X-Runner Oil Pan Spacer FS
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Coupe, Jan 24, 2016.
  1. Apr 9, 2021 at 7:28 PM
    #61
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    Wizard and MeJBRO like this.
  2. Apr 9, 2021 at 7:32 PM
    #62
    Coupe
    Coupe [OP] Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    We can discuss it if you want.
    I would need to look at pricing for this.
    I still have one on my truck.
    MeJBRO likes this.
  3. Apr 12, 2021 at 5:08 AM
    #63
    Sxorch
    Sxorch Member
    Thomas
    2005 Tacoma X-Runner
    Long tube header, AFE CAI,
    That's a nice pan, just a little steep for my pocket.
    JohnGabriel likes this.
  4. Apr 12, 2021 at 5:18 AM
    #64
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    That pricing was several years old, I would have to work up new pricing. It would be higher.
  5. Apr 13, 2021 at 3:06 PM
    #65
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    This is the official list:
    0. Coupe, baffled spacer
    1. Sxorch, baffled spacer
    2. sf.larry, baffled
    3. MeJbro, baffled
    JohnGabriel asked to be pulled from the list.
    whatstcp likes this.
  6. Apr 15, 2021 at 9:33 AM
    #66
    sf.larry
    larry
    2011 XR
    Should we start discussing the cost for 3? I’m sure that’ll still be cheaper (and easier) than going to the 4x pan.
  7. Apr 16, 2021 at 5:59 AM
    #67
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Let me first rant a little on machining parts. Most modern machine shops are CNC. These means there is some set up time before you make a part. You have to turn a drawing into a program that the CNC machine can read. Some times you need to make some special fixturing to hold a part in a machine. With that said, when you machine a part there is time spent in the set up of a run of parts. After the part run is finished, you will need to remove some fixturing. The time to do these functions is figured into the cost of the parts. The more parts you run, this cost per part becomes less.
    Now other things effect cost such as materials. If you look at at thread that is a few years old, there has been some increase in material costs over that time period.
    The cost of three (3) oil pan spacers will be:
    $370 for unbaffled each
    $520 for baffled each
    For this I need a $100 deposit from each of the three (3) people that want it before I start machining.
    To make a billet oil pan, I need a minimum of two (2). Price would be $1350 each
    For this I need a $500 deposit from each of the two (2) people that want it, before I start machining.
    Sorry for the higher prices, but that is just the way it is.
  8. Apr 16, 2021 at 10:26 AM
    #68
    Wizard
    Wizard Member
    Murrieta, CA
    06 SWB Xrunner
    TRD SC
    The link to the thread on XRU discussing this deep sump oil pan is broken. Can you please share a new link? Interested in this or the spacer with baffle.
  9. Apr 16, 2021 at 10:30 AM
    #69
    Wizard
    Wizard Member
    Murrieta, CA
    06 SWB Xrunner
    TRD SC
    Count me in for either the oil pan spacer with baffle, or the billet oil pan! I remember bugging you on XRU many years ago for another run of these. I won't miss out this time! Just need more info on the the pros/cons of the billet oil pan vs the spacer with baffle. My 2006 X-runner has a TRD SC and supporting mods. I'm ok with the pricing. Thank you.
  10. Apr 16, 2021 at 11:32 AM
    #70
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    hemitruk likes this.
  11. Apr 16, 2021 at 11:39 AM
    #71
    Wizard
    Wizard Member
    Murrieta, CA
    06 SWB Xrunner
    TRD SC
    Thanks Coupe. Good thread. What did you develop first? Deep oil pan or spacer with baffle? Why were both developed? To serve different needs I suppose. What are those needs? Pros and Cons comparing the two would be appreciated. How much oil does the deep oil pan hold compared to OEM oil pan with spacer? Thanks.
  12. Apr 16, 2021 at 1:15 PM
    #72
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Oil pan spacer was first. It was made without a baffle. It will add 1 qt of oil.
    One of the members on XRU (Grumpy) bought one of my spacers and added a baffle. I liked what he did so I added that option.
    I liked the idea of larger oil pans with baffles that help direct the oil where you want it. This pic shows the inside of the oil pan baffle.
    The rubber trap doors in this pic helps keep the oil from sloshing to the far left or right of the pan. It acts like a check valve to keep the oil in the center section of the oil pan where the oil pick up tube is located.
    The rubber pieces are from a BMW that uses it for the same thing.
    The installation of the oil pan is a little easier than the spacer.
    The oil pan will hold 2 quarts of oil. It may take 2 1/2 if you run a large oil filter.
    I like the look of the oil pan and I think it works better, but it is expensive.
    The oil pan spacer is an improvement over stock, maybe not as effective as the oil pan, but is priced cheaper.
  13. Apr 16, 2021 at 3:16 PM
    #73
    Wizard
    Wizard Member
    Murrieta, CA
    06 SWB Xrunner
    TRD SC
    Thanks Coupe, great info. So I add 2 to 2.5 more quarts of oil, and the read the oil dip stick as normal?
    Put me down for the Deep Sump oil pan! Hopefully another buyer steps up. I really hope this mini group buy goes through.
  14. Apr 16, 2021 at 3:25 PM
    #74
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    You read the dip stick as normal.
  15. Apr 16, 2021 at 3:27 PM
    #75
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    This is the official list for Oil Pan Spacer:
    3. MeJbro, baffled
    Members on this list need to confirm they want to stay on this with pricing for 3 people.
    This is the official list for Deep Oil Pan:
    1. Wizard
  16. Apr 16, 2021 at 10:36 PM
    #76
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Nice work
    Coupe[OP] likes this.
  17. Apr 17, 2021 at 10:10 AM
    #77
    JohnGabriel
    JohnGabriel Well-Known Member
    2005 x runner
    Hurst shifter and lexus isf bbk
    I may be back in if my motor is still good. Lol. I just discovered that my exhaust after the y pipe is loose and coming undone so hoping that may be the reason I'm running rough. The mechanic didnt have time to diagnose my truck on my days off.
  18. Apr 22, 2021 at 8:45 AM
    #78
    sf.larry
    larry
    2011 XR
    I tried to tell myself no but I’m in for the deep pan.
    Wizard likes this.
  19. Apr 22, 2021 at 9:14 AM
    #79
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    2. MeJbro, baffled
    1. Wizard - Deposit Paid
    2. sf.larry - Deposit Paid
    I have enough people to do the the Deep Oil Pan. I will start asking for deposits for the deep oil pan. Once I have the deposits, I will start acquiring material and start machining.
    O.K. we have a party now. I will start getting materials together for the Deep Oil Pan. I will post progress on this thread.
  20. Apr 23, 2021 at 12:25 AM
    #80
    Wizard
    Wizard Member
    Murrieta, CA
    06 SWB Xrunner
    TRD SC
    Woohoo! Welcome aboard sf.larry!
    Coupe, I just sent my deposit. Thanks again for doing another run of these! I'm still rockin' your TRD CAI cover and custom shift knob on my X! Love your stuff.
