Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 24, 2015 at 2:22 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Would replacing the rings be something I could do?
  2. Nov 24, 2015 at 2:44 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Its not hard work but its not exactly the easiest thing either. Remove the head. Have to undo the rods so you can pull the piston out, remove existing rings and install new, the block could probably use a honing. The rod bearings should be good still so i dont think you would need to replace them. Them just reinstall.
  3. Nov 24, 2015 at 2:47 PM
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    Forget the v6. Put a 4bt cummins in the bish.
  4. Nov 24, 2015 at 2:50 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Lol, if it was cost effective I'd happily swap in a v6 now. Only reason I didn't want to before was for the warranty but at this point I'd be lucky if they would even cover my transmission
  5. Nov 24, 2015 at 5:32 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Gage i feel you would get distracted and loose interest/parts in doing rings.
  6. Nov 24, 2015 at 6:02 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Lol, I'll take my attention pills to help avoid that.
  7. Nov 24, 2015 at 6:13 PM
    jgantzler
    Jeremy
    Just don't mix up the rod caps!
    Edit: could be valve guide seals to.
  8. Nov 24, 2015 at 6:48 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    True, forgot about those. Those tend to go out fairly often. Easy to replace too. Just requires a valve spring compressor and if your any good you can do it with the head on still. Have to reset cam timing though
  9. Nov 24, 2015 at 6:51 PM
    jgantzler
    Jeremy
    Just need to put air to the cylinder to hold up the valves.
    There is a couple of tests you can do to determine if the rings are bad or not, cylinder leak down test comes to mind.
  10. Nov 24, 2015 at 6:52 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Even a compression test would be simple to test. If its a low number, add a teaspoon of oil in the cylinder and retest. If it goes up significantly then its the rings.
  11. Nov 24, 2015 at 6:57 PM
    jgantzler
    Jeremy
    That one would definitely be easier than a cylinder leak down test.
  12. Nov 24, 2015 at 7:08 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I thought it was the valve guide seals at first. I have heard thats a doable job for someone with basic skills.
  13. Nov 24, 2015 at 7:32 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    The seals themselevs are easy, yes. But the work to get to them and properly putting everything back can be a bit intimidating. Timing chain, Cam timing, valve springs/retainers.
  14. Nov 24, 2015 at 7:43 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I dont have much input Gage, but it seems like the dealer is definitely not on your side. I'm suddenly not feeling like jumping to 35's haha
  15. Nov 24, 2015 at 8:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x2 on this.
    Gage, how many miles on that engine? For some reason, I had the impression it was not high mileage. In fact, I thought it was still under warranty. <60 K
  16. Nov 24, 2015 at 8:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    @m3bassman Looks like fun Ben. I get to go play in some snow starting on thurs.
  17. Nov 24, 2015 at 8:22 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    ~52k. It is not high miles and under warranty. They were all about the warranty until they saw the fender liner was missing. I looked, there is very little in the air box. Probably whatever I couldn't easily get out before I put in the custom liner. I argued with them for about 10 minutes about how the filter in place stops all the dirt/water. I got fed up with them and left.
  18. Nov 24, 2015 at 8:27 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Itll be a fight if you take it to them, but i think youd win out.
    I had the same issue when my 4x4 actuator went out, they didnt even want to look at it and said it looked "offroad abused". Ended up replacing it myself.
  19. Nov 24, 2015 at 8:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No, no. Its under warranty. Its burning oil. Lots of oil. And it is documented. There are no stipulations in that warranty. Toyota needs to fix it. Period.
    Your dealer is playing head games. Don't let them push you around. If they wont do it without qualification, I would talk with Toyota corporate about it. I would also find another dealer.
  20. Nov 24, 2015 at 9:25 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Well, to use another dealer I would have to go through the same crap and drive 45 minutes at a minimum to drop it off. I dont really have that luxury :pout:
