Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 10, 2016 at 10:12 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I guess I understand the want to regear, I have no hope of 35s with my current 3.58s but his is about right for the tire size, 4.10s if I'm not wrong.
  2. Mar 10, 2016 at 10:16 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I think his plan is to stay with his current sized tires? Which im sure itd benefit but idk that it would be very drastic :notsure:
  3. Mar 10, 2016 at 10:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i think he wants to go to 33s next though.
    so 4.56 would be ideal.
  4. Mar 10, 2016 at 10:27 AM
    Speedytech7
    That would at least make sense, but if even has a shred of thought about going bigger he should just jump up to 4.88s with how expensive it is.
  5. Mar 10, 2016 at 11:15 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Can the RD132 be used in our 8.0" diffs?
  6. Mar 10, 2016 at 11:37 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    According to the info on ecgs it should. It says front or rear.
    Although i still think replacing the solenoid is the easier option.
  7. Mar 10, 2016 at 1:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.88s with a manual will be pretty over geared. Not quite like 5.29s and 35s but close. 4.56 is slight over gear
    No. The arb air locker can not be used in your diff.
    The 8.4" has two more ring gear bolts. The pattern won't line up.
    Digiratus[QUOTED] likes this.
  8. Mar 10, 2016 at 1:12 PM
    Speedytech7
    Oops forgot he was manual
  9. Mar 10, 2016 at 1:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for clarifying. ECGS is not clear on their product page which 8" diffs. Your saying it is only the pre-Tacoma 8"ers.
  10. Mar 10, 2016 at 1:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. The V6/Turbo diff as they call it
  11. Mar 10, 2016 at 2:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Find a new elocker diff for cheap. Hell there's one in Powell. Though Idk how much.
    Or swap a totally different axle hahaha overkill for you though.
    There's an 8.4 axle and diff in Powell too. Actually. I'll have a housing soon. No diff though.
  12. Mar 10, 2016 at 2:54 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    or trade it in on the crew max long bed tundra with the blower at parker. Probably the most costeffective.
  13. Mar 10, 2016 at 3:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It would never make it up to goose lake. Just sayin'
  14. Mar 10, 2016 at 3:22 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    armor and lift and super chargered 5.7l v8 and some will......it will make it any where. He could also just put the BRZ in the back
  15. Mar 10, 2016 at 4:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Find an elocker diff at a junk yard. It'll be miles cheaper then swapping axles and all. And cheaper then a brand new actuator.
  16. Mar 10, 2016 at 4:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Surf the webs then. They pop up.
    But as usual. No matter what any of us say. You've already made up your mind. I bet the mechanical thing is being shipped tomorrow.
  17. Mar 10, 2016 at 5:15 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Call Yoda Jim in Denver. He probably has a shed full of them. My e-locker works well and I wouldn't hesitate to fix it if it broke. Not enough benefit to justify any replacement.
  18. Mar 10, 2016 at 5:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bam. There you go. Denver yard or Timmys.
  19. Mar 10, 2016 at 7:17 PM
    Squeaky Penguin
    Brett
    And you criticize Monte's typing? o_O
    I don't see why your failing one negates the possibility of getting a good one from a junkyard. Like I said, mine is original to the truck, never been touched, and works flawlessly for me every time I need it. I just don't understand the e-locker hate. Your just now failed after how many years? And yes, sometimes you have to move slightly to get it to engage, but that has never once presented a problem with all my wheeling. Either you turned it on ahead of when you need, or if you need it, tires are spinning anyways and it will engage easy.
    Not worth the cost of swapping axles, and the hand/cable unit will probably be nearly as finicky IMO.
    Sacrifice likes this.
  20. Mar 10, 2016 at 8:04 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Any one keeping a tally of those for or against Ben's idea?
