Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 28, 2016 at 8:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Gage, are you back to school next fall or are you finishing up this semester?
  2. Feb 28, 2016 at 8:57 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I can finish next fall but I think I am going to set my schedule up to extend into spring of 2017. Better chances of me leaving with a job then.
  3. Feb 28, 2016 at 9:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, I see. No chance of joining an adventure in the fall then.
  4. Feb 28, 2016 at 9:02 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Nope, I wouldn't be able to regardless though.
  5. Feb 28, 2016 at 9:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    August is mountain summer time. That's the place to be July-sept imo.
  6. Feb 28, 2016 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tent and heat is no fun.
    weldertaco likes this.
  7. Feb 28, 2016 at 9:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Your crazy. No way I would go wheeling when its a 100*. Way too much stress on the vehicle for one. Also, I hate sweating and running the AC all the time is not the answer.
    I lived in the desert for a large portion of my life. You will not see me in moab between may and october.
    mizzac likes this.
  8. Feb 29, 2016 at 1:43 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    For those not actively following my thread, the engine pull has been pushed back to the 12th. Even if night eagle can't show up, I am likely to just get it done somehow on my own. Everyone is welcome, even if it is just to drink some beer and watch the shit show.
  9. Feb 29, 2016 at 7:04 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I hope there is interal support to tie the two walls together to keep it from bowing out.
  10. Feb 29, 2016 at 7:11 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    A utility knife with a long blade like this:
    And some sort of straight edge works well for stuff like that.
  11. Feb 29, 2016 at 7:21 PM
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    The tricks and tips of a former shipping department worker
  12. Feb 29, 2016 at 9:08 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    i have a cut off wheel and angle grinder........jk saw it was plastic. big pair of metal sheers will do it for cutting tin roofing.
    m3bassman[QUOTED] likes this.
  13. Feb 29, 2016 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This was going to be my suggestion. Would make quick work of it.
    Ben, you could invite Jon over and offer him some of that fine Noah's Mill bourbon. He might be tempted. :D @45acp
    45acp likes this.
  14. Feb 29, 2016 at 9:28 PM
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
  15. Feb 29, 2016 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tin snips. You can get them with various blade lengths. Tim has some with 1" tips to 5".
  16. Feb 29, 2016 at 9:31 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    If it's like metal you can score it with a knife then bend it and it should break cleanly.
  17. Mar 1, 2016 at 8:03 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Offering some bourbon wouldn't be necessary... but it wouldn't hurt, either. :luvya:
    I would think metal shears would be a PITA with corrugated anything. More so with potentially brittle materials like plastic. Just use the angle grinder with a cutoff wheel. Or a fine tooth rotary blade attachment for a dremel, which is what I use for soft materials like plastic and aluminum.
    http://www.amazon.com/SE-SS40SM-Speed-Blade-Mandrel/dp/B000TBUMG2/ref=pd_sim_469_5?ie=UTF8&dpID=31PYh9RIoJL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=1WDBPD4RSYAJCRDQJE60
  18. Mar 1, 2016 at 10:51 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    best 70 dollar tool i bought, besides my new Milwaukee sawzall
  19. Mar 1, 2016 at 2:45 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Like I said, I'll be there if I don't get sent to work in CO that weekend. Headed to MT tomorrow for a long weekend since Im already well over my 40 hours of work and their isn't much going on this week.
    BabyTaco[QUOTED] likes this.
  20. Mar 1, 2016 at 6:58 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    I'm available maybe Sunday but my certification course starts Saturday 8-4
