"X miles before empty"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ingot, Jun 21, 2019.
  1. Jun 21, 2019 at 8:43 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Haha!
    Digital at that.
    Chad_QS18[QUOTED] likes this.
  2. Jun 21, 2019 at 8:53 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Those numbers can never be accurate because the amount of consumption will change when the engine is being driven hard or easy.
    Hafaday likes this.
  3. Jun 21, 2019 at 9:00 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    There's an image of the owner's manual above, although I think it's slightly incorrect. The image shows "please refuel" but says it means there's less than 3.2 gallons left, but it would be more accurate to say 2.2 gallons left at "please refuel".
  4. Jun 21, 2019 at 9:14 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Third gen is a 3 gallon “reserve” so the fuel pump can stay submerged, cool, and happy. It’s not recommended to use that “reserve” regularly because it could lead to severe damage to the fuel pump
  5. Jun 21, 2019 at 9:15 AM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    Citation? You'd think if it was critical for the fuel pump, they'd design the tank to have an unusable area.
  6. Jun 21, 2019 at 9:21 AM
    Anchovy
    TRD Ferguson
    That’s how a fuel pump works, it is submerged in the tank. The pump can’t be in an “unusable” area of the tank. Even if it was in an “unusable” area, there still needs to be gas flowing through it to keep it cool so it doesn’t get damaged so running it dry would still damage it
    ToyoTaco25 likes this.
  7. Jun 21, 2019 at 9:34 AM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    Nobody is suggesting to run it dry, and obviously there could be an unusable area of the tank, if they designed the pump intake and tank to do so. The fact that they don't means it's probably ok for the pump body to operate unsubmerged at least some of the time. The pump isn't gonna over heat if you go up / down a long grade or something.
    Running the tank empty won't cause a catastrophic failure of the fuel pump. Accelerated wear, maybe.
    ryan760 likes this.
  8. Jun 21, 2019 at 9:39 AM
    Anchovy
    TRD Ferguson
    It’s not going to cause an immediate failure, no. But if you keep doing it over and over, it will. That’s why Toyota designed it like that so people will fill up before the tank is actually empty
  9. Jun 21, 2019 at 9:51 AM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    So you think they took the trouble to design it so that normal behavior (run until the gauge hits E, gas light comes on) could cause wear, but couldn't be bothered to design it so it's idiot proof and never could be unsubmerged?
  10. Jun 21, 2019 at 9:52 AM
    Chad_QS18
    Chad_QS18 Well-Known Member
    Chad
    NoVA
    2018 Quicksand Tacoma Offroad
    Slammed on 16s
    You two and your bickering are so cute :duel:
    Anchovy[QUOTED] likes this.
  11. Jun 21, 2019 at 9:53 AM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    Bored and every so slightly hungover, but it's lunch time so I'm about to solve all those problems!
  12. Jun 21, 2019 at 9:54 AM
    Chad_QS18
    Chad
    NoVA
    Slammed on 16s
    Im counting down the hours until I can start creating a hangover
    ryan760 likes this.
  13. Jun 21, 2019 at 10:06 AM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    if you are going to run it low like that for test or whatever,
    at least carry a full gas can with you. i keep a 1 liter bottle
    im my bed glove box for the hell of it. i usually just fill up when im at around
    1/2 tank and its convenient
    Jim1946 likes this.
  14. Jun 21, 2019 at 10:36 AM
    Suprasabre
    Suprasabre SOCal Motorcycle Commuter. Yes, I Split Lanes!
    Bob
    Cedar City Utah
    2016 Tacoma Limited MGM 4x4
    none
    Anyone around that was driving back in 1973/4 remembers the gas lines and got in the habit of filling up your tank when you got to the halfway point, since you weren't sure you would be able to find gas to fill up the next time you needed to! :annoyed:
  15. Jun 21, 2019 at 10:45 AM
    #35
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    Man I hated that gas shortage fiasco.
  16. Jun 21, 2019 at 11:01 AM
    #36
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Yeah, thank you Jimmy Carter.
  17. Jun 21, 2019 at 11:30 AM
    #37
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    Odd or even.
    monoman, Qwack and Secondchildhood like this.
  18. Jun 21, 2019 at 11:59 AM
    #38
    Anchovy
    TRD Ferguson
    I’m not sure you understand how difficult that would be... a fuel pump requires fuel flowing through it to be properly cooled, so if you run that pump dry it will cause damage. You’re hung up on the idea that it only requires to be submerged to be cooled but that’s not the only thing it needs. People can still run it dry and cause damage
    Jim1946 likes this.
  19. Jun 21, 2019 at 12:01 PM
    #39
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    mine is 420 till empty when filled up, shaking truck to get the last drops in..
  20. Jun 21, 2019 at 12:03 PM
    #40
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I went to 4 miles to empty.. it took 18.6 gallons even with a 10 second burp and trying to add more..
    Secondchildhood likes this.
