Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 17, 2016 at 6:28 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Its cast aluminum and only had c25. That was a difficult one.
  2. Jan 17, 2016 at 6:31 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Ohhh I thought you did seals too. My bad.
  3. Jan 17, 2016 at 6:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :woot:
    A few days ago you asked how the CVJ axles looked for quality. I found a couple of pics I took when I first got them, and then a couple of more I took yesterday.
    For reference, in this ^^^ pic, far left is the aftermarket spare I've been carrying in the OSK for the past couple of years, then next to it is the one you got from me.
  4. Jan 17, 2016 at 6:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    looks pretty good to me..
  5. Jan 17, 2016 at 6:58 PM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Greeting and salutations from Cheyenne! Former resident of Laramie too.
    joshipps likes this.
  6. Jan 17, 2016 at 6:59 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    FWIW, my two aftermarket ones (one being a reman) have the tulip shaped inner instead of round. I may have CVJ rebuild my one OEM one I still have. They seem to suggest that the outer boot doesn't have the same issue the inner boot has.
  7. Jan 17, 2016 at 7:09 PM
    SconnieHailer
    Marc
    :wave:
  8. Jan 17, 2016 at 7:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    welcome man! :wave:
  9. Jan 17, 2016 at 7:33 PM
    TacoJonn
    Jon
    Laramie, Wyoming
    Thanks for the welcome, guys. Still a gen 1'er. 2002 Tacoma I bought in 2008. 5 speed manual Off-road package. Occasionally tow my Casita with it. Within the next year or two hoping to get a gen 2 or gen 3. Could use some extra horseys to pull it in the higher elevations. Here are some pics of my Tacoma in the wildlands of Wyoming. =)
  10. Jan 17, 2016 at 8:15 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    FT, The CO2 in C25 is an oxidizer. Instead of shielding the aluminum in the casting from the oxygen in the air you just made a non-weld of aluminum oxide. The non-weld needs to be ground out and if possible re-welded with argon shielding.
  11. Jan 17, 2016 at 8:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That does seem to be odd behavior on their part and is different from what my experience was. I wonder why the difference. :confused:
    Have you seen these $60 boots they are pushing. I would love to see a picture of them to see them next to the ones I got. Just to see how they are different.
    Personally, I don't see the need for high angle outer boots. Well, at least from the perspective of tearing boots. I am fairly certain that it is always the inner boots that tear.
    For those that have torn a boot or boots, have you ever torn an outer one? I suppose, it could happen from trail debris, but that isn't what I am talking about. Who has torn an outer boot from too high axle angles?
  12. Jan 17, 2016 at 8:31 PM
    Speedytech7
    Both my inners 'sploded but neither of the outers did and my front is at 3.25".
  13. Jan 17, 2016 at 8:37 PM
    FreidTaco
    FreidTaco boost
    jeff
    I knew it was not the correct method at the time. It was the only thing i had on a late Friday night before a demo derby on a Saturday. Ended up not running it after getting defeated by 3 bent and sheared off engine mount bolts still in the block at about 3am.
  14. Jan 17, 2016 at 8:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Toytec Eibach coils I'll bet. Pretty sure Monte only tore the inners on all of his too.
    That is likely why I've never torn mine. I've kept my lift to ~2.5"
  15. Jan 17, 2016 at 8:43 PM
    Speedytech7
    I'll be lowering it a bit eventually, it's not really what I want it to be right now. But money is the factor, hopefully some decent coilovers and better rear shocks are in my eventual future. Definitely pulling a leaf come spring time so it sits with slightly less rake.
    Digiratus[QUOTED] likes this.
  16. Jan 17, 2016 at 8:50 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm the same boat. Running Eibachs and tore my inners pretty fast. Outers look practically brand new though with 120,000 stock miles, ~20,000 lifted miles
    Speedytech7 likes this.
  17. Jan 17, 2016 at 8:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I get this. ^^^
    Tune-able, adjustable shocks are definitely worth it if you can afford it.
    This is the sort of thing that makes me wonder why CVJ is pushing those more expensive outer boots. Doesn't seem like they are necessary.
  18. Jan 17, 2016 at 8:54 PM
    PcBuilder14
    Brent
    Nor Cal
    Monies
  19. Jan 17, 2016 at 9:00 PM
    Speedytech7
    They likely have built some already, you send in your core once they send you an axle right? But it is weird that the price is lower on the "better" boot.
  20. Jan 17, 2016 at 9:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Have you seen a pic of the two options? Which one do I have? Is that the high angle one? As I told you, I did not pay extra for outer boots.
