"X miles before empty"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ingot, Jun 21, 2019.
  1. Jun 21, 2019 at 1:39 PM
    #41
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    Don't keep pumping once the hose shuts off. You'll screw up your evap system and get an expensive check engine light.
  2. Jun 21, 2019 at 1:55 PM
    #42
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    my other car is an R56 mini cooper and HPFP failure is pretty common for the same reason. they recommend refueling once the first low fuel indicator goes on, usually around 65 miles to empty or 2+ gallons.
  3. Jun 21, 2019 at 2:41 PM
    #43
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    No need to panic at "0" miles remaining as long as there's gas stations in the general vicinity.
  4. Jun 22, 2019 at 3:53 AM
    #44
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    Yes, i know this, thus the 10 second burp and stop filling at pump shutoff... fuel will backflow into the evap canister and lines, and cause havoc with leak detection, and you have to replace the canister, and purge the lines from the fuel return/egr to the tank. also can cause issues with the purge valve..
  5. Jun 22, 2019 at 3:58 AM
    #45
    TT005
    TT005 Well-Known Member
    NC
    2023 SR5 DCSB 4X4
    Thanks for sharing!
  6. Jun 22, 2019 at 4:55 AM
    #46
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    as others have said, there is usually 2-3 gallons left in reserve once "gas empty please fill" illuminates. My previous 6 spd BMW M5 used to have a build in algorithm (based on gas consumption, not distance) to determine the exact miles left until empty: i.e., if you pushed in the clutch & coasted or were light on accelerator the "miles until empty" would lengthen & alternatively if you stomped on the gas the miles would dramatically decrease. Unfortunately our Taco's don't seem to be as "smart". Pushing on the clutch & coasting or stomping on gas does not appear to significantly change the "miles to empty"; it seems to be based on distance traveled alone.
  7. Jun 22, 2019 at 5:59 AM
    #47
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    It is actually fairly simple to calculate based off of the number of injectors, their capacity (rated in cc's) and counting the number of times they are fired times the pulse length is depending on AFR, and readings from the catalytic converters. using flow numbers (simple equation) you can be fairly accurate in fuel consumption, and compare against known fuel capacities, and levels. just have to remmeber that the bottomof the tank is curved.. so less fuel there than at the middle...
    just have to have an accurate fuel level/meter or have the computer recognize a fuel fill up to "full" an aftermarket "long range tank", or secondary tank would screw this calculation up..
  8. Jun 22, 2019 at 6:27 AM
    #48
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    I've got An ultraguage in my truck. Once calibrated (more accurately than the dash guage which is almost always about a mile per gallon optimistic) the UG shows about 30 to 60 miles more to empty (calculated based on the size of the fuel tank I told it from the specifications in the owners manual), how much fuel it thinks I've burned (less than 3% error from pump) and how many miles traveled (less than 1% error from odometer)
    Based on this I think the dash keeps a few gallons in reserve for its distance to empty calculation. The manual also says that it keeps about 3 gallons in reserve.
  9. Jun 26, 2024 at 12:20 AM
    #49
    hmgtaco09
    hmgtaco09 hmgtaco19
    2019 Tacoma TRD off-road dlbcab
    Bilstein 5100, OME 887 Coils second notch, SPC UCA, Deaver 1.5-2 AAL
    When you enter the tank in the UG how much did you put in? 21.1? Or by the amount of gas you actually put in from empty? I'm curious because I would like to calibrate my UG correctly to get an accurate reading of mpg as well as mileage.
  10. Jun 26, 2024 at 6:05 AM
    #50
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    I learned long ago, not to tempt running out, but if you are driving it you get a feel how far you can go. I've put a max of 19.5 in my 3rd gens. However in an unrelated incident my new bride 45 yrs ago asked me to fill her car with gas because it was low and she didn't like to use the pumps. I said sure I'll put gas in when I went to get diapers with her car. Made it 2 blocks. I have never let a car we own sit on E since. Being that guy walking with a gas can is embarrassing. Again that was with me not driving my truck pryer to that.
  11. Jun 26, 2024 at 7:09 AM
    #51
    lbhsbz
    lbhsbz Well-Known Member
    Who cares? Plan on filling up when you’re approaching 1/4 tank. Fuel pumps tend to live longer too when there’s enough fuel in the tank to cool them.
    ToyoTaco25 likes this.
  12. Jun 26, 2024 at 8:50 AM
    #52
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    It's a suggestion more then anything. It's close but not remotely accurate.
  13. Jun 26, 2024 at 4:02 PM
    #53
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    maybe i'm missing something, but how could a section of the tank, in which the pump is submerged, be "unusable"? either the pump is sucking gas or it isn't.
  14. Jun 26, 2024 at 4:26 PM
    #54
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    This game has been played before. Unless someone has beaten me… I’m the highest ranked player of the game of chicken. Forgot what the number was, but consider that the “please refuel” warning starts at 2 gallons and the fuel is a coolant to the pump as well as minimizing debris on the intake filter. If you know your MPG, it’s easy to figure your remaining range… typically ~30 miles. Get gas when you can.
  15. Jun 26, 2024 at 5:26 PM
    #55
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I’ve had my Tacoma 3 years now & have never had the low fuel light come on…I always fill up at 1/4 tank. The first & last time I ran outta gas was my first year driving (1982) & will never happen again..:eek: learned my lesson..
