
    jeff
    Noise after starting sounds like starter hanging up.
    Low oil will make an engine noisier.
    Are you lacking on power more so than normal?
    Metal chunks/shavings/filings on drain plug?
    Was your oil sparkly with metal when changed?
    Did you pull the plugs checking for excessive fouling on one or multiple cylinders?
    Oil in coolant?
  17. Oct 6, 2015 at 3:10 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I figured it may be the starter but never heard them grind in person. I am lacking power in lower rpms. No metal chunks that I know of and I have not messed with the plugs yet.
    Toyota called, they said my MAF is reading wrong and they want me to get a new one. I told them to wait on that until I find out the real issue. They told me they had to put in 4 quarts of oil. That's probably within 1300 miles since my last oil change :frusty:. So it is burning oil pretty good. They said they wanted to top it off, put on a new pcv valve and run it for 400 miles to see how much is burning. I explained that I had recently put on a new PCV valve from them and now they want me to just drive it 100 miles to see how much oil is burned. No word on warranty yet but when I pick up the truck I will ask.
  18. Oct 6, 2015 at 3:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow. I'm worried a piston ring is going out. Or already did. A bad MAF would not make the truck burn oil. And that is a lot of oil.
    No evidence that it's just spilling out either? Not a front or rear main seal?
    FreidTaco likes this.
  19. Oct 6, 2015 at 8:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Saw a 4 door 325ix today in traffic. Caught my attention due to the fender flares and the sound it made. Had a baby seat in the back haha. Looked it up and man, what a cool car it must be to own. Super rare. an AWD 325i basically..Never knew how small they really where. I bet it's a hoot to drive. Just maybe not in traffic.
  20. Oct 6, 2015 at 8:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. 88-91. I think it was a 89. Sounded great.
