Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 14, 2016 at 8:48 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    My truck stays outside too, i only put it in there to work on it. To be honest i dont even think it will fit anymore with the rtt.
  2. Jan 14, 2016 at 8:55 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Gonna clear a spot for the Subie in the garage now that i'm back at in Wyo :cool: those cold morning starts should sound real nice bouncing off the back wall :D
  3. Jan 14, 2016 at 8:59 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I kno they refer to your garage as a two-car but it really isn't that big except for how tall the opening is. Not very long or wide.
  4. Jan 14, 2016 at 9:12 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    1 car garage problems, happy wife problems..... truck makes it in there sometimes but usually when the wife is out of town.
  5. Jan 14, 2016 at 9:17 AM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Nothing like another cold windy weekend to welcome you back to town. Lol
  6. Jan 14, 2016 at 9:32 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I just ordered 2 new batteries. :pccoffee:
  7. Jan 14, 2016 at 9:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mmmmm not sure. Id have to look.
    Do tell...
  8. Jan 14, 2016 at 9:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :D
    2 Northstar AGMs. 24Fs
  9. Jan 14, 2016 at 9:56 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Haha it's different when ur married and have joint checking. Trust me!
  10. Jan 14, 2016 at 9:57 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Duals finally eh? How are you setting them up?
  11. Jan 14, 2016 at 10:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, finally!
    Are you asking where will I put the 2nd one? In the bed. No room under the hood. The controller will be an ML-ACR.
    Yeah, if it isn't leaking more, you may be Ok. :notsure:
    IIRC, the seal on the passenger side can be pushed in to far when its replaced.
    You should be able to feel it when the axle is not in there. When you replace, try not to have it in any deeper than what the stock one is now.
  12. Jan 14, 2016 at 10:19 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It ain't fun, I did both on my truck, but I did it at the same time as tie rods and LBJs so I took the whole spindle off the truck and used a c-clamp style ball joint press from Autozone (I broke one of the cups you force the joint into but it still worked). You just won't be able to get enough leverage without the spindle off the truck, maybe a 650+lb impact would let you crank it in though.
  13. Jan 14, 2016 at 10:59 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Hey when ur ready ur ready. I dated her for 7 years before marrying her. It only changed a few things, it was nice I didn't have to go to my own home at 9 every night haha.
  14. Jan 14, 2016 at 11:21 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I just recall reading that. Did you come across that in your research?
  15. Jan 14, 2016 at 12:23 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    If u need help or whatever I'm a few streets over and have air tools and everything. I'll trade help for the camera expertise haha!
  16. Jan 14, 2016 at 12:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just don't press em in too far and you'll be fine. You'll need a big ass socket or at some sort of round tap that fits around it to tap it in evenly. Then use the axle to push it where it needs to go. So get it set in there a little ways and then just put the axle in gently.
    Really? after timmy said it was useless and didn't work?
  17. Jan 14, 2016 at 1:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't remember Mr Tim saying that, but it doesn't matter. I already have one. It is one of those things a collected along the way. :oops:
    Besides, there are lots of people using that controller. It must not be a problem for them.
    Do you have more information on what his issues were? If you have more on this or advice, I'd like to hear details.
  18. Jan 14, 2016 at 2:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No idea. I just remember asking him about it as I wouldn't mind changing mine to an automatic one and he said it didn't work. :notsure: have to ask him though.
  19. Jan 14, 2016 at 2:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, not sure either. Seems kinda rash to say they don't work tho. There are a ton of folks on here using one of these for their dual battery controller.
    Maybe his definition of automatic is different from what this unit does. There is supposedly a lot of functionality packed into one of these things.
    I do know that one thing it doesn't do is have an in-cab status indicator/monitor readout. You know, those two rows of colored lights that go from red to yellow to green.
  20. Jan 14, 2016 at 2:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea don't need that. But to me by automatic that means it still monitors the starter battery and kicks off the aux battery when the start is low so the starter will charge. Then flip back to the aux when the starter is done charging.
    If it doesn't do that. Not worth it
