Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 25, 2015 at 9:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It has not been a good season for cBOB. Was that 'rojo's' old set up? Didn't he bust a ring in that one too?
    I just noticed that Ben deleted that post asking about the alt. WTF!
    I missed the refference to all-poo, any more information or a link? :popcorn:
  2. Oct 25, 2015 at 10:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You need to read better haha the cs144 has always been a sub 150 mod.
    I can help do that too if you come for Christmas.
    Dude I can't believe you've blown two rear ends so close to eachother. Crazy.
    4.88s eh? Going for that low gearing :cool:
  3. Oct 25, 2015 at 10:52 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Gimme a call if you want a hand
  4. Oct 25, 2015 at 11:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, Mr Tim got a good deal on his. I think I paid a bit more. Something like $130 + shipping. Did you even look at the links I posted?
  5. Oct 25, 2015 at 11:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The info at that ttora link is supported by what I was told by the Canadian mechanic that did the second fix on mine. If you have the e-locker, you have an ABS axle and associated compoments, even if the truck does not have ABS. Is it my imagination but the non-TRD/ABS axle looks beefier/larger diameter compared to the elocker/TRD/ABS axle. Maybe its the lighting in those pics. :notsure:
    4.88s eh! I like it. Are you planning to go larger than 33s?
  6. Oct 26, 2015 at 6:29 AM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Anyone happen to have a set of 2nd gen LCA laying around? I put my ome kit on this weekend only to find 3 out of 4 alignment cams are rusted into the bushings.
  7. Oct 26, 2015 at 7:41 AM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    @SconnieHailer might have some but I think he would be the only one in Wyoming. Maybe Steve but I can't remember if he replaced his. Check in the Colorado BS thread if we can't help you.
  8. Oct 26, 2015 at 8:15 AM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Thanks! I was hoping he might as I saw he had swapped his. I might not end up needing them but it would be nice to have a set ready invade I mess mine up trying to get the bushings out.
  9. Oct 26, 2015 at 8:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Difficulty level for normal guy...easy
    Difficultly level for ben...ultra hard..
    Lol
    Nah it's easy.
    Wtf. Quit deleting posts. Be a man and stand by your internet post haha
    Just Marc. Dad hasn't done LCAs.
  10. Oct 26, 2015 at 8:17 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I have a set. One of the cam bolts was seized in the bushing and cut to remove.
    My plan was to refurb this set with new bushings/cam bolts and possibly reinforce. Then have them on hand for spares or swaps if people had seized cams.
    I haven't yet done that so these aren't quite ready to go but they can be worked on while leaving the truck driveable until ready to swap.
    I'm not wanting to get rid of them but if it would help you maybe we could work something out to swap with yours?
    Also curious how you managed to seize 3 of the 4... I understand the ones where the cams are on a sleeve but it would seem to me that it would take a LOT of rust to seize the ones where the cams are on a bolt.
  11. Oct 26, 2015 at 8:57 AM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    I'm not sure, I also wouldn't have thought the rear one would rust in there. With a breaker bar I'm able to get some movement out of it, but it must just be twisting the rudder as it tries to go back. 8 years old and only 60k it may never have been aligned, so who knows.
    Where are you located? We might be able to get something figured out, and get them back to you.
  12. Oct 26, 2015 at 9:38 AM
    Speedytech7
    Sounds like a plan!
  13. Oct 26, 2015 at 12:42 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I'm in Firestone CO. Looks to be about 221miles/3hrs from Glenrock
  14. Oct 26, 2015 at 4:46 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
  15. Oct 26, 2015 at 6:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Oct 26, 2015 at 6:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i can't wait for the story on that.
    Jumping to 16s too? Going with some SCS's?
  17. Oct 26, 2015 at 6:33 PM
    Speedytech7
    I've heard the OEM 2nd Gen steelies are near 29lbs a pop, not sure on the 1st Gen steelies though.
  18. Oct 26, 2015 at 6:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gotcha.
    Im sure they are at least 8lbs heavier if not more. Not sure that matters much..Cutting weight down...not my forte..haha
  19. Oct 26, 2015 at 8:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So, 16x7 eh? FWIW, my steelies are 32/33 lbs I think.
    I like the 255/85-16s idea. Definitely narrow/less weight. You really think they'll be a full inch taller? I am sure they are taller than 33x10.5-15s on an 8" wide rim but I was guessing .5-.75" at most.
    I like the countersteer Xs but they are the wrong offset/bs and I don't want to run a spacer. I think they weigh less than 20 lbs.
  20. Oct 26, 2015 at 8:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Plus tire choices are km2s or st maxxs I think..
