Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 15, 2016 at 8:37 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Crimping is the typical approved technique for large wire. It remains flexible at the end and no worries of brittle solder (that and unless you use a blow torch, itd be hard to get the wire hot enough to accept the solder)
    Digiratus[QUOTED] likes this.
  2. Jan 15, 2016 at 8:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Crimping is actually better. If done right.
  3. Jan 15, 2016 at 8:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Always use a blow torch :cool:
    Well...maap gas torch.
  4. Jan 15, 2016 at 9:42 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  5. Jan 15, 2016 at 10:59 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not to sure about his crimping method but the rest of it is reasonable and quite similar to what I've done in the past with 4 ga wire.
    It was my impression that larger gauge wire should be crimped with a crimper that compresses evenly, all the way around the terminal and the wire. Essentially compressing/compacting the wire to eliminate all air gaps in the process.
    To do this a crimping tool like this is used.
    http://www.amazon.com/Best-Choice-Products®-Hydraulic-Terminal/dp/B00CUQ042Q
    Speedytech7 likes this.
  6. Jan 15, 2016 at 12:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ding ding
    Correct!
    ANd that is pretty much what my dad has. Works great man.
  7. Jan 15, 2016 at 12:45 PM
    PcBuilder14
    Brent
    Nor Cal
    Glad y'all are talking about this. Just started doing researching on putting an auxiliary battery in the bed.
  8. Jan 15, 2016 at 12:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    got my gopro back! Well..a new one that is! Plus they sent me another battery, so now i have 4 :cool:
    joshipps and PcBuilder14 like this.
  9. Jan 15, 2016 at 3:50 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Hey guys, got a question. So the runner wouldn't start, after it had just been running, and it seemed like both my batteries were dead. So I hooked up a jumper, jumped it and it started right up. Except now it's reading a P0340 and P0345, cam sensor module problems, and the VCS TRAC and VCS OFF lights are both on now. Anyone have any thoughts on this?
  10. Jan 15, 2016 at 6:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    is that pink ^^^^
    Blackdawg[OP] likes this.
  11. Jan 15, 2016 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pink car condom..
  12. Jan 15, 2016 at 10:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    $250 bucks to fix my camera...damn..
  13. Jan 16, 2016 at 10:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    So worth fixing it. I needs to serve you for a few more years.
    I was just poking fun. But yeah, it still looks kinda pinkish in that light
    :D
  14. Jan 16, 2016 at 4:26 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    @SconnieHailer
    How goes the welding? You had a chance to play with it anymore?
  15. Jan 16, 2016 at 4:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea..but damn. That's a lot.
  16. Jan 16, 2016 at 4:41 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Lol @Blackdawg. $250 is nothing compared to what you are willing to drop on your truck. It's a crappy expense but at least it goes towards a hobby. Rice and beans ain't all that bad.
    Digiratus likes this.
  17. Jan 16, 2016 at 4:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well. Only because there is pretty much nothing on the truck I want that cost less than 400 at this point..
    But still. A lot. Considering I could get a used body for 500 as it is.
    I'll pay for it. I miss it. Really missed it over Xmas.
  18. Jan 16, 2016 at 4:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you are talking about a used 60D, there is no guarantee it wont develop the same trouble you had with yours. I only hope that the repair is an actual improvement in durability. Didn't you say the SD reader in those was a common point of failure?
  19. Jan 16, 2016 at 4:51 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I haven't touched it since last weekend. I was in Denver area most of the week and today I was busy with the pup/shooting a few photos (the ones below). I really want to get a bottle and be done with flux core (even though i've got alot of practicing to do with it) so i've kind of been putting off playing with it more until i get one. Also i need a better mask, i can hardly see wtf i'm doing haha. Can you weld with straight co2? Or do you really need that 75-25 mixture?
    I want to sketch up a plan for building a cart for the welder too. I think that will be a good first project to weld on. Then this summer I want to tackle a trailer build! If all goes well i'll probably build to sell :cool: since im not too keen on wheeling with one unless its got an rtt on it and we're just doing easy trails.
    Shots from today just playing in some snow. These tires really are nice in the snow. Tons of grip.
    [​IMG]12 (3) by Marc Mayer, on Flickr
    [​IMG]12 (2) by Marc Mayer, on Flickr
    Sacrifice likes this.
  20. Jan 16, 2016 at 5:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea needs a whole new one like whole chunk of pcb re soldered in.
    Yea it's a common issue. Only way around it is to switch to micro sd cards and leave the adapter in all the time.
    Yea you can weld with pure co2. I think it's just not quiet as clean but still totally can.
    Truck looks good man!
