Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 20, 2016 at 8:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :quickdraw:
    Was that return label inside the box? I didn't see him put it in, only saw the box all sealed up.
  2. Jan 20, 2016 at 8:27 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yep all set for return! Should have em ready early next week.
  3. Jan 20, 2016 at 8:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks Buddy, there is certainly no big rush on this. Take whatever time you need.
  4. Jan 20, 2016 at 8:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Under the diff eh? Does the area around the pinion seal show signs of oil being thrown? Where on the diff are you seeing fresh oil?
    Also, saw in the daily you were asking about part numbers for LBJ bolts. I am curious if your '01 model came with rubber protective skirts covering the sides of the bj?
    My '02 has them but I know older ones don't. My '98 did not. FWIW, the ones I ordered the part number was 90119-10933. I just looked at my invoice.
    I think I read that you said you ordered the other part number, 90080-10066, correct? That part number would be the ones to use if you do not have that protective rubber skirt dealie.
  5. Jan 20, 2016 at 8:45 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Is the rubber skirt helpful at all? I don't have any, but if it's worth it I may add it to my order when I get new bolts.
  6. Jan 20, 2016 at 8:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :notsure: I assume it is there to prevent a stick poking accidentally a hole in the bj boot.
  7. Jan 20, 2016 at 11:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't have em on Frank. Even the new ones
  8. Jan 21, 2016 at 3:51 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    :cheers:
  9. Jan 21, 2016 at 3:53 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    When you doing them? I'd like to watch and learn a thing or two.
  10. Jan 21, 2016 at 5:38 AM
    SconnieHailer
    Marc
    Not sure, I'll shoot you a text. U back in WY?
  11. Jan 21, 2016 at 6:14 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Fly into Denver Saturday, and will be home Sunday sometime.
  12. Jan 21, 2016 at 7:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    These rubber skirts do not come with new OEM LBJs tho you can order them, they are a seperate item. They are designed to be reused if you have them. Certainly, older trucks like yours did not come with them. :notsure: You know Toyota, hard to predict sometimes which ones did and which didn't.
    :thumbsup:
  13. Jan 21, 2016 at 9:15 AM
    Digiratus
    Roaming the PNW
    The RedHead
    What?
  14. Jan 21, 2016 at 9:30 AM
    Digiratus
    Roaming the PNW
    The RedHead
    If you did not do the swap yourself, then the shop that did could have not reused the skirt as it was designed for but did they also reuse the original bolts? Those don't come with the replacement LBJs either?
  15. Jan 21, 2016 at 9:37 AM
    Digiratus
    Roaming the PNW
    The RedHead
    o_O
    The Toyota dealership would not have thrown away the skirts. If they were there, they would have reused them.
    Are you certain they reused the original bolts? I'm pretty sure the FSM shows the bolts as non-reusable whereas the skirt is shown as reusable.
  16. Jan 21, 2016 at 10:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thought I got new bolts with my ball joints..
  17. Jan 21, 2016 at 12:36 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I know I gave you a shitload of spares. Maybe that's what you're thinking of. :luvya:
  18. Jan 21, 2016 at 1:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Or maybe you are thinking of the one I traded for with you. :)
    [​IMG]IMG_6531 by mike digirat, on Flickr
  19. Jan 21, 2016 at 1:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually think my dad may have threw those out :anonymous:
    hopefully they are just in my pile o parts still..:pray:
    im sure that one is still being used :laugh:
    Idk...i lost track with all the bolts..i know they are all toyota ones...from...somewhere
  20. Jan 21, 2016 at 3:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Piaa bulb went out finally. Back to all stock on Igor haha
