X-Runner Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Clifford, Jan 23, 2012.
  1. Mar 6, 2013 at 11:54 PM
    #81
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    nice! mas boost! haha
  2. Mar 7, 2013 at 12:38 AM
    #82
    Clifford
    Clifford [OP] Well-Known Member
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Brian Crower 4.3ltr stroker kit. Picked up another motor to start building/sleeve. Gotta catch up to Torspd.
  3. Mar 7, 2013 at 1:51 AM
    #83
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Impressive haha
  4. Mar 7, 2013 at 3:36 AM
    #84
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Hopefully lol.
  5. Mar 7, 2013 at 3:53 AM
    #85
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'm jelly.
  6. Mar 7, 2013 at 4:24 AM
    #86
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    No, clearly you're Robert. lol.
  7. Mar 7, 2013 at 4:56 AM
    #87
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The race is on broski!
    I think there might be another very soon to get that kit as well. ;)
    Gotta stroke it before you give her the rod. o_O
  8. Mar 7, 2013 at 7:01 AM
    #88
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    That's freakin awesome! Are there any videos of what that stroker kit sounds like?
  9. Mar 7, 2013 at 7:10 AM
    #89
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    I'm sure there is, just have to look at videos of Hilux's and FJ's over in Saudie. I don't know of anyone running one in the states yet. Mark (Torspd) will probably be the first of us to get it up and running, with a few more following behind shortly.
  10. Mar 7, 2013 at 7:16 AM
    #90
    Lucario Runner
    Robert
    06 Toyota 4Runner
  11. Mar 7, 2013 at 8:46 AM
    #91
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Dry humor. :rolleyes:
    That guy is shifting at 6500 RPMs. Highest I have seen that was intentional and not from a miss shift. :eek:
  12. Mar 7, 2013 at 8:55 AM
    #92
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This holds water on my guesstimate that I told you earlier that the factory oil and water pump may still be effective till around 6800-7000 rpm. With supporting internals of course. I would still love to see the pressure, flow, and temperature data to confirm.
  13. Mar 7, 2013 at 9:13 AM
    #93
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    After my swap, I'll donate my spare block to the cause of science! lol
    Edit: So I just watched that video, that thing seams awfully quick for being NA, his 0-100kph/0-60 is pretty damn impressive.
  14. Mar 7, 2013 at 9:35 AM
    #94
    prerantaco
    prerantaco Well-Known Member
    mesa, az
    prerunner
    sorry if this is a stupid question, but are you going to run the turbo AND the supercharger??
  15. Mar 7, 2013 at 10:48 AM
    #95
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Not a stupid question, there is a guy that has been trying and failing at it for a while though. Nope, sold my TRD unit a while back in preparation for this.
  16. May 27, 2013 at 2:14 PM
    #96
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Lookin good Clifford! Another bad ass build. I was wondering if u had a build thread but finally saw it lol. I think you'll be boosted sooner than I will.
  17. May 27, 2013 at 2:27 PM
    #97
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
  18. Jan 29, 2014 at 11:33 AM
    #98
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Built motor is done.
    That is all.
  19. Jan 29, 2014 at 12:24 PM
    #99
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Can't wait to fondle it. haha
  20. Jan 29, 2014 at 12:30 PM
    #100
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    You always know just what to say haha.
