Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 11, 2016 at 9:04 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Not sure if this is much help for comparison. I lost track of the options discussed.
  2. Mar 11, 2016 at 9:27 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I like how much advice you all have for Ben, you guys all sound like a bunch of nagging wives. Sometimes you gotta just set back and watch the world burn......Or let ben do it on his own! :rofl:
    Digiratus likes this.
  3. Mar 11, 2016 at 9:36 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Comparing an 8" ring gear to a 10.5" ring gear.
  4. Mar 11, 2016 at 10:11 AM
    at_olw
    at_olw Banned in D.C.
    I have pulled and installed five thirds on my truck, and with original everything except the thirds, have never leaked a drop of oil. My elocker has always worked perfectly.
    Is Cody the guy behind this LROR video?
    https://www.youtube.com/watch?v=AVQHgcXEhpE
    If so, you might question why you value his mechanical opinion :laugh:
    Like anything, there are correct and incorrect methods. You follow the incorrect procedure outlined on this site for pulling thirds, and it wouldn't surprise me that one might have issues.
    And, as I have said before, it would be a worthwhile exercise for Mr. Mike to start by checking for axle straightness (stick a correctly-machined rod through the housing).
    EDIT: You should also check the axle shaft for straightness, as well as twisting on the splines themselves.
    It doesn't.
    Take this approach and you'll still get grief for not "participating" :rolleyes:
    gordi[QUOTED] and Speedytech7 like this.
  5. Mar 11, 2016 at 10:19 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :wave:
    at_olw[QUOTED] likes this.
  6. Mar 11, 2016 at 10:26 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    There's a distinct lack of drunken mistypes. So yeah all in all even better than usual.
  7. Mar 11, 2016 at 10:40 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    sometimes i sit back and think WWBD.....what would ben do......then do the oposite. Haha Jk! whats the plan tomorrow @Speedytech7 still coming over for pull and paint. im not off till 4pm though.
  8. Mar 11, 2016 at 10:46 AM
    Speedytech7
    Yup I'll be there, weather supposed to be shitty but hopefully I can lay a coat of bedline well enough. Ben will have to get the garage nice and toasty after we finish grinding the shit outta bumpers.
  9. Mar 11, 2016 at 11:09 AM
    Speedytech7
    I'm gonna set mine right on the ground, I'll bring some cardboard to grind and paint on though.
  10. Mar 11, 2016 at 11:26 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    So, what's the 'correct' procedure for swapping thirds as I'll be doing it shortly. I helped @Wishbone Runner swap his in the dirt in Moab, complete with sand, dust, dirt, biting gnats, and a piece of wood as a jackstand and he hasn't had any issues. No e-locker though.
  11. Mar 11, 2016 at 11:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The elocker has a clocking spring from setting its backlash. You just ratchet it over till it's right and then suck it down.
    Vs on the 8.4" you need shims and have to remove the carrier every time. Plus none of the whims come with an install kit so you have to order them after the fact or have em all before you start. Pita.
    5. Damn. What have you been doing to diffs in your absence haha
    I'm not saying I agree with the whole thing. I was just explaining why Mike has been skeptical. There are plenty of people here who have regeared with no problems ever. That said. You are probably right that the next place to look is the axle housing and shafts. But man. Id be amazed if he bent though but it's not out of the question at this point.
  12. Mar 11, 2016 at 11:30 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wasnt aware there was a correct way vs a wrong way. Drain oil. Disconnect the drive shaft. Undo the drums from the axle and pull the shafts out of the third. Undo the third bolts and your done..
  13. Mar 11, 2016 at 11:33 AM
    Squeaky Penguin
    Brett
    After those two posts I rescind my previous comment about Ben making fun of your typing. I clearly see now he has every right to do so.
    :D
  14. Mar 11, 2016 at 11:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea....:luvya:
    Ipad auto correct is something else haha
  15. Mar 11, 2016 at 11:40 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    i have 2 sets of jack stands if you want to set it on those instead.
  16. Mar 11, 2016 at 11:42 AM
    Speedytech7
    That'd be great if you don't mind me accidentally bedlining your stands. :D
  17. Mar 11, 2016 at 11:47 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    ones black and the other are these taller old blue ones. @m3bassman i can drop them by tonight since i wont be out till 4ish tomorrow.
    Speedytech7[QUOTED] likes this.
  18. Mar 11, 2016 at 11:50 AM
    FreidTaco
    FreidTaco boost
    jeff
    Fucking gf is absorbing all my time lately. I really need to finish my LT. Driver side is at 92% done. Passenger is at 0%.
  19. Mar 11, 2016 at 11:52 AM
    FreidTaco
    FreidTaco boost
    jeff
    Also need to put some preload on the coils. Currently driver side sits lower compared to previous setup on passenger side.
  20. Mar 11, 2016 at 12:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What coils do you have? If they are 600s, judging but the preload on them now, you'll need a lot to get it to 2-3''
