Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 4, 2016 at 8:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    #ceramic #rockcrawling
  2. Jan 4, 2016 at 8:40 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Ohhh haha. How are your syncros holding up?
  3. Jan 4, 2016 at 8:42 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    #regear #doubletransfer #twinstick
  4. Jan 4, 2016 at 8:44 PM
    FreidTaco
    FreidTaco boost
    jeff
    No idea. Banking on snow pack on the underside hindering something. Waiting for a warmer day to try and drive again.
    Also need a snorkel but hate the looks.
  5. Jan 4, 2016 at 8:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Crawl box with your hp man not be a good idea
  6. Jan 4, 2016 at 8:48 PM
    SconnieHailer
    Marc
    Was just wondering in general how they're doing before your issue. My second gear and first gear can be stubborn at times like the syncros are peaking (not meshing). I usually just kick the clutch and then the gear will go.
  7. Jan 4, 2016 at 8:50 PM
    FreidTaco
    FreidTaco boost
    jeff
    Reverse is finicky 60% of the time. First was very rarely a trouble maker maybe 5% of the time.
  8. Jan 4, 2016 at 8:56 PM
    SconnieHailer
    Marc
    Hmm my reverse never a troubles me. Glad they're good though.
  9. Jan 4, 2016 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know on our 5speeds reverse is a bitch sometime. Going into 1st can be a bitch sometimes too
  10. Jan 4, 2016 at 9:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I never ave any trouble getting into reverse. 1st either for that matter.
    Sacrifice and SconnieHailer like this.
  11. Jan 4, 2016 at 9:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It was great still is. But I think it slips every now and then. Noticed it on the trip. Did it maybe twice.
  12. Jan 4, 2016 at 9:24 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I did the twin stick on mine and I love being able to use low gears in 2wd
  13. Jan 4, 2016 at 9:33 PM
    FreidTaco
    FreidTaco boost
    jeff
    Then maybe backing a loaded trailer with a stage 3+ clutch wouldn't suuuuuuuccccckkkk
  14. Jan 4, 2016 at 9:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk. Not a lot of options. Maybe a URD one
  15. Jan 4, 2016 at 10:10 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Only problems with dead batteries? :stirthepot:
    Blackdawg[OP] likes this.
  16. Jan 4, 2016 at 10:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Fucking perfect
  17. Jan 4, 2016 at 10:37 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Lol probably. I do all my pulling with my duramax so I can't say for sure. When I was in Moab I was frustrated that I had to be in 4 low when I just needed a lower gear for some of the slow trail maneuvering or tight corners on hills.
  18. Jan 5, 2016 at 5:35 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    it was from low range...
    http://blog.lowrangeoffroad.com/category/products/toyota-products/
    also, check out LCE engineering, http://www.lceperformance.com/1GR-CLUTCH-KITS-s/16732.htm
    i went with the dual comp to handle the SC and wears of wheeling better...it's definitely grabbier than OEM...i would not suggest the dual comp really for our trucks...i would do the pro clutch if i were to do it again...
    SconnieHailer[QUOTED] likes this.
  19. Jan 5, 2016 at 10:33 AM
    SconnieHailer
    Marc
  20. Jan 5, 2016 at 11:04 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Haha, I guess it was my turn...
    :luvya:
    At least I didn't blow out a ball joint and have to have my dad come get me.
