Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 9, 2016 at 4:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I hate stick welding haha well..not hate. But it takes a lot of practice. The guys I learned from where fucking good. Thouh they do it all the time. Oil guys
  2. Mar 9, 2016 at 4:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, I find MIG a lot more useful in my everyday stuff, but stick is a cheap way to weld thicker stuff without forking thousands for a good Hobart or Miller MIG.
  3. Mar 9, 2016 at 5:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No doubt. But he'll I just use an Eastwood 185. Welds 1/4" easy
  4. Mar 9, 2016 at 5:49 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    What's a 60D?
  5. Mar 9, 2016 at 5:50 PM
    Speedytech7
    Canon DSLR
  6. Mar 9, 2016 at 7:14 PM
    Speedytech7
    I'm telling ya, we can make it cable actuated and put a locking lever in the cab. Cut out that stupid electric motor nonsense.
  7. Mar 9, 2016 at 7:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A mechanical is an auto locker..aka..on all the time your on the throttle.
    Don't do it.
    Start surfing junk yards and stuff for a new diff.
  8. Mar 9, 2016 at 7:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also a possibility..someone makes a kit for it actually..
  9. Mar 9, 2016 at 7:20 PM
    Speedytech7
    I think we could make that for less money, but that is a better idea I think than fixing the elocker over and over.
  10. Mar 9, 2016 at 7:34 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Ah
  11. Mar 9, 2016 at 8:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea that's a good option..I think.
    Long as the cable stays semi clean and out of the way
  12. Mar 9, 2016 at 8:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think if I was in that situation, I might consider swapping to an 8.4 axle.
    <knocks on wood>
    Blackdawg[OP] likes this.
  13. Mar 9, 2016 at 8:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I would not be giving up on a locker. Gotta have a selectable in the rear. Of course I would add an ARB and 4.88s. Didn't think I needed to say that.
    Might even consider using a t100 axle like Monte is going to. @Blackdawg How much wider are they? Are the axles any stronger over the Tacoma axles? I know the 8.4 carrier is generally stronger.
  14. Mar 9, 2016 at 10:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you wouldn't do a t100 and neither would ben lol its 6'' wider. 3'' per side. Look moronic unless you did LT too.
    The pinion is much stronger and the ring gear is slightly bigger and braced better.
    It is stronger then the e locker, not by a huge margin though.
  15. Mar 10, 2016 at 5:21 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    All this talk of swapping axles and everything else. Jut replace the damn elocker solenoid and have plenty of years to use it again.
    Easiest and cheapest option at the moment
  16. Mar 10, 2016 at 6:36 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You can get it online for 615. And unless you have the funds to drop for new gears/arb now then i would just fix it and continue running it even if you decide to regear. Just my opinion. The truck is 12+ years old and it just now failed so a new one should easily last a while unless you get rough with it
  17. Mar 10, 2016 at 8:10 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    the elocker can just be plugged/bolted in
  18. Mar 10, 2016 at 9:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wait a second..
    So when you regear...your going to swap diffs..and axles..just for an air locker..
    So what your saying is air lockers are better? Haha
    Seems excessive though. You can't put an air locker in your current axle or diff.
    BabyTaco and Sacrifice like this.
  19. Mar 10, 2016 at 9:43 AM
    Speedytech7
    What are you regearing to Ben, seems like a lot of extra effort for your tire size and current axle situation.
    Sacrifice likes this.
  20. Mar 10, 2016 at 9:59 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Exactly! The elocker has worked well enough for whats done and its a simple bolt-on replacement
    X2 this also
