Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 1, 2015 at 8:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Whatever! He just slides around. Makes it fun
  2. Dec 1, 2015 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's what's fun. It's not turning its not turning BAM grip and your done.
    Plus lt so I win no matter what
  3. Dec 3, 2015 at 5:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Happy Birthday Ben. Hope you are having a swell day. :D
    @m3bassman
    m3bassman likes this.
  4. Dec 3, 2015 at 5:36 PM
    jgantzler
    jgantzler Well-Known Member
    Jeremy
  5. Dec 3, 2015 at 5:55 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Happy birfmas ben...he will see it..
  6. Dec 3, 2015 at 6:10 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Happy birthday dude, didnt realize ours were so close :cheers:
  7. Dec 3, 2015 at 6:29 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Happy birthday Ben :cheers:
  8. Dec 3, 2015 at 6:40 PM
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Gage you might as well get an Instagram. Pelfrey likes showing off your truck :cool:
  9. Dec 3, 2015 at 6:47 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Lol, I don't need another social media account.
    Mike90 likes this.
  10. Dec 3, 2015 at 7:29 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Any of you guys pressed your own wheel bearings? Going to try it tomorrow, seems straight forward except the ABS sensor part. Worried I won't get it back in the right spot so my inner seal seals correctly. Also found it strange that there is no sensor for the ABS on the rear but it has the 'gear' if you will on the shaft.
  11. Dec 3, 2015 at 8:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Can't help you with feedback on doing your axle bearing and seals, I always had a shop do the work. But yeah, that rotor for the ABS was on mine too and I don't have ABS either.
    Are you regeared? How many miles on your truck?
  12. Dec 3, 2015 at 8:37 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    No, just bought a 99 with 276,000 miles and going through it fixing all the things that the previous owner neglected. Pulled the axles to just do the seals but noticed there was some play in the bearings, not a lot but I'm assuming there should be zero. Runs great though, gives me hope for mine with only 148,000 miles.
  13. Dec 3, 2015 at 8:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ha, I see. Good to hear that the '99 is in good shape.
    FWIW, I lost the driver side axle bearing (twice) at ~150K. These is some speculation that this is common to regeared trucks. :notsure:
  14. Dec 3, 2015 at 8:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    From my research all elockers are abs housings.
  15. Dec 3, 2015 at 9:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is what I recall reading as well.
  16. Dec 3, 2015 at 11:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Welp. Sad new in camera land. My 60D is no longer useable. Got the "no card in camera" error. Only way to fix is to send it to canon.
    Tragic.
  17. Dec 4, 2015 at 1:22 AM
    Mike90
    Mike90 Well-Known Member
    Black Hills, SD
    '07 DCSB, '79 FJ40, '18 Subaru Crosstrek, ‘23 DCSB
    Backup camera!
  18. Dec 4, 2015 at 5:37 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That sucks! Sorry man.
  19. Dec 4, 2015 at 5:59 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Interesting, good to know
  20. Dec 4, 2015 at 9:03 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    It's on the list. Won't happen this winter but maybe over the summer.
