Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 10, 2016 at 8:07 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Someone has to keep track of Ben's current idea too then.
  2. Mar 10, 2016 at 8:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Tires? For the brz?
    Well get your priorities straight next time. Haha
    Also..
    THANK YOU BRETT! Seriously. Haha
  3. Mar 10, 2016 at 8:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I'm thinking you've not had any troubles with yours yet is because it hasn't been disturbed. But I will admit, I do not follow you exploits too closely so I know very little about what you've had to do to your truck.
    Have you regeared yet? Have you had to replace bearing or seals yet?
  4. Mar 10, 2016 at 8:31 PM
    Speedytech7
    You should let me clean the locker motor, cause if I remember correctly you greased the commutator bars, which is a no no.
  5. Mar 10, 2016 at 8:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wait. When did you get a Kia?
  6. Mar 10, 2016 at 8:37 PM
    Speedytech7
    Thought you were gonna sell that and get her something else.
  7. Mar 10, 2016 at 8:41 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Me? What did I do?
  8. Mar 10, 2016 at 8:43 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Haven't touched bearings or seals, nor do I see how that would effect the e-locker actuator. Will be regearing here very shortly, but again, not seeing how changing the 3rd effects the function of that electric motor. If it were in that bad of shape that unbolting it and reattaching it causes issues, it surely would have failed by now just driving on it and using it.
    Edit: truck has 259K on it, and I use the locker dozens and dozens of times a year. It has not lived an easy life.
  9. Mar 10, 2016 at 8:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I like your optimism.
  10. Mar 10, 2016 at 8:53 PM
    Squeaky Penguin
    Brett
    Maybe you've been listening to too much of Ben's pessimism. :notsure: :p
    Regardless, you're more than welcome to tell me 'I told you so' when I have e-locker issues shortly after I mess with it, but I still don't think that will happen. I'm guessing a lot of it has to do with climate: my truck has lived in the dry Colorado air it's whole life, no rust to be found.
  11. Mar 10, 2016 at 8:54 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Might as well be married :rolleyes:
  12. Mar 10, 2016 at 9:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Some of it might be related to how much road gunk gets in there. I don't live in ID or MT but I have been there enough in road salt time to be infected. So :notsure: , I never had any issues until I regeared.
    I was not being sarcastic nor trying to play the devils advocate. I've just seen too many instances to ignore the possibility.
  13. Mar 10, 2016 at 9:05 PM
    Speedytech7
    Never found Washington very hard on vehicles. No rust probs for me and my trucks been here for all 21 years of its life. Mostly just the East coast where it snows that sucks for vehicles.
  14. Mar 10, 2016 at 9:19 PM
    at_olw
    at_olw Banned in D.C.
    'I told you so' :luvya:
    Speedytech7 likes this.
  15. Mar 10, 2016 at 9:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Quoted just to prove you actually still do love us. :luvya:
  16. Mar 10, 2016 at 11:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thank you Timmy @at_olw
    Told you they where out there man..
    Oh wtf...are you married yet? sheesh..slow down man.
    Nah he is saying that all because his axle has given him major bearing issues ever since it got regeared. And Cody, our friend at Low Range, said that for whatever reason the elocker axles never play nice after being messed with....no idea if that is true..
    I do know that setting your rear diff gears will be super easy compared to mine! haha
    HA!
    also
    :wave:
    m3bassman[QUOTED] likes this.
  17. Mar 10, 2016 at 11:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sorry Brett..i meant CO "young Brett" haha for calling ben out on his shit typing. Seriously Ben, its gotten worse then ever..
  18. Mar 11, 2016 at 7:43 AM
    Squeaky Penguin
    Brett
    Got me there. Only 8 months behind too.
    I've never heard of that issue relating to regearing e-lockers, and I still doesn't see how that effects the e-locker motor. I guess we'll see, won't we.
    Ben's talking shit about the actuator because it failed and then failed again after 'fixing' it. Mike has had repetitive issues with axle seals and bearings. I'm going to continue with my optimism and say neither of these are issues that every truck is going to face when laying a finger on the rear axle.
    Nor am I ignoring the possibility, but it is still only that: a possibility. I like to look on the bright side and not assume I'll have the same issues as others with seemingly isolated problems.
    Why's that? And I'm not setting them up myself. Leaving that job to someone with lots of experience with these diffs.
  19. Mar 11, 2016 at 8:33 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That and the elocker sensor never showing the diff is fully locked even though it is. All of it worked correctly prior to being disturbed.
  20. Mar 11, 2016 at 8:54 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I already tried that after you mentioned it before. But I don't remember that large a socket requirement. 14mm? :notsure:
